[SOLVED] Bookmark problem
Results 1 to 15 of 18
    Jan 2008
    170
    Bookmark problem
    I am running F23 with the latest Firefox 43.0.3
    Since a few days I can't add new bookmarks into the Bookmarks Menu or Toolbar...
    I checked preferences and compared all of them with some other systems running the same Fedora version and Firefox version.
    I simply can't figure out what happens here...
    Any idea/help would be appreciated
    Aug 2011
    1,952
    Re: Bookmark problem
    Seems to work fine over here.
    You might want to "refresh" your firefox profile.
    Jan 2008
    170
    Quote Originally Posted by Dutchy
    Thanks!
    What do you mean with "refresh" the firefox profile ?
    Cheers
    Just found out that I can't even delete bookmarks. That said, the complete handling of bookmarks is corrupted...
    Winterpeg, Canada
    72
    They could all be in Unsorted Bookmarks or you have so many in your Bookmarks Toolbar that they cannot be shown within Firefox, so they appear hidden to you.
    Lenovo T61: CPU: Intel 8100 Video: NVIDIA Quadro NVS 140M chip RAM: 4 GB DASD: WD Scorpio 320 GB SATA Wireless: Intel Corporation PRO/Wireless 4965
    Fedora 26 Workstation (x86_64) + GNOME 3.24.3 + Cairo-Dock 3.4.1
    Jan 2008
    170
    Quote Originally Posted by jimj_wpg
    I see all type of Bookmarks, but I can't manage (adding, deleting & editing) them anymore !!!
    Maryland, US
    7,448
    You can try Firefox 44, it's in the updates-testing dnf repository or it should show up in Fedora updates soon.
    You also might try exporting your bookmarks to html, html would be a format that's easy to
    review by eye to verify it's not corrupted.
    Backup the existing bookmarks from the Firefox menu:
    Bookmarks -> Show All Bookmarks
    -> Import and Backup -> Export Bookmarks to HTML... and give that file some name and save it
    Exit Firefox and look over the bookmarks.html file you made. If the bookmarks look like they
    make sense (new ones you just recently added are in there and the format
    looks good) then move the existing firefox profile folder out of the way (rename the directory
    under ~/.mozilla/firefox/*default* to some other name like
    ~/.mozilla/firefox/*default*-saved (note that I show asterisks there, the actual
    directory name is gibberish like ~/.mozilla/firefox/abzdh1jha.default-4194567391383
    but the string "default" is always in there. Mozilla does that to make the directory
    unique)
    and restart Firefox, Firefox will look in the ~/.mozilla/firefox/profiles.ini and
    find the named directory is not there anymore, so it will make a fresh one.
    At that point in Firefox, go back into menu Bookmarks -> Show All Bookmarks
    -> Import and Backup -> Import Bookmarks from HTML...
    use the file you previously saved.
    That way you'd have your original bookmarks but a brand new profile tree, possibly
    fixing a corrupted places.sqlite db file that was the problem.
    This is not fully good, you'd be leaving behind any saved passwords, login information and
    preferences. Those are saved in other files still back in that original *saved profile folder,
    See this: https://support.mozilla.org/en-US/kb...an-old-profile
    for the names and content of those files. This link here also has good instructions on how
    to make a fresh profile with the "Profile Manager", that might be a good thing to try first instead of
    my "move the directory hack" I've described here above.
    But you can get those back by exiting Firefox again and
    copying those files as you like from the old profile into the new one.
    Jan 2008
    170
    Firefox was upgraded to version 44.x
    I exported the bookmarks into bookmarks.html.
    Unfortunately only the bookmark folders are exported but no bookmark itself.
    The file is useless...
    I tried on another system with success, i.e the exported bookmark.html contains the folders and the bookmarks.
    I checked .mozilla with ls -la to see if there are any wrong permissions/owners.
    It looks like the other systems.
    Finally I did a Refresh Firefox which did NOT solve the problem.
    Bookmarks still can't be managed anymore...
    Maryland, US
    7,448
    What happens if you make a fresh profile via the ProfileManager and try to add, remove, move, etc some bookmarks in that?
    Is that what you meant by "Refresh Firefox"?
    Jan 2008
    170
    Refresh Firefox is a function provided by about:support. It saves the old profile and create a new one, then imports the bookmarks and other stuff from the old profile.
    After this I had all bookmarks again, but I can't still add new ones and delete current ones...
    Where do I find the Profile Manager ?
    Maryland, US
    7,448
    Quote Originally Posted by curano
    You start Firefox with the profile manager selected by running from the command line
    firefox -P
    or
    firefox --ProfileManager
    You can see the option from the firefox --help output:
    firefox --help
    It's also covered here in the URL I quoted back in post 6
    and in particular:
    https://support.mozilla.org/en-US/kb...refox-profiles
    Jan 2008
    170
    I'll give it a try.
    The URL you supplied lead to the same link as about:support (Refresh Firefox)
    Jan 2008
    170
    Quote Originally Posted by marko
    I created a new profile with Profile Manager.
    I can add, delete and modify bookmarks within this profile...
    Jan 2008
    170
    This doesn't help me.
    I can't take over the old bookmarks as I explained here before...
    Refresh Firefox doesn't solve the problem. I still can't add or remove bookmarks !
    Maryland, US
    7,448
    Well, I don't get what you mean, you said it worked (post 12), then you say it didn't work. which is it?
    I explained before, you can export the bookmarks from the broken profile and put them
    in the new one. At that point just use the new profile with the imported bookmarks.
    You set the new profile to be the default, that way Firefox always loads it.
    If Firefox itself is completely damaged, you might want to backup the bookmarks to a plain text file
    (assuming you can't export them to a html file) and then do:
    dnf reinstall firefox
    to reinstall it
    If that's not it, then someone else might be able to come up with a fix.
    Jan 2008
    170
    to reinstall it
    I explained this earlier. I did export the bookmarks into bookmarks.html and did import it to the new profile.
    But only the bookmark folders were exported but not the bookmarks themselves !!!
    This was the very first thing I did even before I asked for help...
    I saved the file firefox from .mozilla and removed and re-installed firefox and then restored the file firefox into .mozilla - this didn't hjelp !
    I used the Refresh Firefox (about:support) and this didn't help !
    Thanks for you efforts.
  1. Bookmark problem
    By jeb3121 in forum Using Fedora
    Last Post: 7th July 2014, 04:50 AM
  2. Firefox - Bookmark
    By rosiedayz in forum Using Fedora
    Last Post: 29th July 2009, 06:08 PM
  3. How to retrieve bookmark
    By Niche in forum Using Fedora
    Last Post: 17th September 2008, 05:27 AM
  4. Firefox can't bookmark
    By chucklinart in forum Using Fedora
    Last Post: 4th September 2008, 02:34 PM
