Go Back   FedoraForum.org > Fedora Resources > Guides & Solutions (No Questions)
Guides & Solutions (No Questions) Post your guides here (No links to Blogs accepted). You can also append your comments/questions to a guide, but don't start a new thread to ask a question. Use another forum for that.
Old 2nd June 2012, 08:49 PM
COKEDUDE Offline
xrandr: cannot find crtc for output VGA1
If you get one of these two messages it means you either have a bad connection or you forgot to turn off the screen that you used last (the second one only happens in my experience when use multiple types of screens).
xrandr: cannot find crtc for output TV1
The easiest and quickest thing to do is to turn off the previous screen that you used like this.
xrandr --output TV1 --off
xrandr --output VGA1 --off
Then turn it back on like this.
xrandr --output VGA1 --mode 1024x768 --rate 60
xrandr --output TV1 --mode 1024x768 --rate 60
If that doesn't work you need to check connections. Running the xrandr command you should have an output like this. If you don't then it is confirmed you have a connection problem.
$ xrandr
Screen 0: minimum 320 x 200, current 2048 x 768, maximum 4096 x 4096
LVDS1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 304mm x 228mm
   1024x768       60.0*+
   800x600        60.3     56.2
   640x480        59.9
VGA1 connected 1024x768+1024+0 (normal left inverted right x axis y axis) 338mm x 270mm
   1280x1024      60.0 +   75.0
   1152x864       75.0
   1024x768       75.1     70.1     60.0*
   832x624        74.6
   800x600        72.2     75.0     60.3     56.2
   640x480        72.8     75.0     66.7     60.0
   720x400        70.1
DVI1 disconnected (normal left inverted right x axis y axis)
TV1 unknown connection (normal left inverted right x axis y axis)
   848x480        59.9 +
   640x480        59.9 +
   1024x768       59.9
   800x600        59.9
crtc, output, vga1, xrandr
XrandR deunnero Hardware & Laptops 4 8th December 2011 06:26 AM
xrandr - F9 - intel 945: cannot find crtc jaromrax Hardware & Laptops 3 11th December 2008 08:18 AM
doing something to the output of find daviddoria Using Fedora 7 8th December 2008 12:38 PM
F7 - xrandr --output TV (no PAL) jaromrax Hardware & Laptops 0 14th January 2008 12:42 PM
contab -l output is stored where? I can't find a single file with the same content alphonsebrown Using Fedora 7 10th April 2005 05:55 AM
Current GMT-time: 14:25 (Wednesday, 19-06-2013)
