Gdesklets problem - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Dec 2003
    Vancouver, BC
    167
    Not sure if anyone has solved this, but you can start gdesklets without tray icon:
    gdesklets --no-tray-icon
    Then, just use gdesklets from Accessories. It works for me.
    Apr 2005
    344
    Quote Originally Posted by asun
    Same problem as the others.
    The above got it working for me.
    May 2004
    42
    Yep! This workaround also works for me... I presume the fault must be down to the tray icon module for the programme??
    Well done asun! and thanks for your input...
    PC: Acer Aspire 1520 Laptop
    CPU: AMD Athlon 64 3000+ (1.8GHz)
    Video: NVidia Geforce FX Go5700, 15.4" (1280x800) WXGA TFT LCD
    OS: FEDORA Release 9 (Sulphur), Kernel Linux 2.6.27.21-78.2.41.fc9.x86_64, GNOME 2.22.3 + Windows XP SP3
    Public UUID: pub_40e07fd2-6f54-4793-a632-bc5f3678ec24
    Linux Registered User: #392144
  1. gdesklets problem
    By Ric@rdo in forum Using Fedora
    Last Post: 18th June 2008, 11:09 PM
  2. gdesklets problem
    By ToolNIN420 in forum Using Fedora
    Last Post: 20th September 2006, 04:21 AM
  3. Problem with gdesklets
    By Benz in forum Using Fedora
    Last Post: 23rd August 2005, 10:31 PM
  4. gdesklets problem
    By jackuto in forum Using Fedora
    Last Post: 4th April 2005, 07:48 AM
  5. Problem with gDesklets
    By DXT in forum Using Fedora
    Last Post: 18th November 2004, 10:41 AM
