20th October 2004, 11:11 PM
USB to serial adapter problem FC3 T3
Just installed/testing FC3 T3 on HP nx7000 NoteBook.
Trying to make my USB to serial adapter work>
so far so food after as I attach the device ....
usb 1-4.3.4: new full speed USB device using address 7
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303
pl2303 1-4.3.4:1.0: PL-2303 converter detected
usb 1-4.3.4: PL-2303 converter now attached to ttyUSB0
usbcore: registered new driver pl2303
but any try to send characters to /dev/ttyUSB0 leeds to following:
PL-2303 ttyUSB0: pl2303_open - failed submitting interrupt urb, error -28
PL-2303 ttyUSB0: PL-2303 converter now disconnected from ttyUSB0
Pls advice
Thanks zstoupa
22nd October 2004, 06:04 PM
I'll test this in a little bit. I'm using the same device (PL2303) on a ZD7000. I upgraded from FC2 and I've got a few problems to sort through first.
24th October 2004, 02:22 AM
Linus et al have released 1.6.10-rc1. I notice that there are a large number of usb_serial, PL2303 and usb_storage changes in it.
http://linuxtoday.com/news_story.php...3-009-26-NW-KN
6th November 2004, 09:27 AM
I am having the same problem with FC2 with an upgraded kernel 2.6.9 (with nitro1 patches).
It worked with previous kernel releases with the same Fedora release, seems to be a kernel-related problem.
6th November 2004, 06:38 PM
USB Serial works fine on my machine now.
I am running FC3rc5 with kernel 2.6.9-1.667.
This setup (and better) will be released to the public early next week (Nov 8th) as the live Fedora Core 3 install.
I am using a PL2303 device. USB recognizes it as a hot plug and everything. Even hardware handshaking works.
By net_boy in forum Using Fedora
Last Post: 1st December 2008, 10:34 AM
By tunerX in forum Hardware
Last Post: 2nd October 2008, 06:43 AM
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
[[template footer(Guest)]]
