Go Back   FedoraForum.org > The Dungeon > Archived (Click Header To See Sub-Forums) > Alpha - Beta (Fedora 9 Only)
Alpha - Beta (Fedora 9 Only) Post Development Version comments and questions that don't belong in Bugzilla here. These posts will be moved or deleted once the Final version is released
  #151
Old 30th May 2008, 01:28 PM
chalsall Offline
Hey All.
I'm *dying* to get my 3D acceleration back under FC9. Running on a Dell Precision M65.
However, the above did *not* work for me. I haven't "downgraded", so simply added the livna repository, and then ran the yum install (kmod-nvidia xorg-x11-drv-nvidia xorg-x11-drv-nvidia-lib), and then the "nvidia-config-display enable".
However, when I try to "startx" (I boot into init 3 as a precaution), I get the following error: "dlopen: /usr/lib/xorg/modules/extensions//libglx.so: undefined symbol: _nv001471gl".
Any thoughts?
Thanks for all your efforts here.
  #152
Old 30th May 2008, 04:25 PM
notageek Offline
Please post
1. uname -r
2. ls /boot
Robot Nite - Designated device drivers drink free
  #153
Old 30th May 2008, 04:38 PM
notageek Offline
Please note that the kernel module (driver) of Nvidia available at Livna is for the 2.6.25.3-18.fc9 kernel. If you're still unable to get Nvidia working then
1. Check the kernel version you're running on (by running uname -r)
2. ls /boot will show you the list of kernels available (files starting with vmlinuz-xxx)
3. Edit /boot/grub/grub.conf to make sure the correct kernel is booting.
  #154
Old 30th May 2008, 04:43 PM
hammel Offline
kmod-nvidia from livna is working like a charme with latest xorg here.
i have an 7900GS.
Registered Linux User 406188
  #155
Old 31st May 2008, 12:57 AM
chalsall Offline
Hi notageek.
Thanks for your suggestions, but it does appear that I'm running the correct version.
[chalsall@burrow ~]$ uname -r
2.6.25.3-18.fc9.i686
[chalsall@burrow ~]$ ls /boot
config-2.6.25-14.fc9.i686      initrd-2.6.25.3-18.fc9.i686.img
config-2.6.25.3-18.fc9.i686    System.map-2.6.25-14.fc9.i686
efi                            System.map-2.6.25.3-18.fc9.i686
grub                           vmlinuz-2.6.25-14.fc9.i686
initrd-2.6.25-14.fc9.i686.img  vmlinuz-2.6.25.3-18.fc9.i686
Any tests / experiments anyone can suggest?
Thanks!!!
  #156
Old 31st May 2008, 03:03 AM
TalioGladius Offline
Has anyone seen this?
http://news.softpedia.com/news/Insta...-9-86757.shtml
Since not having dual monitors was a deal breaker for me, I went to Ubuntu 8.04. Which in turn my wireless card on my laptop doesn't work with it. I can't catch a linux break for anything.
  #157
Old 31st May 2008, 03:45 AM
leigh123linux
Guest
Posts: n/a
Try PCLinux
http://distrowatch.com/table.php?distribution=pclinuxos
  #158
Old 31st May 2008, 10:59 AM
demuytree Offline
I have a problem when finish install...can not enable desktop effect
/usr/sbin/nvidia-config-display enable
Driver already enabled.
glxinfo
name of display: :0.0
Xlib: extension "GLX" missing on display ":0.0".
Error: couldn't find RGB GLX visual or fbconfig
3 GLXFBConfigs:
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
Segmentation fault
  #159
Old 31st May 2008, 11:07 AM
leigh123linux
Guest
Posts: n/a
glxinfo
3 GLXFBConfigs:
Segmentation fault
post
cat /etc/X11/xorg.conf
  #160
Old 31st May 2008, 11:42 AM
stefan1975 Offline
"Stefan the converted" -- forum Macintosh® Glee Club leader
Originally Posted by chalsall
Hey All.
i have a precision m65 too and for me it is not working either, not on OpenSuSe11 either. If I understand correctly it is a bug in the nvidia driver that they recognized but are uncertain if/how/when it will be solved:
http://www.nvnews.net/vbulletin/show...ghlight=quadro
i do not know why it applies to certain nvidia cards and not to others but the quadro seems to be suffering from this. maybe i will try the 173.08 beta once again
stefan
"$ su - bofh"
OS: Mac OSX Snow Leopard (x64 by default), W7_Enterprise_X64, F12_x64_KDE
Hardware: late 2009 Macbook 13", MSI Wind 10"
Browser: Opera 10.10, Safari 4
Registered linux user #459910
  #161
Old 31st May 2008, 02:40 PM
demuytree Offline
I successfully Installed new Nvidia Driver...^^...I forgot to remove Xorg....haha.. It work fine now but my compiz fusion have a new problem...It's just provide me only rotate desktop cube..and wobble windows in desktop effect and emerald windows...So I can't use other effect in my compiz-manager...(...have someone else have the same problem to me ??
  #162
Old 31st May 2008, 02:54 PM
Firewing1 Offline
You can install "compizconfig-backend-gconf" and "ccsm" to configure Compiz with extra (3rd party?) plugins, although this is unsupported. I've tried this on 3 machines and confirmed that Compiz will crash every time you open a new window... It did work when I only enabled the 'water' and the extra switcher plugins though. Anything else seems to start the new-window-crash bug.
Firewing1
[+] My open source software and blog
[+] Some of my howtos: (for full list, click here)
  #163
Old 31st May 2008, 03:12 PM
weitjong Offline
I have waited patiently for this day. I have not downgraded my X. After following Leigh's instruction in this thread: http://forums.fedoraforum.org/forum/...d.php?t=190240, everything seems to work in a perfect harmony. I only deviated slightly from his instruction. I install the 64-bit kmod-nvidia package instead of akmod.
I have not tried all the compiz-fusion bell and whistle, but at least the one that I did try seems to work nicely though.
In case someone is wondering, I have MSI 7900GTX.
  #164
Old 31st May 2008, 03:47 PM
leigh123linux
Guest
Posts: n/a
Use fusion-icon instead to launch compiz-fusion !
  #165
Old 31st May 2008, 03:57 PM
Firewing1 Offline
Edit: Ignore this post, I had a thinko. Can't use Compiz when I've switched to the Vesa driver!
Doesn't work for fglrx
compiz (core) - Fatal: No GLXFBConfig for default depth, this isn't going to work.
compiz (core) - Error: Failed to manage screen: 0
compiz (core) - Fatal: No manageable screens found on display :0.0
Any way to pass LIBGL_ALWAYS_INDIRECT to fusion-icon?
Firewing1
fedora, nvidia, opengl
OpenGL doesn't work, nvidia does Xx r3negade Hardware & Laptops 6 9th March 2008 08:18 AM
help please (nvidia/OpenGl problems) tapke Using Fedora 21 2nd January 2008 01:09 PM
nVidia - no opengl after upgrade to FC6 akbowbender Hardware & Laptops 2 2nd November 2006 03:33 AM
Nvidia Drivers and OpenGL Chupacabra Using Fedora 10 2nd September 2006 11:06 PM
FC4: Nvidia and OpenGL Supa Troopa Hardware & Laptops 2 2nd July 2005 02:04 AM
Current GMT-time: 20:58 (Sunday, 25-06-2017)
