    Apr 2008
    Sweden
    33
    41
    Question vpn connection problem
    I thought configuring a vpn would be a piece of cake, but it seems I'm missing something.
    I'm attempting to create a vpn (pptp) using the networkmanager (0.7.1). I enter the gateway (I assume thats the server I'm trying to connect to) and my login information. What is the NT Domain?
    When I try to connect it only tells me after a while that it failed to do so. How can I find the information on what went wrong in the process?
    Apr 2008
    Sweden
    33
    41
    After some more digging I found this in with "mousepad /var/log/messages|grep -i ppp"
    Sep 21 15:40:16 localhost pptp[2361]: nm-pptp-service-2352 warn[open_inetsockptp_callmgr.c:329]: connect: Connection timed out
    Sep 21 15:40:16 localhost pptp[2361]: nm-pptp-service-2352 fatal[callmgr_mainptp_callmgr.c:127]: Could not open control connection to 130.235.72.140
    Sep 21 15:42:34 localhost NetworkManager: <info> Starting VPN service 'org.freedesktop.NetworkManager.pptp'...
    Sep 21 15:42:34 localhost NetworkManager: <info> VPN service 'org.freedesktop.NetworkManager.pptp' started (org.freedesktop.NetworkManager.pptp), PID 2609
    Sep 21 15:42:34 localhost NetworkManager: <info> VPN service 'org.freedesktop.NetworkManager.pptp' just appeared, activating connections
    Sep 21 15:42:34 localhost pppd[2612]: Warning: can't open options file /root/.ppprc: Permission denied
    Sep 21 15:42:34 localhost pppd[2612]: Plugin /usr/lib/pppd/2.4.4/nm-pptp-pppd-plugin.so loaded.
    Sep 21 15:42:34 localhost pppd[2612]: pppd 2.4.4 started by root, uid 0
    Sep 21 15:42:34 localhost pptp[2613]: nm-pptp-service-2609 log[mainptp.c:314]: The synchronous pptp option is NOT activated
    Sep 21 15:42:34 localhost NetworkManager: <info> VPN plugin state changed: 3
    Sep 21 15:42:34 localhost NetworkManager: <info> VPN connection 'VPN-anslutning 1' (Connect) reply received.
    Sep 21 15:42:34 localhost pppd[2612]: Using interface ppp0
    Sep 21 15:42:34 localhost pppd[2612]: Connect: ppp0 <--> /dev/pts/0
    Sep 21 15:43:05 localhost pppd[2612]: LCP: timeout sending Config-Requests
    Sep 21 15:43:05 localhost pppd[2612]: Connection terminated.
    Sep 21 15:43:05 localhost NetworkManager: <info> VPN plugin failed: 1
    Sep 21 15:43:05 localhost pppd[2612]: Modem hangup
    Sep 21 15:43:10 localhost pppd[2612]: Exit.
    Sep 21 15:43:10 localhost NetworkManager: <info> VPN plugin failed: 1
    Sep 21 15:43:10 localhost NetworkManager: <info> VPN plugin state changed: 6
    Sep 21 15:43:10 localhost NetworkManager: <info> VPN plugin state change reason: 0
    Sep 21 15:43:10 localhost NetworkManager: <WARN> connection_state_changed(): Could not process the request because no VPN connection was active.
    Sep 21 15:43:10 localhost NetworkManager: <info> Policy set 'System eth0 (telia)' (eth0) as default for routing and DNS.
    Can anyone help me find the problem.
    Sep 2006
    UK, Bucks.
    354
    It appears we have the same problem. Something about a synchronous state and then a failure. My logs are here:
    http://forums.fedoraforum.org/showth...highlight=pptp
    Edit: I found a fix for the issue that I was having at least, check out the thread that I reported my issues in (link above).
    Thinkpad T400 - Smolt Profile || Thinkpad T61 - Smolt Profile || Thinkpad T41p - Smolt Profile.
  1. Net connection problem....
    By venkat3271 in forum Servers & Networking
    Last Post: 20th June 2007, 04:21 PM
  2. Problem with DNS for DSL connection
    By nardinc in forum Servers & Networking
    Last Post: 24th January 2007, 04:07 PM
  3. FC5: Problem Slow PGSQL Connection, SSH connection
    By dunadan67 in forum Servers & Networking
    Last Post: 5th June 2006, 09:42 PM
  4. VNC Connection Problem
    By xgamma in forum Using Fedora
    Last Post: 6th September 2005, 02:48 PM
  5. Problem with 2 DSL connection
    By ssnathan1975 in forum Servers & Networking
    Last Post: 28th July 2005, 06:09 AM
