Results 1 to 15 of 27
    RyRy Guest
    Angry Acer Aspire 3630 Wireless Communication Problems
    I have recently installed Fedora 7 on my Acer Aspire 3630 laptop only to find 'Ah! No wireless drivers for a broadcom wireless adapter' As I use my wireless when i use my laptop this has caused a problem because I hate having wires going across the floor.
    Any help in getting my broadcom drivers going for a wireless adapter would be greatly appreciated.
    Thank you
    Aug 2007
    London Postbox (the red one)
    52
    3,868
    Hello this is one way if you have a broadcom 43xxx
    su -
    wget http://downloads.openwrt.org/sources...0.53.0.tar.bz2
    tar xvf broadcom-wl-4.80.53.0.tar.bz2
    cd broadcom*
    cd kmod
    /usr/bin/bcm43xx-fwcutter -w /lib/firmware wl_apsta.o
    or there is ndiswrapper, and there is lots in here about that
    RyRy Guest
    Nu-uh,
    Still isn't working, Its not appearing in the network area, and the drivers for broadcom are the wrong set so I don't know, I'v tryed ndiswrapper and stuff still doesn't work.
    Any more ideas?
    Thank you
    -Ry
    iptv66 Guest
    Buy a cheap (Fedora compatible) USB wireless dongle until you can find working drivers for the broadcom device.
    Jul 2007
    Indiana USA
    1,715
    first
    /sbin/lspci | grep Broadcom
    so we know what card you even have?
    also do some reading on ndiswrapper it uses windoze drivers to get your wireless going.
    my card is a Broadcom Dell 1390 Mini-PCI, I use ndiswrapper with the windows drivers there are plenty of how-to's around here. What have you tried?
    Also I think DangerMouse missed a little something
    su -
    wget http://downloads.openwrt.org/sources/broadcom-wl-4.80.53.0.tar.bz2
    tar -xvf broadcom-wl-4.80.53.0.tar.bz2
    cd broadcom*
    cd kmod
    The answer to all of lifes questions are buried somewhere in the Google search engine.
    [Stephen@localhost ~]$ whatis this?
    this?: nothing appropriate
    RyRy Guest
    Broadcom Wireless LAN B+G
    Jul 2007
    Indiana USA
    1,715
    Copy and paste that into you console then copy and paste the output back here
    RyRy Guest
    Broadcom Copration BCM4318 AirForce One 54g 802.11g
    Jul 2007
    Indiana USA
    1,715
    That's what I needed to know, follow this how-to
    http://forums.fedoraforum.org/forum/...d.php?t=159322
    RyRy Guest
    Quote Originally Posted by FriedChips
    Thank you soo much, I will let you know personally if it works
    Jul 2007
    Indiana USA
    1,715
    Cool
    Quote Originally Posted by RyRy
    Can't find kernel build files in /lib/modules/2.6.22.6-81.fc7/build;
    make: *** [all] Error 2
    what does that mean?
    no worries brother you need the kernel-devel package, you will need this anytime you build a kernel module
    yum install kernel-devel
    then try again
    P.S. no need for the instant messages bro, I check back here often
    Sep 2007
    Los Angeles, CA
    128
    Hey, this is a related question:
    On my Acer Aspiron 5050 laptop, whenever I reinstall Vista, the wireless doesn't work right away and I download and install these Broadcom drivers from Acer's site. However, the actual device name for the wireless is
    [root@epsilon ~]# lspci | grep 802
    02:00.0 Ethernet controller: Atheros Communications, Inc. AR5006EG 802.11 b/g Wireless PCI Express Adapter (rev 01)
    Would the steps to install the Broadcom ndiswrapper still work? Or should I be looking for something to do with Atheros drivers?
    [root@epsilon ~]# lspci | grep Broadcom
    [root@epsilon ~]# lspci | grep broadcom
    [root@epsilon ~]#
    Dec 2004
    UK
    62
    276
    Reply To RYRY
    This howto should also get you going using the 'built in driver' .
    http://forums.fedoraforum.org/forum/...d.php?t=166744
    Stop making excuses, start making progress.
    Aug 2007
    52
    3,868
    Cuvou yours is easy have a look here
    normally id say install from livna but there is a dependency problem at the moment as the kernels do not match, livna is a bit ahead or vice versa.
    Aug 2007
    52
    3,868
    Cuvou sorry i forgot to say yours is madwifi/atheros not broadcom
    RyRy you to can also install by the script for broadcom if you want (native broadcom divers in f7 dont always work)
    FriedChips thanks for that when i copied pasted it , it turned it into a link ill have to look out for that in future.
  1. Acer Aspire One Wireless trouble
    By apollo2015 in forum Hardware & Laptops
    Last Post: 7th February 2009, 04:54 PM
  2. Libata errors on Acer Aspire 3630
    By AloneInTheDark in forum Hardware & Laptops
    Last Post: 11th January 2008, 10:55 AM
  3. atheros wireless in acer aspire 3620
    By metalworm in forum Servers & Networking
    Last Post: 13th June 2007, 05:38 PM
  4. How to connect to Wireless on my Acer Aspire 2000
    By wiggywag in forum Servers & Networking
    Last Post: 12th January 2006, 06:35 PM
