Issue with 3 monitor setup
    Nov 2011
    9
    I am using a 3 monitor setup on Fedora 23 (64bit).
    The primary device is NVidia with two monitors and the secondary is integrated Intel VGA.
    Using default nouveau driver.
    So far the issues are:
    1. The system randomly freezes forcing a hard reboot. Same issue persists with Ubuntu. Tried Wayland too. Nothing changes. The 3 monitor set-up works perfectly well on Windows 10, therefore it is a driver/configuration issue.
    2. A copy of the mouse pointer is stuck in the centre of the main display after login. It stays on top of all windows. Sometimes switching to a new session and back helps to get rid of it.
    3. The mouse pointer is flickering on monitors connected to nvidia but never on intel-connected monitor.
    Could you please help me out in solving these issues, especially the 1st one? I can live with issues 2 and 3.
    What information would you need?
    Seems that Fedora's syslog is cleared on every startup. Where could I find the old logs?
    Thanks,
    Gin
    PS. gnome-system-log does not start saying:
    # gnome-system-log
    Unable to init server: Could not connect: Connection refused
    (logview:4532): Gtk-WARNING **: cannot open display:
    Oct 2011
    1,917
    Re: Issue with 3 monitor setup
    That is a hard question, gpu drivers and/or multiple monitors setups doesn't work perfectly last time that I read about ii. You can use journalctl command to access logs. For boot log from last boot you can use:
    journalctl -b -1
    I guess first step is to find out which driver freezes system.
    Nov 2011
    9
    Thanks semiRocket.
    I disabled the integrated intel VGA in the attempt to avoid those freezes. Didn't help.
    Looked at the last boot logs (with intel disabled) and here what I found:
    Nov 10 14:49:55 g-PC gnome-software-service.desktop[2542]: (org.gnome.Software:2542): Gs-WARNING **: Not already a started task for 0x555aed1f42d0~packagekit-refine
    Nov 10 14:49:55 g-PC PackageKit[1749]: resolve transaction /115_edbaedac from uid 1000 finished with success after 338ms
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (**) Option "fd" "16"
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (**) Option "fd" "19"
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (**) Option "fd" "20"
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (**) Option "fd" "21"
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) AIGLX: Suspending AIGLX clients for VT switch
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) NOUVEAU(0): NVLeaveVT is called.
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) systemd-logind: got pause for 13:65
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) systemd-logind: got pause for 13:67
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) systemd-logind: got pause for 13:66
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) systemd-logind: got pause for 13:64
    Nov 10 14:50:15 g-PC /usr/libexec/gdm-x-session[2055]: (II) systemd-logind: got pause for 226:0
    Nov 10 14:50:15 g-PC kernel: nouveau E[     DRM] GPU lockup - switching to software fbcon
    Nov 10 14:50:15 g-PC systemd[1]: Started Getty on tty3.
    Nov 10 14:50:15 g-PC audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=getty@tty3 comm="systemd" exe="/u
    Nov 10 14:50:15 g-PC systemd[1]: Starting Getty on tty3...
    Nov 10 14:50:19 g-PC audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/l
    Line "Nov 10 14:50:15 g-PC kernel: nouveau E[ DRM] GPU lockup - switching to software fbcon" is marked in red.
    Oct 2011
    1,917
    This does indeed look bad. I don't have any experience with nvidia drivers but maybe there is some official binary drivers available that would work better.
    Sorry I don't have any better advice.
    Nov 2011
    9
    Back to the start: I now have a stable (hopefully) configuration with nvidia and two monitors.
    Had to downgrade X11 to a stable Fedora 22 release and then installed nvidia drivers. Otherwise it was impossible to work.
    Apparently f23 ships with a pre-release version not supported by nvidia (why pre-release??).
    Now is the question: how do I configure x11 for intel vga and the monitor?
  1. F18 3 monitor setup
    By dbemowsk in forum EOL (End Of Life) Versions
    Last Post: 16th May 2015, 06:34 PM
  2. Set primary monitor for a dual monitor setup?
    By blah569 in forum Using Fedora
    Last Post: 15th July 2009, 04:49 PM
  3. Monitor Setup
    By mat.hunt in forum Hardware
    Last Post: 27th March 2007, 06:10 PM
  4. Monitor Setup
    By genisis300 in forum Using Fedora
    Last Post: 21st March 2005, 05:17 PM
[[template footer(Guest)]]
