Bookmark problem
Results 1 to 12 of 12
    Nov 2011
    198
    Bookmark problem
    Hi All,
    I run F 19 32 Gnome from a dedicated drive and am unable to save bookmarks in Firefox. This has occurred over reinstalls of F19 and the progression from FF 28->30.
    This may be a FF problem and I'm contacting them also, but I wondet if anyone here has had the same problem.
    Hopefully,
    jeb
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,804
    Re: Bookmark problem
    Umm, have you checked in Bookmarks > Recently Bookmarked and/or Bookmarks > Unsorted Bookmarks to see if your "missing" bookmarks are there?
    Nov 2011
    198
    Quote Originally Posted by PabloTwo
    Hi Pablo, thanks for your quick response.
    My problem is more basic. When I click on "Bookmark This Page" or key Ctrl D I should get a popup which has the name and address of the web page I'm on. This is where I choose where in the bookmarks I want to put it. The popup doesn't come up.
    Both click and key bring the popup for bookmarks already in my list.
    There's a thread on Mozilla for this problem which seems to be in versions 28->30. Unfortunately, it only has 'try this or that,' not solutions.
    jeb
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,804
    That explains your problem much better. What firefox plugins/extentions do you have active?
    Nov 2011
    198
    Hi
    Going to Help, I restarted with Add-ons Disabled which disabled all the extensions. Then I disabled all the plugins.
    No change; neither click nor key brings the popup.
    In addition, when I go to "Show All Bookmarks," click on left-side Toolbar, Menu or Unsorted and then right-click on right-side a popup gives me several options. One is New Bookmark where I can type in the blank spaces, but can't Cancel or Add.
    At that point the Library Tab screen goes gray and the upper-right corner "x" doesn't work. This doesn't seem to effect the other Tabs. It's necessary to close FF to eliminate that Tab.
    I hope you can make more sense of this than I can.
    jeb
    Nov 2011
    198
    Click error
    PabloTwo's Avatar
    Mar 2007
    Seville, FL
    7,804
    I hadn't run across this type of problem in firefox before. I can only think of two things to try.
    Check for any possibly corrupted firefox install files with the command,
    rpm -V firefox
    No output means no altered files were found.
    Create a new user profile and see if by using firefox with the new profile, the problem still exits. You can do that one of two ways...
    Launch firefox from the command line with: firefox -ProfileManager
    which should have an option to create a new profile if only one exists. Then then when you relaunch firefox, it should come up with a window to select which profile to use.
    Launch firefox from the command line with: firefox -CreateProfile <name>
    which should create a new profile. And again, relaunching firefox should bring up the profile manager and let you select which one to use.
    Nov 2011
    198
    Solved: Bookmark problem
    rpm -V firefox
    Hi Pablo,
    Sorry to be so long; I had offline stuff to do.
    I created a new profile with all addons and extensions inactive, then activated Foxclocks and Download Helper(having a 2nd smaller problem). The boolmark popup now comes and the 2nd problem-Download Helper, is solved as well.
    I have a number of extensions and addons so I plan to activate one at a time(and take a closer look at each of them for utility).
    I have a question: In the Plugins Shockwave Flash is shown as Always Activate whereas all the others say Ask to Activate. Is there any significance to the difference?
    Thanks again for the help.
    jeb
    PS I've yet to receive a useful response from Mozilla
    Aug 2011
    899
    About the Adobe flash plugin, this a deliberate upstream change, all plugins are set to "ask to activate"/click-to-play by default except Adobe Flash: https://bugzilla.mozilla.org/show_bug.cgi?id=899080
    https://developer.mozilla.org/en-US/...bility#Plugins
    FWIW, I always change it to "ask to active".
    Nov 2011
    198
    Quote Originally Posted by Ahmad Samir
    Hi Ahmad,
    Thanks for your hot-off-the-stove quick response.
    Another question to illustrate my level of expertise
    I assume "Always Activate" means it's on whenever FF is; what are the disadvantages of always on?
    Thanks again,
    jeb
    Aug 2011
    899
    If say you go to a youtube page with a video in it:
    - if you have it set to "always activate" the video will play as soon as the page finishes loading
    - if you have it set to "ask to activate" then the video won't play until you allow the plugin either: "allow" (i.e. just this time) or "allow and remember" (i.e. always allow this plugin for this web site).
    Nov 2011
    198
    Hi Ahmad,
    Succinctly put, thank you. I deal with a lot of videos so Always Activate sounds good.
    Thanks again.
    jeb
  1. Bookmark management
    By glennzo in forum Using Fedora
    Last Post: 6th January 2011, 09:01 PM
  2. Firefox - Bookmark
    By rosiedayz in forum Using Fedora
    Last Post: 29th July 2009, 06:08 PM
  3. How to retrieve bookmark
    By Niche in forum Using Fedora
    Last Post: 17th September 2008, 05:27 AM
  4. Firefox can't bookmark
    By chucklinart in forum Using Fedora
    Last Post: 4th September 2008, 02:34 PM
