Fc6 Broadcom BCM4401 problem
    urosm Guest
    Hy!
    I have truble getting my ethernet card to work... I have Broadcom BCM4401-B0 100Base-TX and FC6 doesn't recognize it.
    When I try to enable it (ifup eth0) I get error msg: No such device
    I searched Google, found one solution -> downloading drivers from Broadcom... but when I want to install them... I got error about eno directory missing (but it exist... actualy it's a link... bot no mather ).
    Can someone please tell me how can I solve this problem. PLEASE!
    p.s.: I gave up on getting ipw2200 to work (with WPA and WEP) in FC5... but ethernet worked there with no problem... so... any help around BCM4401 (and ipw2200) will be very appreciated
    and sorry for my bad english writting
    have a nice day,
    Uros from Slovenia
    35
    probably you are using XEN?
    If yes, this bug report may help you: bug 208242 (https://bugzilla.redhat.com/bugzill...g.cgi?id=208242). The Redhat fix works fine here.
    I linked some explanations on my page: http://www.felix-schwarz.name/Linux_on_Dell_E521_(en).
    fs
    goliathvt Guest
    Using Fedora Core 6, I had to recompile the kernel and insert the tg3 driver instead of having it run as a module. I know you have a different version of Broadcom NIC and would likely use a different driver, but I have a feeling the suggestion will help you out, as I've read a number of Broadcom users with Fedora 6 reporting that adding their card's driver into the kernel fixes their networking woes. For whatever reason, loadable modules, Broadcom and Fedora 6 aren't playing nice.
    - GoliathVT
    35
    These Broadcom chips seem to be quite crappy. See the explanations on the XEN mailing list (linked on my page) regarding DMA limitations of the B44. I think, one problem showing up means that there are most likely even more - especially with these kind of low cost consumer hardware.
    fs
    urosm Guest
    Hi!
    Thanks for all replays. I made it work. I just had to install new drivers and make an upgrade.
    p.s.: I suceeded in connecting wireless with wep... but still no luck with wpa.
    cheers,
    Uros
  1. Broadcom 4322AG problem
    By aggelos in forum Servers & Networking
    Last Post: 23rd September 2009, 02:14 PM
  2. Broadcom BCM4311 problem
    By epqr in forum Servers & Networking
    Last Post: 29th March 2009, 03:01 PM
  3. Weird broadcom problem - 1 mb/s for G??
    By Vansolrick in forum Servers & Networking
    Last Post: 12th April 2008, 02:01 AM
  4. broadcom wireless problem.
    By neo8307 in forum Hardware & Laptops
    Last Post: 16th January 2008, 12:34 PM
  5. FC6 and no network on Broadcom BCM4401
    By palla13 in forum Hardware & Laptops
    Last Post: 2nd November 2006, 09:19 PM
