[SOLVED] kmod-nvidia GLX module problems
Results 1 to 9 of 9
    May 2008
    61
    I am using the kmod-nvidia package. Since a few versions (I cannot say from which exactly) the GLX module is not loaded anymore. The log file says
    (II) LoadModule: "glx"
    (II) Loading /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
    (EE) Failed to load /usr/lib64/xorg/modules/extensions/nvidia/libglx.so: libnvidia-tls.so.304.64: cannot open shared object file: No such file or directory
    (II) UnloadModule: "glx"
    (II) Unloading glx
    (EE) Failed to load module "glx" (loader failed, 7)
    I tried to symlink the existing module which has version 304.88 but I still cannot find it.
    # locate libnvidia-tls.so
    /usr/lib64/nvidia/libnvidia-tls.so.1
    /usr/lib64/nvidia/libnvidia-tls.so.304.64
    /usr/lib64/nvidia/libnvidia-tls.so.304.88
    /usr/lib64/nvidia/tls/libnvidia-tls.so
    /usr/lib64/nvidia/tls/libnvidia-tls.so.1
    /usr/lib64/nvidia/tls/libnvidia-tls.so.304.64
    /usr/lib64/nvidia/tls/libnvidia-tls.so.304.88
    /usr/lib64/xorg/modules/extensions/nvidia/libnvidia-tls.so.304.64
    What can I do to get the GLX module working again?
    Thanks,
    Markus
    Jan 2009
    FL
    105
    Re: kmod-nvidia GLX module problems
    can you post the output of
    rpm -q xorg-x11-drv-nvidia-libs
    echo -
    rpm -qV xorg-x11-drv-nvidia-libs
    echo -
    rpm -qa | grep xorg-x11-drv-nvidia
    thanks
    May 2008
    61
    # rpm -q xorg-x11-drv-nvidia-libs
    xorg-x11-drv-nvidia-libs-304.88-1.fc18.x86_64
    # echo -
    # rpm -qV xorg-x11-drv-nvidia-libs
    # echo -
    # rpm -qa | grep xorg-x11-drv-nvidia
    xorg-x11-drv-nvidia-304.88-1.fc18.x86_64
    Jan 2009
    FL
    105
    ok thanks. how about
    ldd /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
    also, can you tell me out of the files you listed which ones are symlinks, and which ones you created yourself (meaning not installed from RPM)?
    can you also provide the output of
    su -c 'grep xorg-x11-drv-nvidia /var/log/yum.log*'
    thanks
    May 2008
    61
    # ldd /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
            linux-vdso.so.1 =>  (0x00007fff26ffe000)
            libnvidia-tls.so.304.64 => not found
            libnvidia-glcore.so.304.64 => not found
            libc.so.6 => /lib64/libc.so.6 (0x00007fa082e16000)
            libdl.so.2 => /lib64/libdl.so.2 (0x00007fa082c12000)
            /lib64/ld-linux-x86-64.so.2 (0x000000360c600000)
    All the *.304.64 files are symlinks I created.
    # grep xorg-x11-drv-nvidia /var/log/yum.log*
    Jan 27 16:43:52 Installed: 1:xorg-x11-drv-nvidia-304.64-5.fc18.x86_64
    Jan 27 16:43:56 Installed: 1:xorg-x11-drv-nvidia-libs-304.64-5.fc18.x86_64
    Feb 09 22:39:04 Installed: 1:xorg-x11-drv-nvidia-304.64-5.fc18.x86_64
    Apr 12 19:59:02 Updated: 1:xorg-x11-drv-nvidia-libs-304.88-1.fc18.x86_64
    Apr 12 19:59:03 Updated: 1:xorg-x11-drv-nvidia-304.88-1.fc18.x86_64
    May 01 18:30:50 Installed: 1:xorg-x11-drv-nvidia-304.88-1.fc18.x86_64
    Jan 2009
    FL
    105
    hmm can you explain that yum log?
    on jan 27, you installed 304.64 (base pkg + libs). on feb 09, you installed 304.64 base pkg again? then on apr 12, you updated to 304.88 (base pkg + libs), and then on may 01 you installed the 304.88 base pkg again.
    were there some rpm -e in between those dates?
    is /usr/lib64/xorg/modules/extensions/nvidia/libglx.so a symlink to /usr/lib64/nvidia/xorg/libglx.so ? i ask because of what is listed in the xorg-x11-drv-nvidia package:
    $ repoquery -l xorg-x11-drv-nvidia | grep libglx.so
    /usr/lib/nvidia/xorg/libglx.so
    /usr/lib/nvidia/xorg/libglx.so.1
    /usr/lib/nvidia/xorg/libglx.so.304.88
    May 2008
    61
    I guess this is because around this time I bought a new computer and at seems that I copied the log files and of course on the new system I had to install kmod-nvidia again which would explain that.
    # ls -la /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
    -rwxr-xr-x. 1 root root 8488456 23. Feb 13:04 /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
    No, it is not a symlink.
    Jan 2009
    FL
    105
    well if you had to install everything again then i should expect to see xorg-x11-drv-nvidia-libs also listed there. nevertheless, if i do a whatprovides on */nvidia/libglx.so, the only thing it returns is xorg-x11-drv-nvidia-173xx, which is the legacy driver for older nvidia devices. methinks that particular libglx.so is the wrong one, and it should be loading the one at /usr/lib64/nvidia/xorg/libglx.so instead. is there a config file in /etc/X11/xorg/xorg.conf.d which defines a ModulePath of /usr/lib64/nvidia/xorg ? i guess you could do this if not,
    mv /usr/lib64/xorg/modules/extensions/nvidia/libglx.so /usr/lib64/xorg/modules/extensions/nvidia/libglx.so.bak
    ln -s /usr/lib64/nvidia/xorg/libglx.so /usr/lib64/xorg/modules/extensions/nvidia/libglx.so
    so when you went to this new machine, and you say you copied the logs over, what else did you copy over? possibly other parts of the filesystem, /usr maybe?
    May 2008
    61
    The strange thing is that the module worked before on the new machine. However, the module paths seemed to be wrong. In xorg.conf I changed them to the ones from /etc/X11/xorg.conf.d/00-nvidia.conf now and it is working again!
    Thanks for your help!
  1. Nvidia MX4000 - Failed to initialize the GLX module (Fedora 11)
    By gadgetwiz in forum Hardware & Laptops
    Last Post: 3rd February 2010, 11:11 PM
  2. Replies: 9
    Last Post: 5th September 2007, 10:28 PM
  3. Replies: 16
    Last Post: 14th July 2005, 08:57 PM
  4. Can Nvidia GLX and Mesa GLX live happily together?
    By alacheesu in forum Hardware & Laptops
    Last Post: 6th May 2005, 05:30 AM
  5. nvidia install GLX Xorg.conf problems
    By smudge in forum Using Fedora
    Last Post: 29th January 2005, 04:39 PM
