Problem at Starting UT2004 and AA
    Viperb0y Guest
    Ive got a Radeon 9500 Pro / 9700 with the newest Drivers installed at FC2
    When i try to start UT2004 or AA i get this error:
    [viper@gloria viper]$ sh ut2004
    WARNING: ALC_EXT_capture is subject to change!
    Xlib:  extension "XiG-SUNDRY-NONSTANDARD" missing on display ":0.0".
    Signal: SIGSEGV [segmentation fault]
    Aborting.
    Crash information will be saved to your logfile.
    Here are Infos about DRI:
    [viper@gloria viper]$ glxinfo | grep render
    direct rendering: Yes
        GLX_ATI_render_texture
    OpenGL renderer string: RADEON 9500 Pro Generic
    Google only tells my persons with the same problem, but no solution!
    Please help me! Iam going to a Lan-Party tomorrow and i need this to fix
    P.S. Sorry for my bad english!
    715
    I don't know the answer to your problem, but you may want to consider posting at this forum. It has been helpful in the past for ut2k4 issues on Linux for me.
    http://www.linux-gamers.net/modules/...m.php?forum=15
    Viperb0y Guest
    I posted it into the Forum but nobody helps me
    Can realy nobody help me? Its anoying to switch to Wintendo!
  1. UT2004 Run Problem
    By Polantaris in forum Using Fedora
    Last Post: 6th February 2007, 06:51 PM
  2. ut2004 run problem
    By fnshman in forum Gamers' Lounge
    Last Post: 4th October 2006, 12:45 AM
  3. Problem installing UT2004 server
    By bupkus in forum Using Fedora
    Last Post: 4th October 2005, 05:15 AM
  4. UT2004 problem
    By davidswe in forum Using Fedora
    Last Post: 4th March 2005, 02:28 AM
  5. Sound problem in ut2004
    By jpmills in forum Using Fedora
    Last Post: 1st January 2005, 11:15 AM
