fedora 20 mate compiz problem
    Jan 2014
    Madrid
    When i enable compiz as the window manager the cursor changes to a black one (Adwaita).
    i tried to change it but now matter what i do it remains black with exception when the cursor is over some applications like firefox, then it looks like it should.
    i already tried changing in dconf the cursor theme in gnome and mate for the one i want, also edited
    /usr/share/icons/default/index.theme but didn't work
    if i disable compiz the cursor theme works.
    any possible solution to have a cursor theme and compiz at the same time ?
    thanks
    Sep 2014
    Mexico
    Re: fedora 20 mate compiz problem
    Hi. I have a similar problem. You solved?
    In Fedora 20 mate+compiz 64bits
    use terminal command: $fusion-icon
    , after my pc freeze.
    This is output in terminal command:
    [favio@localhost ~]$ fusion-icon
    * Detected Session: mate
    * Searching for installed applications...
    * Using the GTK Interface
    * Starting Compiz
    ... executing: compiz --replace --sm-disable --ignore-desktop-hints ccp
    compiz (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
    nouveau: kernel rejected pushbuf: Cannot allocate memory
    nouveau: ch0: krec 0 pushes 1 bufs 9 relocs 46
    nouveau: ch0: buf 00000000 00000002 00000004 00000004 00000000
    nouveau: ch0: buf 00000001 0000000b 00000002 00000002 00000002
    nouveau: ch0: buf 00000002 0000000c 00000002 00000002 00000000
    nouveau: ch0: buf 00000003 0000000a 00000002 00000002 00000000
    nouveau: ch0: buf 00000004 00000007 00000004 00000004 00000000
    nouveau: ch0: buf 00000005 00000015 00000002 00000002 00000002
    nouveau: ch0: buf 00000006 00000009 00000002 00000002 00000002
    nouveau: ch0: buf 00000007 0000000e 00000004 00000004 00000000
    nouveau: ch0: buf 00000008 00000008 00000002 00000002 00000000
    nouveau: ch0: rel 00000000 000016d8 00000001 00000000 0004e210 00000000 00000000
    nouveau: ch0: rel 00000000 000016dc 00000001 00000001 00000000 00000000 00000000
    nouveau: ch0: rel 00000000 000016e0 00000001 00000000 0004e214 00000000 00000000
    nouveau: ch0: rel 00000000 000016e4 00000001 00000001 00000000 00000000 00000000
    what can i do?
    raveit65 Guest
    @about cursor theme
    lightm-gtk-1.8.5-9.fc20 fix the issue
    If you use compiz you can switch the cursor theme in ccsm manager.
    see rhbz (#989152)
    @Abdid
    using compiz with a livecd isn't funny, performance is too low.
    nouveau crashed because of missing memory in your case.
    Install Mate on disk and you'll be happy.
  1. Thanks for Fedora 19 MATE-Compiz
    By hopenheim in forum Fedora Spins & Remixes
    Last Post: 3rd October 2013, 07:31 AM
  2. Questions about F19 Compiz MATE Spin
    By xumangore in forum Using Fedora
    Last Post: 17th September 2013, 12:29 PM
  3. mate compiz ?
    By b4time in forum Using Fedora
    Last Post: 22nd May 2013, 01:16 PM
  4. Compiz on Fedora 18 with MATE
    By Ihatewindows in forum Guides & Solutions (Not For Questions)
    Last Post: 21st April 2013, 05:10 AM
  5. Replies: 1
    Last Post: 27th February 2013, 09:34 PM
[[template footer(Guest)]]
