  #31
Old 13th April 2017, 05:00 PM
PabloTwo Offline
"Registered User" T-Shirt Winner
Re: Long, long Fedora boot (stopwatch Fedorathon)
Originally Posted by topiwala View Post
Then i think other way is to name one of the fedora entries as Windows Boot Manager. and make it default.
That makes no sense to me as he (apparently) has no Windows installed. His problem seems to be that he keeps repeatedly booting from the BOOTX64.EFI shim which spawns a new "Fedora" entry instead of from any of the existing "Fedora" entries.
Old 18th April 2017, 10:06 PM
Vareg Offline
Yes, PabloTwo, you're totally right, I have been having no Windows whatsoever for years on the discussed comp (the one I'm using now anyway) and in any case I have just run $ sudo blkid | grep ntfs and it returns strictly nothing...
As for your idea Topiwala to rename the boot file same style as Windows, well I'm not denying it could work but I've got a funny feeling about it though.
info deleted per Forum rules. Signatures linked to non-authorized sites will be deleted.
Old 19th April 2017, 12:40 AM
gordon64 Offline
then as a suggestion to avoid all this non-intuitive junk, when F26 comes out
use the partition tool to delete the UEFI partition and create nice easy MBR style partitions.
FWIW I have a 1TB drive with 4 primary partitiions
first partition has a debian distro on it....it get replaced when F26 out
second is my swap
third is F25
fourth is my data, I keep very little in home and make backups of data at my own whim
I backup my system partitions initially to the data partition using an image system by "fsarchiver"
tower asus z97m plus
laptop Acer aspire ES1-420-55H6
FF from unpack
Old 19th April 2017, 03:28 AM
topiwala Offline
Every Laptop brand ha different implementation of UEFI. AFAIK HP has hardwired to make bootmgfw as default EFI from Microsofts partition. And even among HP laptops Different types have different implementation. When i was trying to install REFIND i renamed shim to the corresponding file and placed it there with other required files. It has been a long time so i cannot give you step by step recall.
boot, fedora, fedorathon, long, stopwatch
[SOLVED] Fedora 21 long boot time khoacao96 Using Fedora 7 31st January 2015 05:17 PM
Long boot times - Fedora 19 X64 cranil7 Using Fedora 9 3rd August 2013 08:02 PM
Long boot time in Fedora 15 chm270 Guides & Solutions (Not For Questions) 0 16th November 2011 05:04 AM
tar -czf taking long long time shariqnitt EOL (End Of Life) Versions 3 31st January 2011 12:17 PM
Fedora 12 taking too long to Boot Gaurav Prabhu Using Fedora 4 7th March 2010 08:12 AM
Current GMT-time: 05:25 (Tuesday, 30-05-2017)
