    Oct 2007
    395
    Smart card and Fedora
    Hi there. I am helping a customer who has a USB AC38 smart card reader, and a Siemens CardOS inside. The system is Fedora 13, 64 bit.
    I have installed pcscd and it can see the AC38, and it apparently can read the card, as I am getting the card's ATR.
    I also downloaded and untarred "HiPath SIcurity Card API V3.1 PKCS#11 for Linux" http://www.famzah.net/download/sieme...0_Linux.tar.gz
    file.
    However, the web site complains that libsiecap11.so cannot be loaded., although it exists in /usr/lib..
    Was anyone able to get this to work?
    Many thanks, -turgut
    stevea Guest
    Re: Smart card and Fedora
    Those are 32bit libraries ....
    $ file *.so
    libsiecadlg.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, not stripped
    libsiecap11.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, not stripped
    Which is fine if the app is 32bit also.
    Ii looks like those libraries are in /usr/local/lib - right ?
    To get the system to register those libraries do this as root:
    echo "/usr/local/lib" >> /etc/ld.so.conf.d/hipath.conf
    ldconfig
    Then try the command again. It should find the library then.
    Smart phone SD card NOT detected in Fedora 14
    By lpshark in forum Hardware & Laptops
    Last Post: 18th December 2010, 02:10 PM
  2. Fedora 12: Smart Card (DoD CAC) stopped working
    By cwebster in forum Using Fedora
    Last Post: 2nd July 2010, 12:14 AM
  3. HP Smart Card keyboard
    By S_Leveller in forum Using Fedora
    Last Post: 18th December 2009, 07:45 PM
  4. Fedora 11, smart card reader, firefox, and coollkey
    By leaskdw in forum Using Fedora
    Last Post: 18th December 2009, 07:31 PM
  5. Smart Card Reader
    By Bloomer510 in forum Guides & Solutions (Not For Questions)
    Last Post: 5th July 2007, 06:21 AM
