    Jan 2011
    wireless connection issue
    Hi all,
    The issue I'm facing is I can not obtain any Internet access (browser or ssh) from my fc16 desktop.
    Previously, with this same system, I was able to access Internet.
    The only change I made was (its a dual boot system) I booted
    into Windows and updated with the service pack.
    When I retried to boot fc16, I can see I have a wireless connection to the router, but no internet. Also, I tried to access internet with the desktop's firewall disabled. But, this did not make any difference.
    What steps should I take to fix this?
    "internet" 14L, 547C
    May 2011
    Confoederatio Helvetica (Swissh)
    Re: wireless connection issue
    Have you tried to restart the router yet?
    EFI Cheatsheet :: http://forums.fedoraforum.org/showthread.php?t=298546
    Video Handler Script (VHS) (mass re-encode videos, screenrecorder, console music/webradio player, ...) :: http://forums.fedoraforum.org/showthread.php?t=299182
    Windows 8+ & Fedora 20+ Dualboot :: http://forums.fedoraforum.org/showthread.php?t=298161
    Jan 2011
    Yes, I did restart the router. BTW I can connect to internet thru the router if I use a cable instead of the wireless.
    Jun 2009
    Hi Fedora Kernel-3.2.2 update killed nearly everyone's wireless connections. This is being fixed. Check you have the latest update installed (Kernel-3.2.6). If not, connect using your cable and install the latest update. This may well fix your wireless connection. It fixed mine.
  1. Unstable wireless connection with broadcom onboard wireless
    By dindoung1 in forum Servers & Networking
    Last Post: 21st December 2010, 03:27 AM
  2. Broadcom BCM4313 Wireless Issue - No Wired Connection
    By Glippo in forum Servers & Networking
    Last Post: 31st October 2010, 08:07 PM
  3. Replies: 1
    Last Post: 5th January 2008, 02:32 PM
  4. Replies: 1
    Last Post: 7th January 2007, 05:34 AM
  5. Replies: 7
    Last Post: 27th February 2006, 12:57 AM
