I followed some hints in this forum to get my bcm4318 wireless card working.
I downloaded the actual driver package from the HP Website and extracted the firmware.
I can see my wlans in the NetworkManager Applet, I can click on them an NM tries to
connect them. For me it seems that the IP address discovery is unsuccessful.
Has someone this or a similar problem solved ?
Here you'll find the interesting part of /var/log/messages:
Jul 20 00:55:19  kernel: bcm43xx_mac80211: Radio turned on
Jul 20 00:55:19  kernel: bcm43xx_mac80211: Radio enabled by hardware
Jul 20 00:55:19  kernel: bcm43xx_mac80211: !WARNING! Idle-TSSI phy->cur_idle_tssi measuring failed. (cur=0, tgt=62). Disabling TX power adjustment.
Jul 20 00:55:19  kernel: bcm43xx_mac80211: Chip initialized
Jul 20 00:55:19  kernel: bcm43xx_mac80211: 32-bit DMA initialized
Jul 20 00:55:19  kernel: bcm43xx_mac80211: Wireless interface started
Jul 20 00:55:19  NetworkManager: <info>  nm-netlink-monitor.c - nm_netlink_monitor_event_handler (724) netlink reports device wlan0 link now 1
Jul 20 00:55:20  kernel: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jul 20 00:55:20  NetworkManager: <info>  nm-netlink-monitor.c - nm_netlink_monitor_event_handler (724) netlink reports device wlan0 link now 1
Jul 20 00:55:20  NetworkManager: <info>  nm-netlink-monitor.c - nm_netlink_monitor_event_handler (724) netlink reports device wlan0 link now 0
Jul 20 00:55:30  NetworkManager: <info>  SWITCH: no current connection, found better connection 'wlan0'.
Jul 20 00:55:30  dhcdbd: message_handler: message handler not found under /com/redhat/dhcp/wlan0 for sub-path wlan0.dbus.get.reason
Jul 20 00:55:30  NetworkManager: <info>  Will activate connection 'wlan0/FON_LaHo01'.
Jul 20 00:55:30  NetworkManager: <info>  Device wlan0 activation scheduled...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) started...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Jul 20 00:55:30  NetworkManager: <info>  Activation (wlan0/wireless): access point 'FON_LaHo01' is unencrypted, no key needed.
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'INTERFACE_ADD wlan0             wext    /var/run/wpa_supplicant '
Jul 20 00:55:31  NetworkManager: <info>  SUP: response was 'OK'
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'AP_SCAN 1'
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'ADD_NETWORK'
Jul 20 00:55:31  NetworkManager: <info>  SUP: response was '0'
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'SET_NETWORK 0 ssid 464f4e5f4c61486f3031'
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'SET_NETWORK 0 key_mgmt NONE'
Jul 20 00:55:31  NetworkManager: <info>  SUP: sending command 'ENABLE_NETWORK 0'
Jul 20 00:55:31  NetworkManager: <info>  Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Jul 20 00:55:32  kernel: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jul 20 00:55:32  NetworkManager: <info>  nm-netlink-monitor.c - nm_netlink_monitor_event_handler (724) netlink reports device wlan0 link now 0
Jul 20 00:55:32  NetworkManager: <info>  nm-netlink-monitor.c - nm_netlink_monitor_event_handler (724) netlink reports device wlan0 link now 1
Jul 20 00:55:32  NetworkManager: <info>  nm-device.c - nm_device_set_active_link (596) device wlan0 link state set to 1
Jul 20 00:55:32  NetworkManager: <info>  Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful.  Connected to access point 'FON_LaHo01'.
Jul 20 00:55:32  NetworkManager: <info>  Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Jul 20 00:55:32  NetworkManager: <info>  Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Jul 20 00:55:33  NetworkManager: <info>  Activation (wlan0) Beginning DHCP transaction.
Jul 20 00:55:33  NetworkManager: <info>  Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Jul 20 00:55:33  NetworkManager: <info>  DHCP daemon state is now 12 (successfully started) for interface wlan0
Jul 20 00:55:33  dhclient: wmaster0: unknown hardware address type 801
Jul 20 00:55:33  NetworkManager: <info>  DHCP daemon state is now 1 (starting) for interface wlan0
Jul 20 00:55:33  dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
Jul 20 00:55:33  avahi-daemon[2615]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::290:4bff:fef7:6748.
Jul 20 00:55:33  avahi-daemon[2615]: New relevant interface wlan0.IPv6 for mDNS.
Jul 20 00:55:33  avahi-daemon[2615]: Registering new address record for fe80::290:4bff:fef7:6748 on wlan0.*.
Jul 20 00:55:37  NetworkManager: <info>  Old device 'wlan0' activating, won't change.
Jul 20 00:55:40  dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
Jul 20 00:55:49  dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
Jul 20 00:55:59  gconfd (root-3903): (Version 2.18.0.1) wird gestartet, Prozesskennung 3903, Benutzer »root«
Jul 20 00:55:59  gconfd (root-3903): Die Adresse »xml:readonly:/etc/gconf/gconf.xml.mandatory« wurde an der Position 0 zu einer nur lesbaren Konfigurationsquelle
aufgelöst
Jul 20 00:55:59  gconfd (root-3903): Die Adresse »xml:readwrite:/root/.gconf« wurde an der Position 1 zu einer schreibbaren Konfigurationsquelle aufgelöst
Jul 20 00:55:59  gconfd (root-3903): Die Adresse »xml:readonly:/etc/gconf/gconf.xml.defaults« wurde an der Position 2 zu einer nur lesbaren Konfigurationsquelle a
ufgelöst
Jul 20 00:56:04  dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
Jul 20 00:56:18  NetworkManager: <info>  Device 'wlan0' DHCP transaction took too long (>45s), stopping it.
Jul 20 00:56:18  dhclient: wmaster0: unknown hardware address type 801
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) Stage 4 of 5 (IP Configure Timeout) scheduled...
Jul 20 00:56:19  NetworkManager: <info>  DHCP daemon state is now 14 (normal exit) for interface wlan0
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) Stage 4 of 5 (IP Configure Timeout) started...
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) failure scheduled...
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) Stage 4 of 5 (IP Configure Timeout) complete.
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) failed for access point (FON_LaHo01)
Jul 20 00:56:19  NetworkManager: <info>  Activation (wlan0) failed.
Jul 20 00:56:19  NetworkManager: <info>  Deactivating device wlan0.
Jul 20 00:56:19  NetworkManager: <info>  SWITCH: no current connection, found better connection 'wlan0'.
I tried the v3 driver also but with the effect that no wlan can be ether seen nor connected.
2 Days ago I upgraded to fc7 from fc6 where the wlan stuff worked very well.
Any hint is welcome...
