  #76
Old 19th January 2016, 08:59 AM
glennzo Offline
Un-Retired Administrator
Re: Oracle VirtualBox installation script
Originally Posted by roundboy View Post
Hi Glenn,
I had 2 problems with the script, both easy to fix:
1) Cut and past of the script into a 22_oracle_virtualbox.sh file using gedit. The copy included a space at the end of each line. For some reason COMMENT didn't like this. I do not know why. All I did was remove the spaces at the end of lines 11 thru 21.
2) The following invocation of curl on line 33 is causing the problem.
curl -Os http://download.virtualbox.org/virtualbox/LATEST.TXT
I took out the "" and "" references and the script worked for me.
I had fun debugging this script. I haven't done this in at least 10 years and I now know how the rust builds up in the brain.
Great script. Works great. Thanks.
Dave
Maybe copy/paste isn't the best method for passing a script to one another? File uploads are broken within the forum else I'd upload a .tar.gz file of same.
Glenn
The Bassinator
Old 2nd July 2016, 11:05 PM
glennzo Offline
Hey today! I maintain this script for my own amusement. Here's the latest update. The script worked well, minutes ago, for Fedora 24 Mate (x86_64).
PHP Code:
#!/bin/bash
# 22_oracle_virtualbox.sh
# Glenn A. Johnson
# Started January 18, 2015
# Updated July 2, 2016
# A tip of the fedora to Fedora Forum members Sea, Skull One, marko, Dangermouse
# for help with code
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 22 or later.
Install the Oracle VirtualBox Extension Pack.
Handle all platformsi686PAE and x86_64 .
Clean up when finished.
Remove previously installed VirtualBox.
Support color no color (sudo NOCOLOR=1 22_oracle_virtualbox.sh)
COMMENT
# 07.02.16 - Just checking
# 05.04.16 - Never ending version updates.
# 01.30.16 - Never ending version updates.
# 01.24.16 - Never ending version updates.
# 01.05.16 - Checking in.
# 12.27.15 - VirtualBox version update
# 12.15.15 - VirtualBox version update
# 11.13.15 - Constantly updating the current VirtualBox versioning numbers.
# 10.21.15 - Constantly updating the current VirtualBox versioning numbers.
# 10.04.15 - Constantly updating the current VirtualBox versioning numbers.
# 09.13.15 - Adding Fedora 23 to the mix, I think...
# 09.12.15 - Constantly changing VirtualBox versions
# 07.22.15 - Decided to support only the current release of Fedora
# 07.19.15 - No longer need YUM since we're Fedora 21 and later.
# 07.19.15 - Got me a couple errors to deal with ...
# 07.09.15 - Fedora 21 and 22 only. No more Fedora 20.
# 07.09.15 - Version 5.0 ??
# 06.08.18 - Working with the Fedora 22 rpm
# 06.07.17 - Huh?
# 05.14.15 - Add feature to import and install the Oracle public key
# 05.14.15 - Update VirtualBox version to 4.3.28
# 05.12.15 - Test run under Fedora 22 Beta.
# 04.26.15 - Can I add an uninstall (safely) feature?
# 04.26.15 - Testing... 1,2,3
# 03.26.15 - Cosmetic changes and version update
# 03.15.15 - Tested under Fedora 22 Workstation Alpha (x86_64).
# 03.14.15 - New VirtualBox version
# 02.25.15 - Betterer code to discover kernel arch.
# 02.23.15 - New code to discover kernel arch
# 02.22.15 - Seems that kernel arch discovery is not working.
# 02.21.15 - New version of VirtualBox
<< COMMENT
Additional packages needed
for a successful install of VirtualBox over the different platformsx86_64i686 and i686+PAE include
kernel-devel-$(uname -r), gccqtqt-x11libpng15libXmulibXtlibvpxcompat-libvpx1dkms, and SDL
COMMENT
# Determine OS platform and install correct packages.
# PAE or no?
GETVERS=$(uname -grep "PAE")
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx compat-libvpx1 dkms SDL"
else
PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx compat-libvpx1 dkms SDL"
fi
# Determine the current version of VirtualBox
curl -Os [url]http://download.virtualbox.org/virtualbox/LATEST.TXT[/url]
current_version=$(cat LATEST.TXT)
echo
$current_version
rm LATEST
.TXT
# We can easily make changes to the source file versions by changing a few variables below.
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.0.10/VirtualBox-5.0-5.0.10_108355_fedora22-1.x86_64.rpm[/url]
# [url]http://download.virtualbox.org/virtualbox/5.0.10/VirtualBox-5.0-5.0.10_108355_fedora22-1.x86_64.rpm[/url]
# [url]http://download.virtualbox.org/virtualbox/5.0.20/VirtualBox-5.0-5.0.20_108355_fedora22-1.x86_64.rpm[/url]
VB_REL_VER="5.0-"$current_version"_108355"
VB_EXT_VER="$current_version"-108355
VB_REL_DIST
="fedora24-1"
VBOX_SRC_FILE="VirtualBox-${VB_REL_VER}_${VB_REL_DIST}."`uname -m`".rpm"
VBOX_EXT_SRC="Oracle_VM_VirtualBox_Extension_Pack-${VB_EXT_VER}.vbox-extpack"
SRC_PATH="http://download.virtualbox.org/virtualbox/$current_version"
PUB_KEY="oracle_vbox.asc"
# Color definitions; the variables are null if the option NOCOLOR is set.
# Thanks Skull One!
if [ -"$NOCOLOR]; then
    OKB
=$(tput bold;tput setaf 6)
OK=$(tput setaf 6)
ERRB=$(tput bold;tput setaf 1)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
# Need elevated permissions at some point, might as well do it now.
if [[ $EUID -ne 0 ]] ; then
    clear
       printf $OK
"You're going to need elevated permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 22 or later
function get_release()
printf $OK"Checking Fedora release version... "$RST
    RELNUM
=$(rpm -qa --queryformat '%{version}\n' fedora-release)
    if [[
$RELNUM -lt "22" ]] ; then
        clear
        printf $ERR
"This script is for Fedora release 22 or later.\n"$RST
exit 0
else printf $OK"Fedora $RELNUM $OKB✓"$RST
fi
echo
# Clear screen and print a headline.
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 22.\n"$RST
    printf $OK
"==>$OKB Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
    printf $OK
"==>$OKB VirtualBox release $VB_REL_VER\n"$RST
# Remove Oracle VirtualBox source files if they exist in the current working directory.
function remove_source()
    for
i in $VBOX_SRC_FILE $VBOX_EXT_SRC $PUB_KEY; do
rm -f $i
    done
# Remove any installed version of VirtualBox.
function remove_fed_vbox()
VBOX_INSTALLED=$(rpm -qa grep VirtualBox)
if [[
$VBOX_INSTALLED ]] ; then
    printf $OK
"Removing previously installed instance of VirtualBox. Please wait..."$RST
    dnf
--q erase $VBOX_INSTALLED 2>/dev/null
    printf $OKB
" ✓\n\n"$RST
fi
# Download and import the Oracle public key.
function get_public_key()
printf $OK"Installing the Oracle public key.\n"$RST
curl
-Os https://www.virtualbox.org/download/$PUB_KEY
rpm --import $PUB_KEY
# Install Oracle VirtualBox from the downloaded source RPM.
function install_source()
    if [[ -
f $VBOX_SRC_FILE ]] ; then
        printf $OK
"Installing Oracle VirtualBox\n"$RST
        rpm
-Uvh $VBOX_SRC_FILE
else
printf $ERR"The source file missing.\nThere was an error downloading the file.\n"$RST
exit 0
    fi
# Install the Oracle VirtualBox Extension Pack.
function install_extpack()
    if [[ -
f $VBOX_EXT_SRC ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack."$RST
        VBoxManage extpack install
--replace $VBOX_EXT_SRC
else
printf $ERR"Oracle VirtualBox extension pack source file missing!\n"$RST
    fi
# Get any Fedora packages typically needed to complete the VirtualBox installation without errors.
function get_packages()
printf $OK"Checking for necessary packages..."$RST
echo
NEWPKGS=""
for i in $PACKFILES ; do
printf $OK"==> $i: "
rpm -q $i > /dev/null
if [ $? -eq 0 ] ; then
        printf $OKB
"✓\n"$RST
else
printf $ERR"✗\n"$RST
        NEWPKGS
="${NEWPKGS} $i"
fi
done
if [ -"${NEWPKGS}]; then
echo --n $OK"==> Installing necessary packages$OKB "${NEWPKGS}"... "$RST
    dnf
--q install ${NEWPKGS2>/dev/null
echo -e $OKB"\nDone installing packages.\n"$RST
else
printf $OK"==>$OKB Nothing new to install.\n"$RST
fi
# Test retrieval of any Fedora packages typically needed to complete the VirtualBox installation without errors.
function test_get_packages()
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo --n $OK"==> Packages that need to be installed are: $OKB "${NEWPKGS}"... "$RST
echo
else
echo
fi
# Get the VirtualBox source files from Oracle
function get_source()
printf $OK"Getting the VirtualBox source RPM from the Oracle download site..."$RST
    remove_source
    curl
-Os $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
"Getting the VirtualBox Extension Pack source file..."$RST
    curl
-Os $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
# The script run has completed. Print a short message stating same.
function script_complete()
#remove_source
printf $OKB"Oracle VirtualBox is now installed.\n"
printf $OKB"Script run complete.\n"$RST
# The test script run has completed.
function script_test_complete()
remove_source
    printf $OKB
"This script test is now complete.\n"
#printf $OKB"All necessary Fedora packages are installed.\n"$RST
# Script execution has been cancelled by the user.
function script_cancel()
clear
    printf $OK
"Script execution cancelled.\n"$RST
# Testing only. Show value of all variables
function show_vars()
        echo
printf $OK"VB_REL_VER is $OKB$VB_REL_VER\n"$RST
        printf $OK
"VB_EXT_VER is $OKB$VB_EXT_VER\n"$RST
        printf $OK
"VB_REL_DIST is $OKB$VB_REL_DIST\n"$RST
        printf $OK
"VBOX_SRC_FILE is $OKB$VBOX_SRC_FILE\n"$RST
        printf $OK
"VBOX_EXT_SRC is $OKB$VBOX_EXT_SRC\n"$RST
        printf $OK
"SRC_PATH is $OKB$SRC_PATH\n"$RST
function
testonly()
clear
printf $ERRB
"===== TEST ONLY. NO PACKAGES ARE BEING INSTALLED.=====\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n/t/v> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
        remove_source
           script_complete
n)    script_cancel
exit 0
# Test menu entry used for development. End user should ignore this menu option.
# All this does is test for missing packages and test the download process for VirtualBox and GuestAdditions.
t)     testonly
        get_release
           test_get_packages
           get_source
# All this does is show the current value of all of the variables.
v)  get_release
        show_vars
script_cancel
exit 0
esac
menu    # Call the main menu.
So, while I'm not the most elegant script writer, it works. There are a few tweaks that I'd like to make. Just can't figure out how. Maybe I'll request some help soon.
Glenn
The Bassinator
Old 17th December 2016, 11:06 PM
glennzo Offline
Latest working script. Fedora 25.
PHP Code:
#!/bin/bash
# 25_oracle_virtualbox.sh
# This script is for Fedora 25 only at this time
# Glenn A. Johnson
# Updated December 11, 2016
<< COMMENT
COMMENT
<< COMMENT
kernel-devel-$(uname -r), curl gccqtqt-x11libpng15libXmulibXtlibvpxcompat-libvpx1dkmsSDL and wget
qt5
-qtx11extras (this brings in other packages like qt5-qtbase qt5-qtbase-gui amongst others)
libpython2.7.so.1.0()(64bit) - WellFedora 24 ships with Python35
python
(abi) = 2.7 WellFedora 24 ships with Pythin35
COMMENT
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel curl dkms gcc libpng15 libXmu libXt libvpx qt qt-x11 qt5-qtx11extras SDL wget"
else
PACKFILES="kernel-devel-$(uname -r) curl dkms gcc libpng15 libXmu libXt libvpx qt qt-x11 qt5-qtx11extras SDL wget"
fi
curl_installed=$(rpm -qa grep curl)
if [[ !
$curl_installed ]] ; then
    printf
"Installing package curl. Please wait ..."
dnf --q install curl
echo
fi
curl
echo
$current_version
rm LATEST
.TXT
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.1.10/VirtualBox-5.1-5.1.10_112026_fedora25-1.x86_64.rpm[/url]
VB_REL_VER="5.1-"$current_version"_112026"
VB_EXT_VER="$current_version"-112026
VB_REL_DIST
="fedora25-1"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
# Redhat derivatives and release 24 only
    if [[ ! -
/etc/redhat-release ]] ; then
    printf $ERRB
"This script is for Redhat derivatives only.\n"$RST
exit 0
else
    RELNUM
    if [[
$RELNUM -lt "25" ]] ; then #!= "24"
clear
        printf $ERR
"This script is for Fedora release 25 only.\n"$RST
exit 0
fi
fi
echo
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora Linux.\n"$RST
    printf $OK
    printf $OK
    for
rm -f $i
    done
if [[
    printf $OK
    dnf
    printf $OKB
" ✓\n\n"$RST
fi
curl_installed=$(rpm -qa grep curl )
if [[ !
    printf $OK
"Installing package curl. Please wait ..."$RST
    dnf
--q install curl
echo
fi
printf $OK
"Installing the Oracle public key ... ✓\n"$RST
curl
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    dnf
else
fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo
else
echo
fi
    remove_source
    curl
    printf $OKB
" ✓\n"$RST
    printf $OK
    curl
    printf $OKB
" ✓\n"$RST
echo
#remove_source
remove_source
    printf $OKB
clear
    printf $OK
        echo
        printf $OK
        printf $OK
        printf $OK
        printf $OK
        printf $OK
function
testonly()
clear
printf $ERRB
# Main script flow
function menu()
clear
#get_release
headline
printf $OK
printf $OKB
"\nShall we continue? <y/n> "$RST
read yn
case $yn in
    y
)    remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
        remove_source
           script_complete
n)    script_cancel
exit 0
t)     testonly
        test_get_packages
           get_source
v)      show_vars
script_cancel
exit 0
esac
Glenn
The Bassinator
Old 16th May 2017, 01:15 AM
glennzo Offline
Latest update to the install script.
PHP Code:
#!/bin/bash
# This script is for Fedora 25 and up
# Glenn A. Johnson
# Updated May 14, 2017
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 25 or later.
Additional packages needed for a successful install of VirtualBox over the different platformsx86_64i686 and i686+PAE include
kernel-devel-$(uname -r), curl gccqtqt-x11libpng15libXmulibXtlibvpxcompat-libvpx1SDL and wget
qt5-qtx11extras (this brings in other packages like qt5-qtbase qt5-qtbase-gui amongst others)
COMMENT
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel curl gcc libpng15 libXmu libXt libvpx qt qt-x11 qt5-qtx11extras SDL wget"
else
PACKFILES="kernel-devel-$(uname -r) curl gcc libpng15 libXmu libXt libvpx qt qt-x11 qt5-qtx11extras SDL wget"
fi
# Determine the newest available version of VirtualBox
if [[ !
    printf
echo
fi
curl
echo
$current_version
rm LATEST
.TXT
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.1.22/VirtualBox-5.1-5.1.22_115126_fedora25-1.x86_64.rpm[/url]
VB_REL_VER="5.1-"$current_version"_115126"
VB_EXT_VER="$current_version"-115126
VB_REL_DIST
="fedora25-1"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
# Redhat and derivatives - release 25 only
    if [[ ! -
    printf $ERRB
exit 0
else
    RELNUM
    if [[
        clear
        printf $ERR
exit 0
fi
fi
echo
function headline()
clear
    printf $OK
    printf $OK
    printf $OK
    for
rm -f $i
    done
if [[
    printf $OK
    dnf
    printf $OKB
" ✓\n\n"$RST
fi
if [[ !
    printf $OK
    dnf
--q install curl
echo
fi
printf $OK
curl
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE --quiet
else
exit 0
    fi
    if [[ -
--replace --accept-license=715c7246dc0f779ceab39446812362b2f9bf64a55ed5d3a905f053cfab36da9e $VBOX_EXT_SRC
else
    fi
# License accepted. For batch installaltion add
# --accept-license=715c7246dc0f779ceab39446812362b2f9bf64a55ed5d3a905f053cfab36da9e
# to the VBoxManage command line.
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    dnf
else
fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo
else
echo
fi
    remove_source
    curl
    printf $OKB
" ✓\n"$RST
    printf $OK
    curl
    printf $OKB
" ✓\n"$RST
echo
#remove_source
remove_source
    printf $OKB
clear
    printf $OK
        echo
        printf $OK
        printf $OK
        printf $OK
        printf $OK
        printf $OK
function
testonly()
clear
printf $ERRB
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest installed kernel and run this script again.\n"$RST
printf $OKB
read yn
case $yn in
    y
)    remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
        remove_source
           script_complete
n)    script_cancel
exit 0
t)     testonly
        test_get_packages
           get_source
v)      show_vars
script_cancel
exit 0
esac
Glenn
The Bassinator
installation, oracle, script, virtualbox
oracle virtualbox not working pythonkr11 Wibble 1 7th September 2012 07:48 PM
oracle virtualbox not working pythonkr11 Fedora Focus 1 7th September 2012 07:20 PM
Oracle Virtualbox clueless Using Fedora 5 17th May 2011 10:39 AM
[SOLVED] oracle vm virtualbox postmanpat Using Fedora 5 24th November 2010 11:51 AM
Update Oracle VM VirtualBox error JValeck Using Fedora 2 12th October 2010 05:42 AM
Current GMT-time: 08:40 (Friday, 23-06-2017)
