How do I enable 'tap to click' on mousepad? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    Sep 2007
    23
    After doing all the stuff on this thread I still cant get mine to work. Ive installed the synaptics driver and the config tool and I get the chfconfig needs to be set to true and it still dosent work. Touchpad mouse will move but will not click on tap nor the actual click buttons will not work.
    Section "ServerLayout"
    Identifier "single head configuration"
    Screen 0 "Screen0" 0 0
    InputDevice "Keyboard0" "CoreKeyboard"
    InputDevice "Synaptics"
    EndSection
    #Another section for Touchpad
    Section "InputDevice"
    Identifier "Synaptics"
    Driver "Synaptics"
    Option "SendCoreEvents"
    Option "Protocol" "auto-dev"
    Option "TapButton1" "1"
    Option "TapButton2" "2"
    Option "TapButton3" "3"
    Option "SHMConfig" "true"
    EndSection
    UK
    4,426
    Hello IronFox
    If you've done those and your touchpad still doesn't work it's probable that your touchpad is not synaptics but an Alps Glidepoint.
    Those need some extra configuration.
    I got mine to work by adding the following:
    Identifier "Default Layout"
    InputDevice "Synaptics" "CorePointer"
    EndSection
    Driver "synaptics"
    Option "Device" "/dev/input/mice"
    Option "Emulate3Buttons" "yes"
    Option "LeftEdge" "120"
    Option "RightEdge" "920"
    Option "TopEdge" "120"
    Option "BottomEdge" "680"
    Option "FingerLow" "14"
    Option "FingerHigh" "15"
    Option "MaxTapMove" "110"
    Option "VertScrollDelta" "20"
    Option "HorizScrollDelta" "20"
    Option "MinSpeed" "0.4"
    Option "MaxSpeed" "0.99"
    Option "AccelFactor" "0.035"
    Option "MinTapTime" "110"
    Option "MaxTapTime" "350"
    Option "ClickTime" "0"
    EndSection
    Some of the "Section "ServerLayout"" you will probably already have.
    control pointer movement, and:
    control tapping. This final section controls double tapping and by extension "tap to drag"
    Give it a try and post back if you have any questions.
    Jun 2006
    Germany
    30
    57
    I've an Dell Vostro 1310 with Alps Glidepoint and configured it with hal. Here is an explanation about this problem: http://who-t.blogspot.com/2008/07/in...n-nutshell.htm . if you put this file into /etc/hal/fdi/10-synaptics.fdi and tweak it a little bit your touchpad should work after a reboot.
    c/h<?xml version="1.0" encoding="ISO-8859-1"?>
    <deviceinfo version="0.2">
      <device>
        <match key="info.capabilities" contains="input.touchpad">
          <match key="info.product" contains="Synaptics TouchPad">
    	<merge key="input.x11_driver" type="string">synaptics</merge>
    	<merge key="input.x11_options.Emulate3Buttons" type="string">yes</merge>
    	<merge key="input.x11_options.LockedDrags" type="string">yes</merge>
    	<merge key="input.x11_options.PalmDetect" type="string">yes</merge>
    	<merge key="input.x11_options.TapButton1" type="string">1</merge>
    	<merge key="input.x11_options.SHMConfig" type="string">1</merge>
          </match>
          <match key="info.product" contains="AlpsPS/2 ALPS">
    	<merge key="input.x11_options.SHMConfig" type="string">true</merge>
    	<merge key="input.x11_options.RightEdge" type="string">900</merge>
    	<merge key="input.x11_options.LeftEdge" type="string">0</merge>
    	<merge key="input.x11_options.TopEdge" type="string">0</merge>
    	<merge key="input.x11_options.BottomEdge" type="string">660</merge>
    	<merge key="input.x11_options.VertScrollDelta" type="string">13</merge>
    	<merge key="input.x11_options.HorizScrollDelta" type="string">20</merge>
    	<merge key="input.x11_options.MaxSpeed" type="string">0.72</merge>
    	<merge key="input.x11_options.MinSpeed" type="string">0.76</merge>
    	<merge key="input.x11_options.AccelFactor" type="string">0.181</merge>
    	<merge key="input.x11_options.RBCornerButton" type="string">2</merge>
    	<merge key="input.x11_options.ClickTime" type="string">500</merge>
    	<merge key="input.x11_options.PalmDetect" type="string">off</merge>
          </match>
        </match>
      </device>
    </deviceinfo>
  4. #19
    Sep 2007
    23
    nope, mine is a synaptics.
    Holly cow, got it working!
    Xorg configuration created by livna-config-display
    EndSection
    Driver "synaptics"
    EndSection
  5. #20
    Aug 2006
    Rosarito, Mexico
    36
    77
    Thumbs up
    Quote Originally Posted by dejan.kitic
    This is how it should look like:
    PHP Code:
        InputDevice
    InputDevice    "TouchPad" "CorePointer"
    EndSection
    Identifier  "Touchpad"
    Driver      "synaptics"
    Option      "SHMConfig" "on"
    EndSection
    Also take a look at this for more details:
    http://gentoo-wiki.com/HARDWARE_Synaptics_Touchpad
    Cheers, D
    yup thanks it work for me, in my thinkpad r51
  6. #21
    Aug 2007
    Brasil
    471
    Guys, i have changed my xorg.conf to enable "tap to click" and increase the speed wich was very slow.
    But after i suspend the computer, when i turn it back on, my tap to click is gone and my speed is back to slowness.
    Anybody got similar issue? Any ideas how to fix it?
  7. #22
    May 2008
    34
    if driver is synaptics use the rpm i attached to the post in this thread, just scroll back down the posts.
  8. #23
    Aug 2007
    Brasil
    471
    Ok now the taping works with that driver but the speed is still slow =o
    That is weird, i think it should work either all or none
    Any suggestions?
  9. #24
    May 2008
    34
    yum install gsynaptics and adjust the speed.
  10. #25
    Aug 2007
    Brasil
    471
    But the speed is perfect, until i suspend the laptop.
    The speed is adjusted already in xorg.conf.
    So when i'm back from suspend the speed is really low.
    I tried gsynaptic anyway, but found it quite useless to me. The changes don't seem to have effect.
    And also, coming back from suspend and having to open gsynaptic to re-adjust speed each time is not a solution..
  1. Needing left-click to open files upon single-click
    By theAdmiral in forum Hardware & Laptops
    Last Post: 30th October 2009, 03:55 AM
  2. Click "Enable Desktop Effects" = log out
    By tdcrooks in forum Using Fedora
    Last Post: 14th September 2009, 06:19 AM
  3. Mousepad, tap doesn't work
    By billgoldberg in forum Using Fedora
    Last Post: 11th June 2009, 04:00 PM
  4. Mousepad click
    By zlx in forum Using Fedora
    Last Post: 30th June 2008, 03:43 AM
