Old 24th October 2008, 03:22 PM
chesire Offline
Installation problems with 8800GTX video card
I'm new to linux and was trying to create a dual boot setup on my new Vista 32 machine. I created the boot DVD for fedora 9, started the installation, performed the verify media step, and then it goes to load up a driver for my nvidia 8800GTX video card and the screen goes blank and never comes back. I actually have 2 8800GTX cards currently installed in my system in an SLI configuration. Has anyone come across this problem before or have any suggestions on how I might get around this to complete the installation?
Thanks,
Melissa
Old 24th October 2008, 03:29 PM
Hlingler's Avatar
Hlingler Offline
Very common problem for stock F9. If you can install in text mode, then update all software, it might help. Or get a re-spin from Fedora Unity with newer updates included. Search the forums.
Good Luck,
V
P.S. Once you do get installed, installing the proprietary driver will almost certainly improve graphics. See the Guides and How-Tos forum.
Old 24th October 2008, 04:11 PM
chesire Offline
Thanks so much. I'll check out fedora unity and the re-spins and see if I can get someplace with that. Appreciate the help!
-Melissa
Old 24th October 2008, 04:14 PM
Hlingler's Avatar
Hlingler Offline
http://spins.fedoraunity.org/
HTH,
V
8800gtx, card, installation, problems, video
F7 nvidia 8800gtx / viesonic vx2235wm installation problem grg183 Installation and Live Media 7 14th August 2007 06:24 PM
Installation problems:S3 Virge video card and Mouse configuration jueliang Installation and Live Media 0 18th January 2006 04:49 AM
Changing Video Card - Before Installation? regin Using Fedora 3 9th October 2004 06:24 PM
Current GMT-time: 15:39 (Saturday, 18-05-2013)
