Rawhide Yum/Python problem
    tuna Guest
    Hi everyone
    I wanted to test Rawhide on one of my computers, and after updating some programs such as yum and python yum is not able to work. When I run yum I get the following error:
    [root@localhost ~]# yum
    There was a problem importing one of the Python modules
    required to run yum. The error leading to this problem was:
    /usr/lib/python2.5/site-packages/_sqlitecache.so: undefined symbol: g_assertion_message_expr
    Please install a package which provides this module, or
    verify that the module is installed correctly.
    It's possible that the above module doesn't match the
    current version of Python, which is:
    2.5.1 (r251:54863, Jan 7 2008, 12:52:59)
    [GCC 4.1.2 20071124 (Red Hat 4.1.2-36)]
    If you cannot solve this problem yourself, please go to
    the yum faq at:
    http://wiki.linux.duke.edu/YumFaq
    Anyone have any idea how to fix this?
    sooty Guest
    Well Tuna,
    I don't know if you have fixed the problem by now, but anyway seems there are many that face the same obstacle, so:
    go to
    1.http://rpm.pbone.net/index.php3/stat...m.html#content
    and download the rpm (i assume you are up to date and use fc8(there are other packages there just try))
    2.open it with archiver find and extract _sqlitecache.so
    3. use the command (from the extraction point) #cp _sqlitecache.so /usr/lib/python2.5/site-packages/_sqlitecache.so
    4...
    tuna Guest
    Thanks, this works!
  1. rawhide upgrade: yum audit-libs-python problem
    By arun_maurya in forum Alpha, Beta & Snapshots Discussions (Fedora 11 Only)
    Last Post: 25th March 2009, 10:31 AM
  2. Python, IDLE, Python-tools Gnome.
    By Deonis in forum Using Fedora
    Last Post: 12th March 2009, 03:44 AM
  3. Yum Python error in rawhide
    By virshu in forum Using Fedora
    Last Post: 1st December 2008, 07:34 PM
  4. python and python-irclib problem
    By LostSon in forum Programming & Packaging
    Last Post: 7th March 2008, 12:12 AM
  5. Replies: 0
    Last Post: 15th September 2005, 05:53 PM
