fstab entries will not mount on boot.
Results 1 to 14 of 14
    spnetspec Guest
    Question fstab entries will not mount on boot.
    I just upgraded from fedora core 3 to core 6. I have a serial ata drive that I boot from and have a ata drive that I have the following mount labels. 1) /var/ftp 2) /home/webusers. I added the mount points during the install. The install went smooth, but upon boot the two ata drive mount points listed give a "write protected" error during the boot. and a kernal audit in the message log.
    here is the message log audits:
    Nov 15 18:25:17 rayout kernel: audit(1163636707.486:4): avc: denied { mounton } for pid=1548 comm="mount" name="webusers" dev=dm-0 ino=21528578 scontext=system_u:system_r:mount_t:s0 tcontext=user_u:object_r:user_home_dir_t:s0 tclass=dir
    Nov 15 18:25:17 rayout kernel: audit(1163636707.486:5): avc: denied { mounton } for pid=1548 comm="mount" name="webusers" dev=dm-0 ino=21528578 scontext=system_u:system_r:mount_t:s0 tcontext=user_u:object_r:user_home_dir_t:s0 tclass=dir
    mount output following boot
    [root@rayout ~]# mount
    /dev/mapper/VolGroup00-LogVol00 on / type ext3 (rw)
    proc on /proc type proc (rw)
    sysfs on /sys type sysfs (rw)
    devpts on /dev/pts type devpts (rw,gid=5,mode=620)
    /dev/sda1 on /boot type ext3 (rw)
    tmpfs on /dev/shm type tmpfs (rw)
    none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
    sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
    ## mount output when mount -a performed
    [root@rayout ~]# mount -a
    /dev/hda2 on /home/webusers type ext3 (rw)
    /dev/hda1 on /var/ftp type ext3 (rw)
    [root@rayout ~]#
    ## df -v output
    [root@rayout ~]# df -v
    Filesystem 1K-blocks Used Available Use% Mounted on
    115126668 2237236 106946956 3% /
    /dev/sda1 101086 10942 84925 12% /boot
    tmpfs 257336 0 257336 0% /dev/shm
    /dev/hda2 59084964 37340800 18742824 67% /home/webusers
    /dev/hda1 59084932 4823464 51260128 9% /var/ftp
    [root@rayout ~]#
    ## fstab
    [root@rayout ~]# cat /etc/fstab
    /dev/VolGroup00/LogVol00 / ext3 defaults 1 1
    LABEL=/boot /boot ext3 defaults 1 2
    devpts /dev/pts devpts gid=5,mode=620 0 0
    tmpfs /dev/shm tmpfs defaults 0 0
    LABEL=/home/webusers /home/webusers ext3 defaults 1 2
    proc /proc proc defaults 0 0
    sysfs /sys sysfs defaults 0 0
    LABEL=/var/ftp /var/ftp ext3 defaults 1 2
    /dev/VolGroup00/LogVol01 swap swap defaults 0 0
    /dev/hda3 swap swap defaults 0 0
    [root@rayout ~]#
    Am I just overlooking something,
    Oct 2006
    4,757
    Might be that I misunderstood what you're trying to do but couldn't you get the same result by making a webusers folder in the home directory and an ftp folder in var and then editing your fstab to mount those partitions into those folders.
    /dev/hda2 /home/webusers ext3 defaults 0 0
    /dev/hda1 /var/ftp ext3 defaults 0 0
    spnetspec Guest
    That is the same only I'm using Label.. This works great when I do a "mount -a" but it give a "device write protected error " on boot. after the machine boots I run the mount -a it mounts all entrys perfectly.
    spnetspec Guest
    The reason I use this I have all of my data stored on its own drive. It has worked great up to this point. it worked good from core 3 to core 4, I skipped core 5 and dosn't work w/core 6.
    Oct 2006
    4,757
    Right, but did you try it that way?
    spnetspec Guest
    yes same effect. On boot still compained bout both block devices being write protected, but mounted perfectly after logging into root and executing a mount -a.
    Feb 2005
    Lansing, Mi
    37
    2,221
    in fstab try
    /dev/hda2 /home/webusers ext3 rw exec auto user async 1 2
    /dev/hda1 /var/ftp ext3 rw exec auto user async 1 2
    As always
    Love, Life, Loyalty, Wisdom, Knowledge, And Understanding
    FC6: Common Questions answered
    Feb 2005
    Lansing, Mi
    37
    2,221
    also did you try with 0 0 not sure if a user can check the filesystem
    As always
    spnetspec Guest
    I tried your suggestions Nickisgod1 same out come. On boot error "cannot mount block device in read-only", but after boot was able to mount perfectly with mount -a".. I have no idea what is going on here but we must be over looking something. Could it be something with udev ?
    Seve's Avatar
    Seve is offline Retired Community Manager
    Oct 2004
    The GTA, Ontario, Canada
    63
    12,371
    Quote Originally Posted by spnetspec
    Hello:
    Been a few changes since FC3
    Since you are trying to mount to /home and /var, I believe that
    SeLinux will not allow this [or is blocking at boot time] and that is why you are seeing some errors.
    So, you have a few options that you can select from:
    Change the mount points to something other than /home and /var .. for example, you could use /mnt/
    Or,
    You have to set SeLinux to permissive or disable it for the mount a boot time to take place.
    Seve
    Registered Linux User: #384977
    See the Links below for more Help and those much wanted extras ... :)
    spnetspec Guest
    Could it be a udev rule issue?
    attached is my "50-udev.rules" any thoughts?
    Attached Files Attached Files
    spnetspec Guest
    Quote Originally Posted by Seve
    Hello:
    Or,
    Seve
    Will try in 5 min.. Thanks! I forgot about the Selinux rules. SPNS
    spnetspec Guest
    Hello:
    Or,
    Seve
    I modified the Selinux " mount any file " option. worked great. Guess I need to review all of the selinux params. ... Thanks !
    Oct 2006
    4,757
    Glad you got it working, I didn't even think about Selinux. You learn something everyday. I had a problem mounting one drive and the only change I made was moving that line to the end of the file and all of a sudden it's fine, go figure.
    Selinux is actually getting kind of annoying now I even had to modify it just to install the ntfs kmod. I see this feature being disabled on more and more machines in the near future.
  1. Replies: 7
    Last Post: 29th May 2006, 12:36 PM
  2. smbfs/cifs mount point in fstab not mounting on boot
    By rgladwell in forum Servers & Networking
    Last Post: 15th January 2006, 11:05 PM
