liveusb-creator does not detect my flash drive
Results 1 to 9 of 9
    Jul 2015
    MD
    4
    Hi all,
    I recently created a LinuxMint17 bootable USB stick which worked fine at first but asked for login information and did not accept mint as user with blank password. I read online that you might just need to retry creating the bootable USB. So I booted back into Fedora 22 and formatted my flash drive. However now liveusb-creator does not recognize my flash drive (even though I can see the 16GB Volume in Disks and Files). How can I make it visible?
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,832
    Re: liveusb-creator does not detect my flash drive
    The Live Linux iso's themselves are not asking for a password, I believe that is created by the liveusb-creator program itself. This foils person after person (who, I suppose, don't bother to read the manual for liveusb-creator before using it). Are you saying you could boot into the LinuxMint USB stick at first without a password prompt, but then later is started asking for a password, or did it always ask for a password to boot into the Live system? If it's the former, then I'm puzzled. If the latter, that's a common occurrence caused by the imaging program.
    Either way, the best and easiest solution is to use the dd command from a command prompt to image the LinuxMint iso to the USB stick.
    dd won't care what's already on the stick, or not, as it does a byte for byte copy of the image file. Just make sure the USB stick is not mounted before using the dd command from Fedora.
    # dd if=</path/to/the/MintISOfile> of=/dev/sd<x> bs=8M
    "if" is the InputFile, "of" is the OutputFile (Device). Make sure you specify the correct /dev/sd? that is the USB stick.
    Dec 2007
    Australia
    1,891
    I've found dd has been more reliable than a number of programs that write isos. To find the correct device name for your usb, run:
    cat /proc/partitions
    or
    lsblk
    and prepend the /dev/ to the sd? name.
    Jul 2015
    MD
    4
    Hey all,
    currently writing this post from Linux Mint 17.2 mounted on my hard drive dd was the way to go! Thanks so much to everyone who helped me
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,832
    Quote Originally Posted by Garfin
    Hey all,
    Nice that you got that going. I have an install of LinuxMint 17.1/Xfce on my desktop PC, which also boots both 32 and 64 bit installs of F22 and W7.
    Feb 2007
    China
    161
    Hi all,
    I have the exactly same problems here: I can find and use my USB stick as usual, but when I try to use LiveUSB-creator to make a bootable USB stick, it always complains that it can not find any USB devices.
    What can I do with it? Thanks.
    Home: Pentium III. 768M. GeForce GT 730. 120G(3 HDDs)
    Office: Lenovo Xiaoxin 700-15ISK
    Fedora 28
    Jun 2006
    Paris, TX
    24,107
    Beyond using the simple effective magic of dd as described above, you can thoroughly complicate the issue at will by using Gparted to find and delete all partitions on the USB stick, rewrite the partition table using (FAT32) and then physically disconnect the USB stick from the computer. Then plug the USB stick back in, (preferably to a different USB port) and re-start Liveusb-creator (via sudo or as root). It should then properly detect your USB stick.
    I've done both.
    Both worked.
    I'll leave you to decide which suits you better.
    Feb 2016
    End of the earth
    94
    Well I use to use either live usb creator or unetbootin but lately they were giving me trouble. DD is the way to go. I use DD to wipe usb flash drives and a hard drive now and then. Now I use it for live usb creation also. Should have switched to this method sooner. Live and learn
    Feb 2007
    China
    161
    Thanks to both @Dan and @Temujin !
    I tried the Fat-32 way and Liveusb-creator still can not find the stick. The dd gives me a properly wiped and bootable stick.
    Thanks! But, still want to know what have happened to Liveusb-creator and MultiWriter ( it could not find the stick either.)
    Fedora 28
  1. DVD ISO to Flash Drive Creator
    By lsatenstein in forum Rawhide
    Last Post: 11th April 2013, 09:16 PM
  2. Should flash drive have FAT or ext4 on it before running LiveUSB creator?
    By recondite in forum Installation, Upgrades and Live Media
    Last Post: 18th January 2013, 11:35 PM
  3. liveusb(created with liveusb-creator) not boot
    By omid2012 in forum Installation, Upgrades and Live Media
    Last Post: 10th June 2012, 03:04 PM
  4. Advantages/Disadvantages LiveUSB vs. Full Install on Flash Drive
    By zackf in forum Installation, Upgrades and Live Media
    Last Post: 2nd February 2010, 02:37 AM
  5. FC6 T3 Fails to detect USB Flash Drive
    By j_baer in forum Hardware & Laptops
    Last Post: 26th October 2006, 08:42 AM
