[FC12] thunderbird-lightning doesn't show up in thunderbird interface
Results 1 to 15 of 15
    May 2008
    amsterdam
    40
    I have thunderbird-lightning rpm installed but it doesnt show up in thunderbird..
    in fc11 with thunderbird 2 it was on the left bottom of the screen i think.
    i checked all the settings tabs but i can't find any reference to ligtning.
    so.. is this a bug or is there something i have to do to see it?
    for now i'm using the standalone app sunbird but i really like to have the intergrated ligtning back in thunderbird.
    any suggestions?
    I also tried the lightning plugin from the plugins tab but it complains it's not compatible with gcc3 or something so i guess that's why there is a rpm package.
    Jan 2010
    7,356
    I'll have to doublecheck, but I think it's under tools/calendar or something like that. There should be something in the menu, somewhere, for calendar.
    May 2008
    amsterdam
    40
    nope.. nowhere any references to calendar.
    i checked all the menu's
    Jan 2010
    7,356
    I believe it's integrated in the Events and Tasks menu.
    Jun 2009
    Top of the World
    115
    Usually when thunderbird releases a new version, lightning requires an update as well to be compatible. Install the "latest lightning nightly builds" extension. This will place a nice little update option in the thunderbird Help menu. Only problem is the latest lightning update is not yet compatible with thunderbird 3.0.2. Give them a little time, you shouldn't lose any of your stuff.
    Dell lappy: 4x Intel Core i7-4600U CPU @ 2.1 GHz--fc23.x86_64
    Registered Linux User #499709
    May 2008
    amsterdam
    40
    hmmz..
    strange that the fedora maintainers include a thunderbird-lightning rpm that has never worked...
    Sep 2008
    Bucharest
    34
    31
    i'm surprised you say that. my thunderbird-lightning always worked flawlessly. and by the way have you tried F11 or View->Today Pane->View Today Pane?
    May 2008
    amsterdam
    40
    coincidently i just noticed updated packages for thunderbird & thunderbird-lightning
    just installed them and restarted firfox but alas.. no calendar still..
    F11?
    does nothing.. what is it supposed to do?
    under View i don't have any "Today Pane" entry.
    are we talking the same version here?
    mine is: 3.0.3 (default fc12 install)
    #rpm -qi thunderbird
    Name : thunderbird Relocations: (not relocatable)
    Version : 3.0.3 Vendor: Fedora Project
    Release : 1.fc12 Build Date: Mon 01 Mar 2010 05:49:04 PM CET
    Install Date: Wed 03 Mar 2010 12:16:45 PM CET Build Host: xb-01.phx2.fedoraproject.org
    Group : Applications/Internet Source RPM: thunderbird-3.0.3-1.fc12.src.rpm
    Size : 52325615 License: MPLv1.1 or GPLv2+ or LGPLv2+
    Signature : RSA/8, Tue 02 Mar 2010 04:16:33 AM CET, Key ID 9d1cc34857bbccba
    Packager : Fedora Project
    URL : http://www.mozilla.org/projects/thunderbird/
    Summary : Mozilla Thunderbird mail/newsgroup client
    Description :
    Mozilla Thunderbird is a standalone mail and newsgroup client
    #rpm -qi thunderbird-lightning
    Name : thunderbird-lightning Relocations: (not relocatable)
    Version : 1.0 Vendor: Fedora Project
    Release : 0.20.20090916hg.fc12 Build Date: Mon 01 Mar 2010 06:11:35 PM CET
    Install Date: Wed 03 Mar 2010 12:16:49 PM CET Build Host: x86-04.phx2.fedoraproject.org
    Group : Applications/Productivity Source RPM: sunbird-1.0-0.20.20090916hg.fc12.src.rpm
    Size : 2636976 License: MPLv1.1 or GPLv2+ or LGPLv2+
    Signature : RSA/8, Tue 02 Mar 2010 12:39:35 PM CET, Key ID 9d1cc34857bbccba
    URL : http://www.mozilla.org/projects/calendar/sunbird/
    Summary : The calendar extension to Thunderbird
    Description :
    Lightning brings the Sunbird calendar to the popular email client,
    Mozilla Thunderbird. Since it's an extension, Lightning is tightly
    integrated with Thunderbird, allowing it to easily perform email-related
    calendaring tasks
    Sep 2008
    Bucharest
    34
    31
    F11 shows/hides the calendar panel from the right side of the screen. If you don't have View/Today Pane submenu than is definitely something wrong at your end. oh, and of course i was talking about the up to date version. i thought that goes without saying.
    my output is a little different:
    $ rpm -qi thunderbird
    Release : 1.fc12 Build Date: Mon 01 Mar 2010 06:49:42 PM EET
    Install Date: Wed 03 Mar 2010 12:30:15 PM EET Build Host: x86-06.phx2.fedoraproject.org
    Size : 51292639 License: MPLv1.1 or GPLv2+ or LGPLv2+
    Signature : RSA/8, Tue 02 Mar 2010 01:33:55 PM EET, Key ID 9d1cc34857bbccba
    Description :
    Mozilla Thunderbird is a standalone mail and newsgroup client.
    $ rpm -qi thunderbird-lightning
    Release : 0.20.20090916hg.fc12 Build Date: Mon 01 Mar 2010 07:16:31 PM EET
    Install Date: Wed 03 Mar 2010 12:31:06 PM EET Build Host: x86-04.phx2.fedoraproject.org
    Size : 2638601 License: MPLv1.1 or GPLv2+ or LGPLv2+
    Signature : RSA/8, Tue 02 Mar 2010 04:54:44 AM EET, Key ID 9d1cc34857bbccba
    Description :
    calendaring tasks.
    May 2008
    amsterdam
    40
    are you running x86_64 or ix86?
    Sep 2008
    Bucharest
    34
    31
    i686 .........
    Jan 2010
    7,356
    Lightning doesn't show up as a separate thing now. There is an Events and Task on the top menu bar. I had always thought that was the new look for Tbird integrated with lightning.
    I see that Fedora also, as they do with firefox, includes 60 plus language packs, whether you ask
    for them or not.
    Jun 2009
    Top of the World
    115
    Haters never win
    Fedora bashing isn't going to solve problems.
    Go here, click "download", install following on screen instructions even if you think you already have it.
    https://addons.mozilla.org/en-US/thunderbird/addon/2313
    For more info, read this thread:
    http://groups.google.com/group/mozil...e6117?lnk=raot
    Dec 2010
    5
    Re: Haters never win
    Quote Originally Posted by R3353
    I am new to Fedora, and giving Fedora 14 a try. I had the same problem, trying to install Thunderbird-lightning through the repositories, and it wasn't showing up anywhere.
    Installing it through your method worked for me, thanks.
    Jun 2009
    Top of the World
    115
    Re: [FC12] thunderbird-lightning doesn't show up in thunderbird interface
    no problem. enjoy your learning process.
  1. Replies: 0
    Last Post: 18th December 2009, 01:09 AM
  2. Thunderbird 3.0b3 and lightning
    By janvlug in forum Using Fedora
    Last Post: 25th November 2009, 07:45 PM
  3. Thunderbird 3.0 and Lightning add-on
    By itmike in forum Using Fedora
    Last Post: 19th October 2009, 03:25 PM
  4. Thunderbird 3.0b2 and lightning
    By theWayner in forum Using Fedora
    Last Post: 10th June 2009, 10:48 PM
  5. Replies: 3
    Last Post: 11th January 2008, 10:23 AM
