  #31
Old 7th June 2016, 12:18 AM
Piscium Offline
Re: F22 Nvidia Guide Link
I did what you suggested (see below), and removing the RPM package for the Nouveau driver did not remove the driver from the dracut image. I suppose that I could manually delete the Nouveau driver from usr/lib/modules/ but I am not sure if when a new kernel arrives it would not be put back.
On the other hand it seems that the Nouveau driver is blacklisted automatically by installing the xorg-x11-drv-nvidia driver. So maybe things are fine as they are and I don't need to do anything else, and indeed it may have been unnecessary to uninstall the Nouveau driver.
What do you think?
[root@tornado tmp]# dracut test.img $(uname -r)
[root@tornado tmp]# lsinitrd test.img | grep nouveau
-rw-r--r--   1 root     root          185 Nov 21  2015 usr/lib/modprobe.d/blacklist-nouveau.conf
drwxr-xr-x   2 root     root            0 Jun  7 00:04 usr/lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/gpu/drm/nouveau
-rw-r--r--   1 root     root       442452 May 21 17:21 usr/lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/gpu/drm/nouveau/nouveau.ko.xz
[root@tornado tmp]# dnf remove xorg-x11-drv-nouveau
Dependencies resolved.
 Package                               Arch                    Version                             Repository                Size
Removing:
 xorg-x11-drv-nouveau                  x86_64                  1:1.0.12-3.fc23                     @System                  217 k
Transaction Summary
Remove  1 Package
Installed size: 217 k
Is this ok [y/N]: y
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Erasing     : xorg-x11-drv-nouveau-1:1.0.12-3.fc23.x86_64        1/1
  Verifying   : xorg-x11-drv-nouveau-1:1.0.12-3.fc23.x86_64        1/1
Removed:
  xorg-x11-drv-nouveau.x86_64 1:1.0.12-3.fc23
Complete!
[root@tornado tmp]# dracut test2.img $(uname -r)
[root@tornado tmp]# lsinitrd test2.img | grep nouveau
drwxr-xr-x   2 root     root            0 Jun  7 00:07 usr/lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/gpu/drm/nouveau
[root@tornado tmp]# yum provides */blacklist-nouveau.conf
Yum command has been deprecated, redirecting to '/usr/bin/dnf provides */blacklist-nouveau.conf'.
See 'man dnf' and 'man yum2dnf' for more information.
To transfer transaction metadata from yum to DNF, run:
'dnf install python-dnf-plugins-extras-migrate && dnf-2 migrate'
Last metadata expiration check: 0:03:01 ago on Tue Jun  7 00:04:59 2016.
xorg-x11-drv-nvidia-1:358.16-2.fc23.x86_64 : NVIDIA's proprietary display driver for NVIDIA graphic cards
Repo        : @System
xorg-x11-drv-nvidia-340xx-1:340.96-1.fc23.x86_64 : NVIDIA's 340xx series proprietary display driver for NVIDIA graphic cards
Repo        : rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-304xx-304.131-1.fc23.x86_64 : NVIDIA's 304xx serie proprietary display driver for NVIDIA graphic cards
Old 7th June 2016, 12:37 AM
dd_wizard Offline
If nouveau is blacklisted, you should be good. Did you reboot after you removed nouveau and before you ran dracut?
dd_wizard
Old 7th June 2016, 01:08 AM
Piscium Offline
No, I hadn't rebooted after uninstalling the Nouveau driver, but I rebooted just a moment ago and it did not make any difference with respect to the output of lsinitrd.
Cool. So the problem is solved (hopefully) and I will have the confirmation only when the next kernel update appears.
Thanks a lot for your help!
Cheers.
[root@tornado tmp]# dracut test3.img $(uname -r)
[root@tornado tmp]# lsinitrd test3.img | grep nouveau
drwxr-xr-x   2 root     root            0 Jun  7 01:02 usr/lib/modules/4.5.5-201.fc23.x86_64/kernel/drivers/gpu/drm/nouveau
[root@tornado tmp]# dnf provides */nouveau.ko.xz
Last metadata expiration check: 0:58:28 ago on Tue Jun  7 00:04:59 2016.
kernel-modules-4.4.3-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.4.5-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.4.6-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.4.6-301.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.4.8-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.4.9-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-modules-4.5.5-201.fc23.x86_64 : kernel modules to match the core kernel
Repo        : @System
kernel-debug-modules-4.5.5-201.fc23.x86_64 : kernel modules to match the core kernel
Repo        : updates
Repo        : updates
kernel-debug-modules-4.2.3-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : fedora
kernel-modules-4.2.3-300.fc23.x86_64 : kernel modules to match the core kernel
Repo        : fedora
Old 9th June 2016, 07:46 PM
Piscium Offline
A new kernel version arrived for F23, 4.5.6-200, and Nvidia still works fine without me doing anything special.
Below is my updated procedure in case someone needs it. It should work for new-ish Nvidia cards (mine is 3 years old).
I installed the dkms package because someone recommended it in this thread, though I am not sure it is needed. Also I installed a few packages recommended in the RPM Fusion website such as vdpauinfo though again I am not sure they are needed. In any case, these packages are not causing me any harm. There is no need to uninstall the Nouveau driver.
I am left wondering why we even need such a procedure. For example, why doesn't installing akmod-nvidia and xorg-x11-drv-nvidia pull all the other needed packages and run dracut? I know nothing about packaging so maybe there is a good reason for that!
# Run the commands below as root or with sudo
# Make sure we are up to date
dnf update
# Install a bunch of packages
# This is an explicit list and it could be made shorter as some packages depend on others, the long list is just for clarity
dnf install   akmod-nvidia xorg-x11-drv-nvidia    xorg-x11-drv-nvidia-devel   xorg-x11-drv-nvidia-libs   gcc   kernel-devel  vdpauinfo  libva-vdpau-driver  libva-utils  dkms  kernel-headers  xorg-x11-drv-nvidia-libs.i686
ls /boot
# Backup old initramfs nouveau image.
# There are two alternatives to this: delete old image or use the parameter "--force" in dracut below
mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img
# Create new initramfs image
# There is no need to use "--omit-drivers nouveau" because the nouveau driver is automatically blacklisted as a result of installing xorg-x11-drv-nvidia
dracut /boot/initramfs-$(uname -r).img $(uname -r)
ls /boot
# Reboot
# reboot
# After reboot, this command should not output anything if the Nvidia driver is being used:
lsmod |grep nouveau
f22, guide, link, nvidia
F18-F20: Nvidia guide Dan Guides & Solutions (Not For Questions) 365 30th November 2015 08:30 AM
Hostapd guide using D-Link DWA-525 amirhamzah EOL (End Of Life) Versions 1 5th May 2012 10:35 AM
Nvidia guide leigh123linux F16 Development 31 31st October 2011 07:04 AM
F15 Nvidia Guide leigh123linux F15 Development 128 24th May 2011 02:40 PM
Nvidia guide for Rawhide. leigh123linux F16 Development 77 15th February 2011 10:08 PM
Current GMT-time: 22:43 (Monday, 29-05-2017)
