Old 4th November 2016, 04:37 PM
srakitnican Offline
Re: kernel 4.9.0rc0 4.9.0rc1 virtualbox didn't work
Originally Posted by antikythera View Post
Well the F26 key is the current rawhide package key, there would be little point in them releasing one if package maintainers aren't meant to use it with rawhide. F26 has not been branched yet.
Ok, so there are keys installed I am guessing for a future stable release. The fact is that packages for rawhide are not signed and in some cases I have found that even alpha releases does not have every package signed. Not sure why is that, to make the development process easier perhaps.
$ grep gpgcheck /etc/yum.repos.d/fedora-rawhide.repo
gpgcheck=0
gpgcheck=0
gpgcheck=0
Originally Posted by nobody View Post
Command in RED does not work. It gave the following error message: ERROR: No matching repo to modify: rawhide.
_nobody_
I have overlooked this somehow, you need package fedora-repos-rawhide for rawhide repo.
Old 5th November 2016, 05:54 AM
nobody Offline
windows_98_nt_2000chrome
Arrow Re: kernel 4.9.0rc0 4.9.0rc1 virtualbox didn't work
As usually, CLI traces (as actions done) follow your comments. Please, do understand that this are traces from my VM Fedora 25 on the top of my VMWorkstation 12.5.1, so the VM I have updated to rawhide is two layers above (on virtualbox, wich I run from Fedora 25 VM):
[root@localhost ~]# uname -r
4.8.6-300.fc25.x86_64
[root@localhost ~]# dnf install fedora-repos-rawhide
RPM Fusion for Fedora 25 - Nonfree                                                  801 kB/s | 155 kB     00:00
RPM Fusion for Fedora 25 - Nonfree - Test Updates                                   3.1 kB/s | 257  B     00:00
RPM Fusion for Fedora 25 - Free - Test Updates                                      1.4 kB/s | 257  B     00:00
RPM Fusion for Fedora 25 - Free                                                     1.2 MB/s | 532 kB     00:00
Dependencies resolved.
 Package                              Arch                   Version                   Repository              Size
Installing:
 fedora-repos-rawhide                 noarch                 25-0.5                    fedora                 8.7 k
Transaction Summary
Install  1 Package
Total download size: 8.7 k
Installed size: 2.0 k
Is this ok [y/N]: y
Downloading Packages:
fedora-repos-rawhide-25-0.5.noarch.rpm                                               44 kB/s | 8.7 kB     00:00
Total        6.3 kB/s | 8.7 kB     00:01
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Installing  : fedora-repos-rawhide-25-0.5.noarch                                                              1/1
  Verifying   : fedora-repos-rawhide-25-0.5.noarch                                                              1/1
Installed:
  fedora-repos-rawhide.noarch 25-0.5
Complete!
[root@localhost ~]# dnf config-manager --set-enabled rawhide
[root@localhost ~]#
I do not intend to upgrade my Fedora 25 VM for the time being.
Thank you,
_nobody_
error, existing, file, gpg, install, rawhide, update
yum update error - rawhide!!! pgw Alpha, Beta & Snapshots Discussions (Fedora 11 Only) 9 28th February 2009 02:47 AM
yum update ERROR (file conflict) sara200t Using Fedora 2 18th September 2008 05:57 AM
Fedora 8 install error mounting existing /home hrabeX Installation, Upgrades and Live Media 4 10th November 2007 04:23 PM
Error during install after upgrade existing Next button zx5000 Installation, Upgrades and Live Media 0 29th April 2006 04:05 PM
Current GMT-time: 13:51 (Friday, 23-06-2017)
