Model: Dell XPS 15
Videocard: Geforce 960
Network:
Wifi: Broadcom BCM43602 Wireless
Bluetooth:
Webcam: working fine
Touchpad: yes
Hotkey (Home, Eject, Suspend ...):
Display: touch screen working as well
OS: dual boot Win 10/ F23
Kernel: v4.4.7-300
Suspend on Disk:
Suspend on RAM:
Comments: all are working fine, some fix needed in firewall it keeps the reboot and shutdown to wait for a long period of time.
Model: ASUS X552L (BIOS reported as X550D, some marketed as X552LD)
iGPU: Intel HD Graphics 4400 (VGA port works fine, HDMI not yet tested but assumes working)
dGPU: NVIDIA GeForce 820M (nouveau not yet support Fermi reclocking as of time posted, go Bumblebee for gaming)
Network: Realtek RTL8111/8168/8411? (ok)
WIFI: Mediatek / Ralink RT3290 (ok) (past)
WIFI: Intel 7260N Single Band (ok, but hotspotting may cause some kernel errors, bad driver probably)
Bluetooth: (no Bluetooth driver for RT3290) (past)
Bluetooth: (ok w/ Intel 7260N)
Webcam: Chicony Electronics? (ok)
Touchpad: (ok)
Hotkeys: (ok since 4.10, previously need acpi_osi=! "acpi_osi=Windows 2001" to have the ACPI in fallback route, see DSDT page in Archlinux Wiki for howto)
Display: (ok)
Suspend on Disk: (ok but requires adding kernel parameter resume=/path/to/swap to work)
Suspend on RAM: (same as above)
Does NOT support HybridSleep, need to use Hibernate instead or don't use at all
Comments:
If your battery sucks, consider buying a new battery because your battery is old and small capacity now...
DVD writer not working? Clean the drive and the DVD to its cleanest state before consider replacing both...
Last edited by TruboXL; 10th September 2017 at 06:20 AM. Reason: Update for kernel 4.12
https://github,com/truboxl
Model: Toshiba Satellite M305D-S4829
Processor: AMD Turion X2 Dual-Core Mobile RM-70 @ 2.0GHz
Videocard: ATI Radeon HD 3100
RAM: 3GB DDR2 @ 667MHz.
SSD: 128GB ADATA SU800.
Network: Marvell Technology Group Ltd. 88E8040T
Wifi: Qualcomm Atheros AR5418 Wireless Network Adapter
Bluetooth: No.
Webcam: Chicony Electronics Co., Ltd USB 2.0 Camera (integrated)
Touchpad: Yes.
Hotkey (Home, Eject, Suspend ...): Yes.
Display: 14.1" diagonal widescreen TruBrite display (1280 x 800).
OS: Fedora 27 x86_64.
Kernel: 4.15.8-300.fc27.x86_64
Suspend on Disk: Yes.
Suspend on RAM: Yes.
Comments: This is an almost 10 year old machine I recently salvaged and, aside from the dead battery, some issue with the volume (it's a physical control) that gets changed for no apparent reason, and the obvious lack of HD playback capabilities, it performs beautifully. Having been put away for many years also helped its aesthetics which now contribute to make it look like a "classic".
Notebook: Acer Nitro 5
AMD Ryzen 5 2500U @ 2.0GHz, 32GB DDR4,
480GB M.2, 480GB SSD.
Fedora 39 x86-64.
Fedora 28 on a Thinkpad Carbon X1 gen 5. Works like a charm.
Let's submit hardware info automatically by https://fedoraproject.org/wiki/Hardware_probe, the successor of smolt project.
