Can't open settings
    Nov 2011
    27
    Can't open settings
    After a clean install of F22, I can't open the settings menu.
    Running gnome-control-center from terminal gives output:
    gnome-control-center: error while loading shared libraries: libwbclient.so.0: cannot open shared object file: No such file or directory
    dnf reinstall libwbclient does not resolve the problem.
    Any ideas?
    7,155
    6 Post(s)
    1 Thread(s)
    Re: Can't open settings
    http://forums.fedoraforum.org/showthread.php?t=304178
    I posted about this yesterday in the thread I link to above. The necessary updates needed to fix the problem are pending on bodhi. the first update wasn't complete so they had to re-release.
    https://admin.fedoraproject.org/upda...a-4.2.1-4.fc22
    Jan 2012
    all world
    144
    Post Re: Can't open settings
    Quote Originally Posted by Maupertus
    Any ideas?
    gnome-control-center has used a old version of libwbclient (4.1.12-X) for packing, when you pack a 'rpm' forever will enable a macro "autorequires" and "provides", the solution is: rebuild or update gnome-control-center with the new libwbclient; or disable the macro autoreqprov...
  1. Replies: 1
    Last Post: 19th June 2009, 05:56 PM
  2. open with.... dialog and shortcut settings
    By muskote33 in forum Using Fedora
    Last Post: 31st May 2007, 09:54 PM
  3. Replies: 1
    Last Post: 29th January 2007, 06:33 AM
