Results 1 to 8 of 8
    Dec 2009
    Veneto
    18
    Installing Fedora using Finnix
    A shell script that can be executed from the Finnix live environment in order to install Fedora 22 on 64-bit x86 machines is now available.
    Download x86_64-efi-fnx-f22-install.zip (4.0 KB).
    Dec 2009
    Veneto
    18
    Installing Fedora 23
    A shell script that can be used in order to install Fedora 23 is now available.
    Download x86_64-efi-fnx-f23-install.zip (4.1 KB).
    Dec 2009
    Veneto
    18
    Installing Fedora 24
    A shell script that can be used in order to install Fedora 24 is now available.
    Attached Files Attached Files
    6,133
    Re: Installing Fedora using Finnix
    Thread title edited to remove version number as you've added updated scripts for newer versions since starting it last June
    Dec 2009
    Veneto
    18
    Installing Fedora 25
    A shell script that can be used in order to install Fedora 25 is now available.
    Dec 2009
    Veneto
    18
    Installing Fedora 26
    A shell script that can be used in order to install Fedora 26 is now available.
    Dec 2009
    Veneto
    18
    Installing Fedora 27
    A shell script that can be used in order to install Fedora 27 is now available.
    Dec 2009
    Veneto
    18
    Installing Fedora 28
    A shell script that can be used in order to install Fedora 28 is now available.
  1. Problem installing Fedora 15 x64 from installing CD
    By jackscorrow in forum Installation, Upgrades and Live Media
    Last Post: 14th October 2011, 04:31 PM
