No / Low Sound Troubles v. RealTek High Definition Audio
    Nov 2006
    512
    No / Low Sound Troubles v. RealTek High Definition Audio (Misidentified Device??)
    Experiencing No Sound Through On-Board Computer Speakers And Barely Audible Sound At Maximum Volume Through Headphone/Line Out.
    Using Fedora 10 2.6.27.12-170.2.5 ... Using All Of The Latest ALSA Support Drivers/Libraries 1.0.19
    Hardware Identified As Intel High Definition ALC883 Audio But Windows (As Well As My Hardware Documentation) Defines Hardware As RealTek High Definition Audio ALC889A
    AlsaMixer shows ALL sliders (including hidden sliders) un-muted and at full volume. (no external volume control
    Sound functions properly, including On-Board speakers using XP with RealTek Audio Codec.
    RealTek Support for this device is a package containing ALSA 1.0.19 Drivers... i compiled the most recent test versions of the alsa-driver but the issue has not been resolved.
    Issue is resident Using Fedora 11 Beta / Fedora 11 Preview / Ubuntu 9.04 Desktop / OpenSuse 11.1
    Nov 2006
    512
    does anyone know how to respecify this device?!
    Feb 2008
    Sydney Australia
    63
    2,585
    If you don't have it already install PulseAudio Volume Control. When you check it you will probably find it is set low. This worked for me on 2 different systems.
    If that doesn't work do a search for similar threads (there are many) as there are other fixes for some audio chips.
    Nov 2006
    512
    Quote Originally Posted by ozjd
    i do already have PulseAudio volume control... and i have checked all the volume sliders.
  1. Low Volume v. Intel High Definition Audio
    By HMSS013 in forum Using Fedora
    Last Post: 28th April 2009, 08:19 PM
  2. Replies: 2
    Last Post: 30th August 2007, 06:24 PM
  3. FC4 Intel High Definition Audio is scratchy
    By bergnj in forum Hardware & Laptops
    Last Post: 5th October 2005, 05:12 PM
  4. Realtek High Definition Audio Soundcard not detected
    By butsam in forum Hardware & Laptops
    Last Post: 15th May 2005, 11:14 PM
