please help - reboot fails
Results 1 to 15 of 16
    Dec 2010
    52
    hey, during my last reboot fedora suddenly wont start just loads the opening screen then loads some lines the last is :
    init: prefdm respawning too fast , stopped
    and when i try to enter text mode and startx it loads the nvidia logo then blank screen, when i try to reboot during text mode it gives me this:
    canot open shared object file: permission denied even though i am root, all the changes i made was just removing wine cause it wasnt working properly thts it. guys plz help all my work is there and i need it soon
    leigh123linux Guest
    Re: plz help
    Thread title changed, please don't mark your posts as urgent!
    In fact try giving it a proper title that reflects the actual issue.
    Oct 2010
    229
    Re: plz help
    Have you backed up lately?
    Use the live cd to access your work if it is an emergency. The live cd can access your files and open documents. If you need something done that the live cd can not do, you can temporarily install the required software.
    Dec 2010
    52
    Re: plz help
    Quote Originally Posted by leigh123linux
    am srry , wont happen again , thnx p.s how can i change the title now
    ---------- Post added at 02:26 PM ---------- Previous post was at 02:22 PM ----------
    Quote Originally Posted by jroa1
    well i back up the most important of them, as for the livecd option i cant cause then ill need to install many programming ide s which would make like at least 600 mega which i cant do right now since iam working on a mobile broadband thnx anyway
    leigh123linux Guest
    Re: plz help
    Quote Originally Posted by forsakenedzero
    Could you include the name of the missing shared object? , it will be included in the error message.
    Dec 2010
    52
    Re: plz help
    on start up in text mode it gives me: error loading shared libraries libc.so.6
    when i enter reboot : its libnih.so.1 instead
    leigh123linux Guest
    Re: plz help
    Not good
    Post
    rpm -qa |grep glibc
    Dec 2010
    52
    Re: plz help
    Not good
    Post
    rpm -qa |grep glibc
    output:
    glibc - common-2.12.90-21.x86_64
    glibc - 2.21.90-21.i686
    glibc - devel-2.21.90-21.x86_64
    glibc - headers-2.12.90-21.x86_64
    glibc - 2.21.90-21.x86_64
    but i found no changes at all reboot wont work still , neither did startx,..... plz dnt tell me to do a clean install
    leigh123linux Guest
    Re: plz help
    output:
    Try
    su
    yum reinstall glibc*
    Dec 2010
    52
    Re: plz help
    Try
    su
    ok, theres a small problem how to iconnect to internet using text mode, also isnt there another way these files are 136 megabits too much for my connection , but if there is no other ill have to do it
    leigh123linux Guest
    Re: plz help
    ifup eth0
    it's only 24Mb
     Package               Arch           Version             Repository       Size
    Reinstalling:
     glibc                 i686           2.12.90-21          updates         4.3 M
     glibc                 x86_64         2.12.90-21          updates         3.9 M
     glibc-common          x86_64         2.12.90-21          updates          14 M
     glibc-devel           x86_64         2.12.90-21          updates         967 k
     glibc-headers         x86_64         2.12.90-21          updates         597 k
    Transaction Summary
    Reinstall     5 Package(s)
    Total download size: 24 M
    Installed size: 136 M
    Is this ok [y/N]: n
    Exiting on user Command
    Complete!
    Dec 2010
    52
    Re: please help - reboot fails
    ohh srry my mistake,ifup eth0 , didnt work for me p.s(the wireless card light doesnt go on when i am in the text mode for some reason) anyway i am using a mobile broadband so can i still connect using another way. thnx for all ur help leigh
    Aug 2009
    Waldorf, Maryland
    7,345
    try using the rescue CD.
    If the network still won't come up, you can reinstall the library from the
    CD itself, it would be a downgrade. It should get you started.
    Dec 2010
    52
    ok this is weird all i did was boot the cd then i though its a bad idea so i closed rebooted and the system is working fine now , no idea how or y, can any one explain wat happened to me, thnx jpollard, leigh thank you too,
    Aug 2009
    Waldorf, Maryland
    7,345
    For pure speculation...
    A memory resident code page that mapps to the "bad" library... becomes
    corrupted by a transient memory error. Once the page in memory is
    corrupted, it is bad forever, or until it is loaded from disk (being overwritten).
    Since glibc is used by nearly everything, it will remain
    resident nearly forever... The only way to guarantee a reload is to
    reboot. What causes such transient errors... several possiblities:
    1) cosmic ray - yes they happen (I used to admin some Cray XMP/YMP
    where the memory was super reliable... except for an occasional failure
    where the memory would still pass the hardest diagnostics afterwards.)
    2) power fluctuation - in the presence of lightning/minor EMP
    3) memory is weak to start with, and fails occasionally. Usually not
    observed if reboots are done frequently. I had this occur with some
    old 60ns memory.. Worked fine for an hour or so, but then I started
    getting segfaults. When I slowed the memory down to 70 ns, problem
    disappeared.
    This assumes the memory+motherboard does not support parity checking or ECC logic.
    Parity memory can detect single bit errors, but miss double bit errors,
    and cannot correct anything.
    ECC can correct single bit errors, and detect double bit errors; but a
    triple bit error won't be caught.
    Reboot Fails F12 Upgrade
    By JValeck in forum Installation, Upgrades and Live Media
    Last Post: 19th February 2010, 11:27 PM
  2. Reboot Fails after suspend
    By jky92 in forum Using Fedora
    Last Post: 26th May 2008, 07:12 PM
  3. fc7 initial reboot fails
    By hubiedo in forum Installation, Upgrades and Live Media
    Last Post: 3rd February 2008, 01:27 PM
  4. Why WPA always fails on reboot unless...
    By Gandurash in forum Servers & Networking
    Last Post: 13th December 2007, 07:38 PM
  5. Reboot, Shuting Down, Log Off Fails
    By JamSession in forum Using Fedora
    Last Post: 23rd June 2006, 11:09 PM
