Directory for USB flash drives
    May 2009
    I'm booting from a USB, but I also have some other documents that I need to view in that same USB...So, where do I go to view my USB's content? Remember, it's the USB I'm booting from...maybe that'll help...
    Thanks
    Jun 2006
    7,544
    Hello jpfalet,
    Try browsing the /media folder. If you don't find anything there, then maybe your documents are in a partition that you will have to mount manually. You should be able to mount ordinary ext3, FAT, and NTFS partitions this simple way...
    su
    mkdir /mnt/temp
    mount /dev/sdxy /mnt/temp
    You change x & y to the drive & partition that you want to mount (e.g., /dev/sda1). Browse for your files in /mnt/temp.
    If your documents are in an LVM physical volume, there's a little more to do. I'm skipping that though because I doubt that you have a second Linux system on that USB drive. If I'm wrong about that and you need that information, then you can see it here...
  1. SDHC, flash drives, etc
    By vorcigernix in forum Hardware & Laptops
    Last Post: 30th January 2009, 03:10 AM
  2. Filesystem of USB Flash drives?
    By guizhou_donkey in forum Hardware & Laptops
    Last Post: 23rd August 2006, 03:55 PM
  3. Can Two Hard Drives Mount to the Same Directory?
    By haywood5179 in forum Hardware & Laptops
    Last Post: 26th March 2005, 01:38 AM
