Smart Card Reader
Results 1 to 6 of 6
    dipeshpatel Guest
    Smart Card Reader
    I am new to Linux and recently installed Fedora Core 6. After successfully installing the OS, i dicovered that there is the functionality to use the Smart Card reader on my laptop. However i am not sure how this works and an addition if Fedora has recognised the reader.
    How can i check that the reader has been recognised and the drivers installed, and how can i use the Smart Card utility?
    Thank you in advance for your assistance.
    Nocturnus Guest
    Shouldn't be a problem. If it is set up properly in System -> Prederences -> Removable Drives and Media the card reader should be automatically mounted when you connect it. When finished, right click on its desktop icon and unmount it.
    dipeshpatel Guest
    The reader is inbuilt into the laptop. How can i check that the drivers have been installed by Fedora?
    Does anyone know if i can use a utility within Fedora to access the card and how to work it or do i require another application?
    Nocturnus Guest
    It should still work. Like a CD the filesystem won't be detected until the machine tries to mount something. If you try a card and nothing happens try System-Administration-Smart Card Manager.
    Built-in or external, it won't detect anything until you put some media with a filesystem in it.
    dipeshpatel Guest
    Cheers.
    I take it that the utility will auto detect the inserted card and doesnt require pre-configuring.
    Mar 2007
    Bradford, UK
    39
    15
    I thought the smart card manager was for smart cards as in
    http://en.wikipedia.org/wiki/Smart_card
    not smart media cards
    (thats what the convo sounds like its talking about)
    *hardware the part of a computer you can kick*
  1. Fedora 11, smart card reader, firefox, and coollkey
    By leaskdw in forum Using Fedora
    Last Post: 18th December 2009, 07:31 PM
  2. Smart card reader "not claimed" by pcscd
    By i.j.dickinson in forum Hardware & Laptops
    Last Post: 11th November 2008, 11:14 PM
  3. Card reader GemPlus and memory card sle4442 problem
    By zah in forum Hardware & Laptops
    Last Post: 11th November 2007, 09:49 AM
  4. Replies: 6
    Last Post: 27th October 2007, 10:53 PM
  5. Smart Card Reader
    By Bloomer510 in forum Guides & Solutions (Not For Questions)
    Last Post: 5th July 2007, 06:21 AM
