Sound stop working on fedora 9
Results 1 to 11 of 11
    netphilic Guest
    hi,
    I have used following motherborad in my media center PC.
    GIGABYTE GA-MA69GM-S2H AM2
    this mother board has following audio device
    Realtek ALC889A
    Earlier my sound card used to work fine, but not any more now. It is a dual boot machine, windows can recognize the card use it.
    I tried downloading driver code from realtek website still no use.
    realtek-linux-audiopack-5.07
    here are few outputs, please let me know, what is wrong on my PC now.
    ==========alsaconfig============
    UI Says: No supported PnP or PCI card found.
    modinfo: could not open /lib/modules/2.6.27.7-53.fc9.x86_64/kernel/sound/acore/snd.ko: No such file or directory
    which: no dialog in (/usr/lib64/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/lib64/ccache:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
    modinfo: could not find module snd-opl3sa2
    modinfo: could not find module snd-cs4236
    modinfo: could not find module snd-cs4232
    modinfo: could not find module snd-cs4231
    modinfo: could not find module snd-es18xx
    modinfo: could not find module snd-es1688
    modinfo: could not find module snd-sb16
    modinfo: could not find module snd-sb8
    ===========lsmod | grep snd===========
    No output
    ========================================lspci===== ========
    00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge
    00:02.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Graphics Port 0)
    00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
    00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
    00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
    00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
    00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
    00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
    00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
    00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
    00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
    00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia
    00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
    00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
    00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
    00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
    00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
    00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
    01:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7600 GS] (rev a1)
    02:0e.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
    02:0f.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8110SC/8169SC Gigabit Ethernet (rev 10)
    ==========================lspci -vvxxx ==============================
    Subsystem: Giga-byte Technology Unknown device 5000
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
    Latency: 32
    00: 02 10 10 79 06 00 20 22 00 00 00 06 00 20 00 00
    10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 50
    30: 00 00 00 00 c4 00 00 00 00 00 00 00 00 00 00 00
    00:02.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Graphics Port 0) (prog-if 00 [Normal decode])
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 4 bytes
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 0000e000-0000efff
    Memory behind bridge: fa000000-fcffffff
    Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
    PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Capabilities: <access denied>
    Kernel driver in use: pcieport-driver
    Kernel modules: shpchp
    00: 02 10 13 79 07 00 10 00 00 00 04 06 01 00 01 00
    10: 00 00 00 00 00 00 00 00 00 01 01 00 e1 e1 00 00
    20: 00 fa f0 fc 01 d0 f1 df 00 00 00 00 00 00 00 00
    30: 00 00 00 00 50 00 00 00 00 00 00 00 ff 00 08 00
    Subsystem: Giga-byte Technology Unknown device a022
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 32, Cache Line Size: 4 bytes
    Interrupt: pin A routed to IRQ 4
    Region 0: Memory at fe024000 (64-bit, non-prefetchable) [size=16K]
    Kernel modules: snd-hda-intel
    00: 02 10 83 43 06 00 10 04 00 00 03 04 01 20 00 00
    10: 04 40 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
    20: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 22 a0
    30: 00 00 00 00 50 00 00 00 00 00 00 00 04 01 00 00
    Thanks,
    Aug 2007
    48
    226
    Your output reveals a lot. Not all, but a lot.
    My guess is sound was working before this. If this is true, then that means the realtek-linux-audiopack-5.07 changed a few things.
    First verify, oss, alsa, esd, snd, are installed
    could not open /lib/modules/2.6.27.7-53.fc9.x86_64/kernel/sound/acore/snd.ko: No such file or directory....<snip>
    Means the file is not where it's expected to be.
    Check your logs as well.
    netphilic Guest
    Quote Originally Posted by JonathanR
    My soundcard stop working after yum update.
    You are right few files are missing like snk.ko, but it was there for earlier kernel modules
    [root@x-mce modules]# find . -name snd.ko
    ./2.6.26.3-29.fc9.x86_64/kernel/sound/core/snd.ko
    ./2.6.26.5-45.fc9.x86_64/kernel/sound/acore/snd.ko
    ./2.6.25.14-108.fc9.x86_64/kernel/sound/acore/snd.ko
    [root@x-mce modules]# uname -r
    /lib/modules/2.6.27.7-53.fc9.x86_64 doesn't seems to have snk.ko or other modules.
    Aug 2007
    48
    226
    snd.ko belong to alsa. Verify you have alsa.
    netphilic Guest
    Alsa is already there.
    [root@x-mce modules]# rpm -qa |grep alsa
    alsa-plugins-pulseaudio-1.0.16-4.fc9.x86_64
    alsa-lib-devel-1.0.17-2.fc9.x86_64
    alsa-lib-1.0.17-2.fc9.x86_64
    bluez-utils-alsa-3.36-1.fc9.x86_64
    alsa-utils-1.0.17-2.fc9.x86_64
    [root@x-mce modules]#[root@x-mce modules]# aplay -l
    aplay: device_list:207: no soundcards found...
    [root@x-mce modules]# rpm -qa |grep oss
    nss_compat_ossl-0.9.4-1.fc9.x86_64
    [root@x-mce modules]# rpm -qa |grep esd
    [root@x-mce modules]# rpm -qa |grep snd
    libsndfile-1.0.17-6.fc9.x86_64
    [root@x-mce log]# cat /etc/asound.conf
    cat: /etc/asound.conf: No such file or directory
    [root@x-mce log]#
    [root@x-mce events]# lsmod
    Module Size Used by
    bridge 56224 0
    stp 10756 1 bridge
    bnep 22016 2
    rfcomm 43808 4
    l2cap 28544 16 bnep,rfcomm
    bluetooth 60068 5 bnep,rfcomm,l2cap
    sunrpc 191208 3
    ipv6 287528 18
    cpufreq_ondemand 15504 1
    powernow_k8 24836 1
    freq_table 12928 2 cpufreq_ondemand,powernow_k8
    fuse 60992 7
    loop 23692 0
    dm_multipath 23832 0
    scsi_dh 14980 1 dm_multipath
    sr_mod 23732 0
    cdrom 40360 1 sr_mod
    ppdev 15752 0
    pata_acpi 13184 0
    firewire_ohci 30340 0
    r8169 40964 0
    firewire_core 45632 1 firewire_ohci
    floppy 66216 0
    mii 13056 1 r8169
    serio_raw 14084 0
    pcspkr 11008 0
    crc_itu_t 10240 1 firewire_core
    i2c_piix4 18448 0
    k8temp 13056 0
    pata_atiixp 13824 0
    soundcore 14992 0
    i2c_core 29216 1 i2c_piix4
    hwmon 11064 1 k8temp
    ata_generic 14084 0
    parport_pc 34200 0
    parport 42784 2 ppdev,parport_pc
    lirc_mceusb2 21508 1
    lirc_dev 20408 1 lirc_mceusb2
    joydev 19328 0
    sg 40656 0
    dm_snapshot 24648 0
    dm_zero 10240 0
    dm_mirror 25472 0
    dm_log 17796 1 dm_mirror
    dm_mod 61408 10 dm_multipath,dm_snapshot,dm_zero,dm_mirror,dm_log
    ahci 40716 4
    libata 157888 4 pata_acpi,pata_atiixp,ata_generic,ahci
    sd_mod 40488 6
    scsi_mod 153304 5 scsi_dh,sr_mod,sg,libata,sd_mod
    crc_t10dif 10112 1 sd_mod
    ext3 130832 2
    jbd 56616 1 ext3
    mbcache 16004 1 ext3
    uhci_hcd 30752 0
    ohci_hcd 31644 0
    ehci_hcd 41228 0
    [root@x-mce ~]# ls /proc/asound/modules
    ls: cannot access /proc/asound/modules: No such file or directory
    netphilic Guest
    I now booted the box with following kernel version
    no success
    lspci gives only following details. My onboard sound chip is via realtek, why I see ATI audio device.
    Kernel is not able to recognize the device ?
    Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Interrupt: pin ? routed to IRQ 16
    00: 02 10 83 43 02 00 10 04 00 00 03 04 01 20 00 00
    30: 00 00 00 00 50 00 00 00 00 00 00 00 04 00 00 00
    Aug 2007
    48
    226
    Reinstall alsa, and reconfigure your sound card.
    netphilic Guest
    Actually booting into 2.6.26.5-45.fc9.x86_64 fixed the issue.
    As yo mentioned, I just have to run alsaconf again. This time alsaconf recognized following
    - hda-intel ATI Technologies Inc SBx00 Azalia
    - legacy Probe legacy ISA (non-PnP) chips
    [root@sandip-mce ~]# aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: SB [HDA ATI SB], device 0: ALC885 Analog [ALC885 Analog]
    Subdevices: 0/1
    Subdevice #0: subdevice #0
    card 0: SB [HDA ATI SB], device 1: ALC885 Digital [ALC885 Digital]
    Subdevices: 1/1
    I tried to unstall alsa via Yum, Yum was trying to unstall 150 other package, which depends on this. I cancelled the operation.
    How do I reinstall alsa ?
    Now the issue is, when I reboot the system, I again come to same situation i.e. no audio device. I need to run alsaconfig again to get back my audio device.
    Aug 2007
    48
    226
    Quote Originally Posted by netphilic
    Subdevices: 0/1
    Subdevices: 1/1
    Use yum to install smart-gui. With the smart gui, or from the command line, you can reinstall, alsa.
    #smart --gui reinstall alsa*
    That should return something like this
    Installing packages (15):
      alsa-firmware-1.0.19-1.fc10.1@noarch
      alsa-lib-1.0.19-2.fc10@i386
      alsa-lib-1.0.19-2.fc10@x86_64
      alsa-lib-devel-1.0.19-2.fc10@x86_64
      alsa-oss-1.0.17-1.fc10@x86_64
      alsa-oss-libs-1.0.17-1.fc10@x86_64
      alsa-plugins-jack-1.0.18-2.fc10@x86_64
      alsa-plugins-oss-1.0.18-2.fc10@x86_64
      alsa-plugins-upmix-1.0.18-2.fc10@x86_64
      alsa-plugins-usbstream-1.0.18-2.fc10@x86_64
      alsa-plugins-vdownmix-1.0.18-2.fc10@x86_64
      alsa-tools-1.0.19-1.fc10@x86_64
      alsa-tools-firmware-1.0.19-1.fc10@x86_64
      alsa-utils-1.0.19-1.fc10@x86_64
      alsamixergui-0.9.0-0.4.rc1.fc9.2@x86_64
    netphilic Guest
    I installed smart and reinstalled alsa*. Now I can't configure sound card.
    aplay -l doesn't show any sound card.
    Few things I observed compare to your alsa pckages
    1). you are using 1.0.19 and I am using 1.0.17 for fc-9. Looks like 1.0.17 is latest in fc-9 repository. Do you suggest to upgrade to fc-10 ?
    2). I see mine alsa-oss is developer version.
    alsa-oss-devel-1.0.15-0.1.fc9.x86_64
    3). I see that you have alsa-plugins-usbstream package too. I can't this via smart and Yum. Not sure if this pkg can make the difference.
    [root@x-mce ~]# cat /proc/asound/pcm
    [root@x-mce ~]# cat /proc/asound/modules
    [root@x-mce ~]# cat /proc/asound/version
    Advanced Linux Sound Architecture Driver Version 1.0.17-v5.07.
    Compiled on Dec 19 2008 for kernel 2.6.26.5-45.fc9.x86_64 (SMP).
    [root@x-mce ~]# uname -r
    [root@x-mce ~]# rpm -qa |grep alsa
    alsa-plugins-upmix-1.0.16-4.fc9.x86_64
    alsa-plugins-samplerate-1.0.16-4.fc9.x86_64
    alsa-oss-libs-1.0.15-0.1.fc9.x86_64
    alsamixergui-0.9.0-0.4.rc1.fc9.2.x86_64
    alsa-tools-firmware-1.0.17-1.fc9.x86_64
    alsa-plugins-jack-1.0.16-4.fc9.x86_64
    alsa-plugins-oss-1.0.16-4.fc9.x86_64
    alsa-firmware-1.0.17-1.fc9.noarch
    alsa-oss-1.0.15-0.1.fc9.x86_64
    alsa-plugins-vdownmix-1.0.16-4.fc9.x86_64
    alsa-tools-1.0.17-1.fc9.x86_64
    [root@x-mce ~]# aplay -L
    [root@x-mce ~]# aplay -l
    aplay: device_list:215: no soundcards found...
    [root@x-mce ~]# yum search alsa-plugins-usbstream
    Loaded plugins: protectbase, refresh-packagekit
    0 packages excluded due to repository protections
    Warning: No matches found for: alsa-plugins-usbstream
    No Matches found
    [root@x-mce ~]# yum search usbstream
    Warning: No matches found for: usbstream
    No Matches found
    [root@x-mce ~]# smart install alsa-plugins-usbstream
    Loading cache...
    Updating cache... ######################################## [100%]
    error: 'alsa-plugins-usbstream' matches no packages
    Saving cache...
    netphilic Guest
    Forgot to mention that I did run alsaconf and it recognized following card.
    It said that it configured the card successfully however at the end it failed to play the sample .wav file.
  1. Replies: 0
    Last Post: 26th July 2009, 05:58 AM
  2. Replies: 10
    Last Post: 15th December 2008, 02:09 PM
  3. Network and USB stop working after I play a sound
    By kopylov in forum Hardware & Laptops
    Last Post: 13th July 2006, 08:47 PM
  4. Display Stop working
    By Malachai in forum Hardware & Laptops
    Last Post: 6th March 2006, 09:54 PM
  5. ASUS A1 laptop + Fedora 4 = non stop working fan
    By linuxben in forum Hardware & Laptops
    Last Post: 12th August 2005, 12:48 PM
