Results 1 to 10 of 10
    Oct 2007
    149
    Disk Power Management
    Is there any disk power management software in f10? I would like for my hard drives to stop spinning when the computer is idle.
    Sep 2006
    Connellsville, PA, USA
    11,307
    yum install hdparm
    Add the following (for example) to /etc/rc.d/rc.local to give a 5-minute spin-down time-out:
    { hdparm -S120 /dev/sda; hdparm -S120 /dev/sdb; }
    Read: man hdparm for details of syntax for option '-S' (spin-down time-out).
    I'll have an updated F10 hdparm package (9.5=current) shortly, since this package seems to be low-priority in Fedora Project.
    V
    Sep 2006
    11,307
    Here's the F9 hdparm-8.9-1.fc9.i386 RPM for x86 that I've been using for both F9 and F10: http://www.4shared.com/file/51747854...icroni386.html.
    It works fine in F10 here, and it's more up-to-date than the available Fedora=8.6. Not GPG-signed. No guarantees/warranties of any kind, of course. But it works just fine here.
    V
    EDIT: OOPS! I knew I had hdparm-9.3-1.fc9.i386 laying around here somewhere: hdparm-9.3-1.fc9.i386.rpm
    Nov 2006
    51
    528
    Quote Originally Posted by vonedaddy
    That's hard on your hard drives and saves almost no power. If it's noise then better to just box them up in a silencer.
    Sep 2006
    11,307
    Actually, I agree with hephasteus: based on everything I've read, HDD spin-up is at the top of the list for HDD wear-and-tear - much like starting a car. If you want to use hdparm to set HDD spin-down, that's fine, if you expect the HDD(s) to stay out-of-use for a long period of time. Otherwise, it's better mechanically to just let them spin away.
    V
    Nov 2008
    827
    I don't recommend boxing up a hard drive in a silencer for two reasons:
    a) it keeps the drive from enough fresh air to cool it properly. With the newer drives on the market that run faster and thus hotter it is not a good idea to place it in a sealed container.
    b) it's cheaper to purchase from your local hardware store a set of rubber washers. Remove the hard drive from your computer case and then while putting it back in use the washers with your hard drive mounting screws. You will be amazed at how quiet things become. Total cost: < $1
    I too agree with hephasteus' and Hlingler' contention that HD spin-up will dramatically reduce the life span of your drive. Better to just let it run constantly. If you are concerned about your carbon footprint as regards this then you should consider getting a drive a) spins at a lower speed (e.g. 5400rpm) and b) has a large disk cache (e.g. >= 8Mb).
    Oct 2007
    149
    Well neither being green or the sound is a concern of mine. Sometimes the drive does not get accessed for days at a time. Its my second box and I only us it for some experimenting and scripting. So it may sit idle for a day or two at a time. I just thought it would be nice to have the drives spin down a bit, maybe after 3 hours of idle time.
    One more note is that I often use this box from remote work locations. So its not an option to shut the machine down because with my luck it will be down when I am out of town and need to access it.
    Also, is there a similar utility with a graphical interface??
    Sep 2006
    11,307
    In that case: go with hdparm as described in Posts #2-3 above. Set the spin-down time as desired, as outlined in man hdparm.
    V
    Nov 2008
    827
    [QUOTE=vonedaddy;1135028]One more note is that I often use this box from remote work locations. So its not an option to shut the machine down because with my luck it will be down when I am out of town and need to access it.
    Isn't that always the way. Cops, tools and an ssh connection... never there when you need one. :-)
    I've never seen one before but that obviously doesn't mean there isn't one out there somewhere.
    Sep 2006
    11,307
    Not that I know of. There was at one time, many years ago (http://sourceforge.net/projects/drivetweak/), but the code is so stale it's dangerous. Would not compile here.
    V
  1. F11 is ignoring disk power management configuration, why?
    By mavo in forum Hardware & Laptops
    Last Post: 4th August 2009, 07:48 PM
  2. Power management in FC4
    By y_farkash in forum Using Fedora
    Last Post: 3rd April 2008, 12:06 PM
  3. FC 4, Software-RAID and IDE Disk power management
    By akbhargava in forum Using Fedora
    Last Post: 2nd August 2005, 04:12 AM
  4. fc3 power management
    By armen in forum Hardware & Laptops
    Last Post: 22nd March 2005, 10:10 AM
