Help install wireless driver without Internet connection
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Dec 2010
    Salem, India
    15
    I don't have a wired connection to internet. I have only a wifi connection. Is there any I could download a driver and install or myself in fedora 14??
    Jun 2006
    7,544
    Re: Help install wireless driver without Internet connection
    Quote Originally Posted by aronnirmal
    Probably so. Start by identifying the wireless adapter's chipset. If it's using the PCI bus, this may do it...
    lspci
    If it is a USB device, this may give some useful information...
    lsusb
    From that, maybe someone will know what you need to download, transfer to the wireless computer, and install.
    Dec 2010
    Salem, India
    15
    I am having the following wifi chipset can somebody tell me what are the things I've to download
    Broadcom Corporation BCM4312 802.11b/g LP-PHY (rev 01)
    Jun 2006
    7,544
    That Broadcom chipset is known to work with the Broadcom 802.11 STA Linux driver. The binary version available from RPM Fusion is commonly used and easy to install. I recommend that you do that. Even though the computer does not have a wired connection, you still can install the driver in an offline situation. To do that, return and report the running kernel...
    uname -r
    From that, I or someone will tell you which files to download, transfer to the wireless computer, and manually install.
    Dec 2010
    Salem, India
    15
    When I enter command this is the output I'm getting
    2.6.35.6-45.fc14.i686
    Jun 2006
    7,544
    On another computer, navigate back to this page and download these three files...Somehow transfer them to a directory of the Fedora system on the wireless computer. Open a terminal in Fedora. Change directories in the terminal to the location of the three files. Install them all at once with these terminal commands...
    su
    rpm -ivh *.rpm
    After that runs successfully, reboot and check the NetworkManager panel applet icon for available networks and connect.
    If all of that worked, then good. But you still need to install the RPM Fusion repos before you attempt to update the system...But if it's still not working, then return here with the bad news. There are some things to try for that.
    Dec 2010
    Salem, India
    15
    Thank you very much Now I'm able to connect to wireless networks. I posting this reply from my fedora machine
    Apr 2011
    Hi Stoat,
    I am having similar problem about installing wireless driver but, don't have wired connection.
    Broadcom Corporation BCM4322 802.11a/b/g/n wireless LAN Controler (rev 01)
    When I enter command (uname -r).this is the output I'm getting
    2.6.32-28-Generic
    Would you please put some instruction or suggestion for me, so that i can download something to make my wireless work?
    I tried to download those three files that you mentioned above and tried to install it.
    It replied me (Package rpm has no instalation candidate).
    Last edited by kamol00; 21st April 2011 at 05:36 PM. Reason: adding more information
    Apr 2011
    3
    Hi guys!
    I have the same exact problem with my wireless configuration. I am running Fedora14 under a Macbook and I am finding it difficult to configure it.
    My wifi chipset is a Broadcom Corporation BCM4321 802.11a/b/g/n (rev 03). My output is 2.6.35.6-45.fc14.i686
    Since it is quite similar to the one posted above I also tried downloading those 3 files. When I am about to install the Broadcom package, terminal prints out the following line:
    error: Failed dependencies:
    wl.kmod >= 5.60.48.36 is needed by broadcom-wl-5.60.48.36-1.fc13.noarch
    Similar errors with the kmod packages :S
    EDIT:
    I've finally done it, but there was no freaking way of installing it without ethernet. I've cheated : )
    Jun 2006
    7,544
    Quote Originally Posted by celeste
    ...there was no freaking way of installing it without ethernet.
    When you're attempting to manually install those three inter-dependent rpms, you must install them all at once in the same yum or rpm command.
    Like this...
    yum localinstall package1 package2 package3
    Or this...
    rpm -ivh package1 package2 package3
    Or, change directories in the terminal to the folder with the three rpms and then this...
    yum localinstall *.rpm
    Or this...
    rpm -ivh *.rpm
    Jun 2006
    7,544
    Quote Originally Posted by kamol00
    2.6.32-28-Generic
    That's not an output I would expect for a Fedora kernel. That looks like an Ubuntu or Debian kernel version to me.
    Apr 2011
    3
    Thank you for the feedback stoat I will take that into account for the next time.
    I am newbie in Linux so I am gonna make a pretty stupid question... How do I know when rpm are inter-dependent? Because of the failed dependencies output? If that output happens to me again do I have to automatically guess that I have to install them at once?
    Jun 2006
    7,544
    Yes, but that situation is sort of rare IMO. It comes up mostly with these RPM Fusion kmods, especially the wireless packages. Generally, you should use yum or one of its front-ends instead of the rpm command. The rpm command checks for dependencies but will not handle them. Yum will take care of all of that.
    May 2011
    Hello stoat + anyone who can help
    I installed Fedora 14 (64bit) on my compaq presario V3000 laptop.
    I was looking to update my laptop wireless configuration and found your solution. Thanks for that. However I forgot to install the rpm fusion repos and updated the system without it.
    Now my wireless doesnt work in my updated Fedora 14 and the same rpm installs which I did doesnt seem to work for this updated version.
    uname -r gave me this output: 2.6.35.12-90.fc14.x86_64
    Also, I do not have an ethernet connection either. I presently download what I need from my windows machine and transfer the files to the linux laptop.
    if you can help me with some leads I would greatly appreciate it.
    Maryland, US
    13,481
    149 Post(s)
    Here's an easy way to see the dependencies on a package:
    yum deplist packagename
    for example to see the dependencies for firefox
    yum deplist firefox
    the list tends to be repetitive and redundant so a trick to make it more brief would be to sort the output and run uniq on it (uniq, like it sounds, means "unique", it only allows a particular line of text to occur once in order):
    yum deplist firefox | sort | uniq
  1. Configuring Wireless Internet Connection
    By Kryptos in forum Servers & Networking
    Last Post: 10th March 2008, 10:29 PM
  2. WPA and internet connection sharing via wireless
    By hellfire[bg] in forum Servers & Networking
    Last Post: 13th November 2007, 10:07 AM
  3. how do I install a wireless card without an internet connection?
    By xowenx in forum Installation, Upgrades and Live Media
    Last Post: 4th April 2007, 03:55 PM
  4. wireless internet connection
    By zhiping_mei in forum Hardware
    Last Post: 27th July 2005, 11:20 AM
  5. Replies: 6
    Last Post: 18th July 2005, 05:50 AM
[[template footer(Guest)]]
