Old 19th March 2017, 06:40 PM
PabloTwo Offline
"Registered User" T-Shirt Winner
Re: latest kernel installed but no initramfs created
One more suggestion. Since grubby is responsible for adding and removing kernel entries from the grub.cfg file when a new kernel is installed, you can check the integrity of that package with:
$ rpm -V grubby
No output means everything with that package is OK.
Old 20th March 2017, 02:32 PM
PabloTwo Offline
The unconfined seems to be normal. I have the same in my system.
Should I restore the old grub.cfg ?
Did you mean by that the /etc/default/grub file? If so, no just leave things as they are.
Old 30th March 2017, 12:27 PM
Spinnifex77 Offline
Smile Re: latest kernel installed but no initramfs created
Hi pablo,
Thanks for your help again.
Since there are no new problems with installing kernel updates this thread can be closed.
See you,
Spinni
created, initramfs, installed, kernel, latest
Does Kernel Update Build Initramfs with User-Installed Firmware Blobs? joncr F24 Development Forum 0 4th May 2016 04:18 PM
Latest Kernel Installed, but Old One Still Remains Amorgan Installation, Upgrades and Live Media 16 19th October 2012 07:47 PM
F16 kernel 3.3.7-1 missing initramfs? markf Installation, Upgrades and Live Media 5 10th June 2012 12:56 PM
F11 dracut and new 32.9 kernel initramfs SlowJet Using Fedora 9 4th March 2010 12:06 AM
initramfs created instead of initrd - can't boot new kernel Jongi Fedora 12 Alpha, Beta & Release Candidates 12 9th November 2009 01:17 AM
Current GMT-time: 19:38 (Wednesday, 26-04-2017)
