Openssl Help
    Feb 2006
    41
    Unhappy Openssl Help
    Hi All,
    Really hoping you can help me. I am trying to get openssl to verify a certificate.
    I will walk you through what I have done so far.
    1. openssl genrsa -des3 -out connect.mydomain.com.key 2048
    2. openssl req -new -key connect.mydomain.com.key -out connect.mydomain.com.csr
    3. Bought an SSL from GoDaddy.
    4. Submitted my CSR
    5. Downloaded sf_bundle.crt (CA File I presume)
    6. Downloaded connect.mydomain.com.crt
    Now I can do the following:
    [root@server tls]# openssl verify -CAfile sf_bundle.crt connect.mydomain.com.crt
    connect.mydomain.com.crt: OK
    This is specifying the CAfile.
    If I do:
    [root@server tls]# openssl verify connect.mydomain.com.crt
    connect.mydomain.com.crt: /O=connect.mydomain.com/OU=Domain Control Validated/CN=connect.mydomain.com
    error 20 at 0 depth lookup:unable to get local issuer certificate
    So for some reason the CA file is not working. I have no idea where it goes, I have tried moving it around all sorts of directories.
    In a word, I am stuck.
    Anyone any ideas?
    Feb 2006
    41
    Re: Openssl Help
    Just giving this a bump..
    unixrobot Guest
    Re: Openssl Help
    means that it can't find the CA that signed connect.mydomain.com.crt , error is mentioned here: http://www.openssl.org/docs/apps/verify.html
    here is small howto which should help you: http://www.herongyang.com/crypto/openssl_verify_2.html
  1. OpenSSL help
    By jcrapps in forum Security and Privacy
    Last Post: 8th April 2009, 06:58 AM
  2. OpenSSL Rc4 Help
    By TypeSH in forum Using Fedora
    Last Post: 4th October 2008, 03:08 AM
  3. yum & openssl
    By jstrope in forum Using Fedora
    Last Post: 13th February 2008, 05:11 PM
  4. OPENSSL 0.9.7a
    By xstation in forum Servers & Networking
    Last Post: 30th January 2006, 03:46 AM
