Problem to mount a partition
Results 1 to 7 of 7
    Oct 2013
    Colombia
    24
    10
    Exclamation Problem to mount a partition
    Hi , thanks for read my problem.
    i've the next problem.
    i just have installed a Fedora and i connect a external hard drive and it print the next problem :/
    Ocurrió un error al acceder a «MikeSoft - HardDrive», el sistema respondió: The requested operation has failed: Error mounting /dev/sdb1 at /run/media/Mike/MikeSoft - HardDrive: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dm ask=0077,fmask=0177" "/dev/sdb1" "/run/media/Mike/MikeSoft - HardDrive"' exited with non-zero exit status 13: MFT is corrupt, cannot read its unmapped extent record 18 Note : chkdsk cannot fix this, try ntfsfix Inode is corrupt (0): Error de entrada/salida Failed to load runlist for $MFT/$DATA. highest_vcn = 0x3, last_vcn - 1 = 0xcfbf Failed to load $MFT: Error de entrada/salida Failed to mount '/dev/sdb1': Error de entrada/salida NTFS is either inconsistent, or there is a hardware fault, or it's a SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows then reboot into Windows twice. The usage of the /f parameter is very important! If the device is a SoftRAID/FakeRAID then first activate it and mount a different device under the /dev/mapper/ directory, (e.g. /dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation for more details.
    i don't understand what's the problem =S
    THANKS
    leigh123linux Guest
    Re: Problem to mount a partition
    Quote Originally Posted by mikesoft
    THANKS
    Well the message clearly states that your windoze ntfs partition has a corrupt mft and that you should run chkdsk from windoze to fix it.
    Feb 2011
    193
    This is a major error. Did you defragment this disk recently ? What were your latest actions on it ? Did you mount this disk on Linux before ?
    This situation is known to be created on Windows and chkdsk is known to not be able to repair it, but it would be useful to know under what conditions it happens.
    First start as root the command :
    ntfsfix -n /dev/sdb1
    The option -n is important. This will assess the damage, and no fix will be applied (please post the output, and wait for the go ahead).
    leigh123linux Guest
    Quote Originally Posted by Jean Pierre
    So windoze can't fix it's own partitions?, unbelievable, what were those stupid wa*kers thinking at M$.
    Oct 2013
    Colombia
    24
    10
    Sorry for the topic just for this.
    i fixed the problem with this command:
    ntfsfix -b /dev/sdb1
    ---------- Post added at 06:23 PM ---------- Previous post was at 06:22 PM ----------
    Thanks for all
    Feb 2011
    193
    This bug is probably not caused by Windows itself. Let me explain : a part of the file table has been relocated, but Windows forbids to relocate the first 16 entries, so the first 16 entries are still in the old location, and the other ones are in a new location, and this new location has been recorded in entry 18, so you have to know where the entry 18 is to read it and know where it is. This is the equivalent of locking your car, slamming the door and leaving the keys inside.
    Now, there is no such thing as relocating the MFT in ntfs-3g, and there is probably none in the Windows ntfs driver. This has to be done by a third party package, probably a defragmenter.
    Note that is a treacherous bug : Windows keeps the MFT in its cache, so everything appears to be normal after the relocation, and you only discover the issue at next reboot.
    For the topic to be useful to prevent other users from falling into this trap, please tell us what third party software you have used the last time the disk could be mounted.
    Nov 2018
    Athens
    Linux Firefox 52.0
    Yesterday i realized that my Toshiba MQ01ABD100 is corrupted when i connect it via USB (the only possible connection) to a win10 mini pc.
    I write this reply to say that when i tried to rescue the disk in parted magic i had the same message:
    "MFT is corrupt, cannot read its unmapped extent record 18 Note : chkdsk cannot fix this, try ntfsfix Inode is corrupt (0): Input/output error Failed to load runlist for $MFT/$DATA. highest_vcn = 0x3, last_vcn - 1 = 0xfc7f Failed to load $MFT: Input/output error Failed to mount '/dev/sdb1': Input/output error NTFS is inconsistent. Run chkdsk /f on Windows then reboot it TWICE!"
    So i write the code: ntfsfix -n /dev/sdb1 in terminal of parted magic as Jean Pierre suggested the MFT fixed.
    But if you want to know what third party software i used the last time the disk was ok to be mounted was a win7 no updated pc a long time ago ( around 1 month ).
    Big thanks to this forum and Jean Pierre.
    I saved my data and my disk. The alternative was to save only the disk by formatting it as windows suggested.
  1. NTFS partition mount problem
    By Apostate in forum F17 Development Forum
    Last Post: 15th April 2012, 11:58 AM
  2. Partition mount problem in KDE
    By sbjaved in forum Using Fedora
    Last Post: 27th April 2009, 06:38 AM
  3. Replies: 2
    Last Post: 17th March 2007, 04:20 AM
  4. Mount windows partition problem!
    By Martijn - R'dam in forum Hardware & Laptops
    Last Post: 16th June 2006, 03:43 PM
  5. Mount fat32 partition Problem
    By BrokenKingpin in forum Using Fedora
    Last Post: 3rd January 2006, 11:26 PM
