  #61
Old 13th November 2015, 10:04 AM
glennzo Offline
Un-Retired Administrator
windows_98_nt_2000firefox
Re: Oracle VirtualBox installation script
I honestly think that the problem is with VirtualBox and not the script.
Run the script again but this time choose the "t" option. This will tell you if all necessary packages are installed / were installed.
The "t" option makes no changes to your system. It is merely a simple test.
Glenn
The Bassinator
Old 13th November 2015, 10:17 AM
MrNice Offline
===== TEST ONLY. NO PACKAGES ARE BEING INSTALLED.=====
Checking Fedora release version... Fedora 22 ✓
Checking for necessary packages...
==> kernel-devel-4.2.5-201.fc22.x86_64: ✓
==> gcc: ✓
==> qt: ✓
==> qt-x11: ✓
==> libpng15: ✓
==> libXmu: ✓
==> libXt: ✓
==> libvpx: ✓
==> dkms: ✓
==> SDL: ✓
==> Nothing new to install.
I'll upgrade and see if it's better. I'll let you know
Old 13th November 2015, 10:28 AM
glennzo Offline
As you wish.
Glenn
The Bassinator
Old 15th November 2015, 02:39 PM
MrNice Offline
Hi glennzo,
I am back with
uname -r
4.2.5-300.fc23.x86_64
I changed the script
VB_REL_VER="5.0-"$current_version"_104061"
VB_EXT_VER="$current_version"-104061
Unfortunately I still get the same error
Creating group 'vboxusers'. VM users must be member of that group!
No precompiled module for this kernel found -- trying to build one. Messages
emitted during module compilation will be logged to /var/log/vbox-install.log.
Stopping VirtualBox kernel modules                         [  OK  ]
Uninstalling old VirtualBox DKMS kernel modules            [  OK  ]
Trying to register the VirtualBox kernel modules using DKMS[  OK  ]
Starting VirtualBox kernel modules                         [FAILED]
  (modprobe vboxdrv failed. Please use 'dmesg' to find out why)
Installing Oracle VirtualBox extension pack.
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
         available for the current kernel (4.2.5-300.fc23.x86_64) or it failed to
         load. Please recompile the kernel module and install it by
           sudo /sbin/vboxconfig
         You will not be able to start VMs until this problem is fixed.
0%...10%...20%...30%...40%...50%...60%...70%...80%...90%...100%
Successfully installed "Oracle VM VirtualBox Extension Pack".
Oracle VirtualBox is now installed.
Script run complete.
 dmesg | tail
[20976.027872] audit: type=1131 audit(1447597569.939:311): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21023.383106] audit: type=1107 audit(1447597617.337:312): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.383693] audit: type=1107 audit(1447597617.338:313): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.432143] audit: type=1107 audit(1447597617.386:314): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.432382] audit: type=1107 audit(1447597617.387:315): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.475104] audit: type=1107 audit(1447597617.429:316): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.475342] audit: type=1107 audit(1447597617.430:317): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.853701] audit: type=1107 audit(1447597617.808:318): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.854016] audit: type=1107 audit(1447597617.809:319): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[21023.982420] audit: type=1107 audit(1447597617.937:320): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='Unknown permission stop for class system exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
Any idea?
Old 15th November 2015, 03:17 PM
MrNice Offline
I found this thread
https://forums.virtualbox.org/viewtopic.php?f=7&t=69356
Look at the last post
Solved it. I just had to change the boot mode from 'UEFI' to 'UEFI with CSM'. Virtualbox now works fine.
I'll find how is my boot.
What do you think?
Old 15th November 2015, 04:15 PM
glennzo Offline
Boot mode where, in the system BIOS?
Glenn
The Bassinator
Old 15th November 2015, 04:33 PM
glennzo Offline
On my new EFI/UEFI laptop, minutes ago.
Glenn
The Bassinator
Old 15th November 2015, 04:56 PM
MrNice Offline
I can't find CSM, moreover this could jeopardize the security.
Old 15th November 2015, 08:23 PM
MrNice Offline
I found another track
http://gorka.eguileor.com/category/technology/linux/
$ su -c 'systemctl status vboxdrv'
Password:
● vboxdrv.service - VirtualBox Linux kernel module
   Loaded: loaded (/usr/lib/virtualbox/vboxdrv.sh; enabled; vendor preset: disabled)
   Active: active (exited) since Sun 2015-11-15 18:26:54 GMT; 1h 30min ago
  Process: 866 ExecStart=/usr/lib/virtualbox/vboxdrv.sh start (code=exited, status=0/SUCCESS)
Nov 15 18:26:54 bla.bla systemd[1]: Starting VirtualBox Linux kernel module...
Nov 15 18:26:54 bla.bla vboxdrv.sh[866]: Starting VirtualBox kernel modules [FAILED]
Nov 15 18:26:54 bla.bla vboxdrv.sh[866]: (modprobe vboxdrv failed. Please use 'dmesg' to find out why)
Nov 15 18:26:54 bla.bla systemd[1]: Started VirtualBox Linux kernel module.
 $ su -c 'modprobe -v vboxdrv'
Password:
insmod /lib/modules/4.2.5-300.fc23.x86_64/extra/vboxdrv.ko
modprobe: ERROR: could not insert 'vboxdrv': Required key not available
openssl req -new -x509 -newkey rsa:2048 -keyout MOK.priv -outform DER -out MOK.der -nodes -days 36500 -subj "/CN=Akrog/"
Generating a 2048 bit RSA private key
writing new private key to 'MOK.priv'
$ modinfo vboxdrv
filename:       /lib/modules/4.2.5-300.fc23.x86_64/extra/vboxdrv.ko
version:        5.0.10 (0x00240000)
license:        GPL
description:    Oracle VM VirtualBox Support Driver
author:         Oracle Corporation
srcversion:     342F9F95905EFBCEFD26E63
depends:
vermagic:       4.2.5-300.fc23.x86_64 SMP mod_unload
signer:         Akrog
sig_key:        CE:CF:93:26:C4:B3:A7:3F:47:BC:CF:EE:DB:CD:1B:A3:13:FA:B8:C1
sig_hashalgo:   sha256
parm:           force_async_tsc:force the asynchronous TSC mode (int)
$ su -c '/usr/src/kernels/$(uname -r)/scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n vboxdrv)'
$ modinfo vboxdrv
license:        GPL
depends:
signer:         Akrog
sig_key:        01:48:C2:35:2B:E2:F3:51:C1:E3:79:89:06:93:01:72:7D:F7:FA:BA
$ mokutil --import MOK.der
input password:
input password again:
Failed to enroll new keys
ATTENTION:
This last command need to be run as root !!!
$ su -c 'mokutil --import MOK.der'
I don't know what is the last requested password. Is it a new to set or a previous to access rights?
MokManager.efi is installed in boot partition.
What did I miss?
Last edited by MrNice; 16th November 2015 at 08:30 AM. Reason: Correct the command line
Old 16th November 2015, 08:09 AM
MrNice Offline
I found the answer of my previous question
https://access.redhat.com/documentat...cure-boot.html
26.8.4.3. System Administrator Manually Adding Public Key to the MOK List
However I am wondering why I have to do all that manually. This should be done by the system in the same way here
https://ask.fedoraproject.org/en/que...roll-new-keys/
Where is my mistake?
Edit:
Second answer
https://ask.fedoraproject.org/en/que...o-write-mokpw/
mokutil needs to be run as root, have you tried sudo?
Did it, accepted, now I'll reboot
Edit 2:
In the boot, I had a new screen to enroll the key. I had to enter the MOK password created with mokutil then reboot.
Now Virtualbox is running fine.
I hope I'll NOT have to do this every time I'll have an update...
However I have the way to do.
At least solved for now.
Hope this will help other.
Many thanks glennzo for your help
Old 9th January 2016, 03:35 PM
glennzo Offline
Latest version of my script. Tested minutes ago for Fedora 23 / LXDE / X86_64.
PHP Code:
#!/bin/bash
# 22_oracle_virtualbox.sh
# Glenn A. Johnson
# Started January 18, 2015
# Updated January 9, 2016
# A tip of the fedora to Fedora Forum members Sea, Skull One, marko, Dangermouse
# for help with code
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 22 or later.
Install the Oracle VirtualBox Extension Pack.
Handle all platformsi686PAE and x86_64 .
Clean up when finished.
Remove previously installed VirtualBox.
Support color no color (sudo NOCOLOR=1 22_oracle_virtualbox.sh)
Additional packages needed for a successful install of VirtualBox over the different platformsx86_64i686 and i686+PAE include
kernel-devel-$(uname -r), gccqtqt-x11libpng15libXmulibXtlibvpxcompat-libvpx1dkms, and SDL
COMMENT
# Determine OS platform and install correct packages.
# PAE or no?
GETVERS=$(uname -grep "PAE")
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx compat-libvpx1 dkms SDL"
else
PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx compat-libvpx1 dkms SDL"
fi
# Determine the current version of VirtualBox
curl -Os [url]http://download.virtualbox.org/virtualbox/LATEST.TXT[/url]
current_version=$(cat LATEST.TXT)
echo
$current_version
rm LATEST
.TXT
# We can easily make changes to the source file versions by changing a few variables below.
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.0.10/VirtualBox-5.0-5.0.10_104815_fedora22-1.x86_64.rpm[/url]
# [url]http://download.virtualbox.org/virtualbox/5.0.10/VirtualBox-5.0-5.0.10_104815_fedora22-1.x86_64.rpm[/url]
VB_REL_VER="5.0-"$current_version"_104815"
VB_EXT_VER="$current_version"-104815
VB_REL_DIST
="fedora22-1"
VBOX_SRC_FILE="VirtualBox-${VB_REL_VER}_${VB_REL_DIST}."`uname -m`".rpm"
VBOX_EXT_SRC="Oracle_VM_VirtualBox_Extension_Pack-${VB_EXT_VER}.vbox-extpack"
SRC_PATH="http://download.virtualbox.org/virtualbox/$current_version"
PUB_KEY="oracle_vbox.asc"
# Color definitions; the variables are null if the option NOCOLOR is set.
# Thanks Skull One!
if [ -"$NOCOLOR]; then
    OKB
=$(tput bold;tput setaf 6)
OK=$(tput setaf 6)
ERRB=$(tput bold;tput setaf 1)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
# Need elevated permissions at some point, might as well do it now.
if [[ $EUID -ne 0 ]] ; then
    clear
       printf $OK
"You're going to need elevated permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 22 or later
function get_release()
printf $OK"Checking Fedora release version... "$RST
    RELNUM
=$(rpm -qa --queryformat '%{version}\n' fedora-release)
    if [[
$RELNUM -lt "22" ]] ; then
        clear
        printf $ERR
"This script is for Fedora release 22 or later.\n"$RST
exit 0
else printf $OK"Fedora $RELNUM $OKB✓"$RST
fi
echo
# Clear screen and print a headline.
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 22.\n"$RST
    printf $OK
"==>$OKB Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
    printf $OK
"==>$OKB VirtualBox release $VB_REL_VER\n"$RST
# Remove Oracle VirtualBox source files if they exist in the current working directory.
function remove_source()
    for
i in $VBOX_SRC_FILE $VBOX_EXT_SRC $PUB_KEY; do
rm -f $i
    done
# Remove any installed version of VirtualBox.
function remove_fed_vbox()
VBOX_INSTALLED=$(rpm -qa grep VirtualBox)
if [[
$VBOX_INSTALLED ]] ; then
    printf $OK
"Removing previously installed instance of VirtualBox. Please wait..."$RST
    dnf
--q erase $VBOX_INSTALLED 2>/dev/null
    printf $OKB
" ✓\n\n"$RST
fi
# Download and import the Oracle public key.
function get_public_key()
printf $OK"Installing the Oracle public key.\n"$RST
curl
-Os https://www.virtualbox.org/download/$PUB_KEY
rpm --import $PUB_KEY
# Install Oracle VirtualBox from the downloaded source RPM.
function install_source()
    if [[ -
f $VBOX_SRC_FILE ]] ; then
        printf $OK
"Installing Oracle VirtualBox\n"$RST
        rpm
-Uvh $VBOX_SRC_FILE
else
printf $ERR"The source file missing.\nThere was an error downloading the file.\n"$RST
exit 0
    fi
# Install the Oracle VirtualBox Extension Pack.
function install_extpack()
    if [[ -
f $VBOX_EXT_SRC ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack."$RST
        VBoxManage extpack install
--replace $VBOX_EXT_SRC
else
printf $ERR"Oracle VirtualBox extension pack source file missing!\n"$RST
    fi
# Get any Fedora packages typically needed to complete the VirtualBox installation without errors.
function get_packages()
printf $OK"Checking for necessary packages..."$RST
echo
NEWPKGS=""
for i in $PACKFILES ; do
printf $OK"==> $i: "
rpm -q $i > /dev/null
if [ $? -eq 0 ] ; then
        printf $OKB
"✓\n"$RST
else
printf $ERR"✗\n"$RST
        NEWPKGS
="${NEWPKGS} $i"
fi
done
if [ -"${NEWPKGS}]; then
echo --n $OK"==> Installing necessary packages$OKB "${NEWPKGS}"... "$RST
    dnf
--q install ${NEWPKGS2>/dev/null
echo -e $OKB"\nDone installing packages.\n"$RST
else
printf $OK"==>$OKB Nothing new to install.\n"$RST
fi
# Test retrieval of any Fedora packages typically needed to complete the VirtualBox installation without errors.
function test_get_packages()
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo --n $OK"==> Packages that need to be installed are: $OKB "${NEWPKGS}"... "$RST
echo
else
echo
fi
# Get the VirtualBox source files from Oracle
function get_source()
printf $OK"Getting the VirtualBox source RPM from the Oracle download site..."$RST
    remove_source
    curl
-Os $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
"Getting the VirtualBox Extension Pack source file..."$RST
    curl
-Os $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
# The script run has completed. Print a short message stating same.
function script_complete()
#remove_source
printf $OKB"Oracle VirtualBox is now installed.\n"
printf $OKB"Script run complete.\n"$RST
# The test script run has completed.
function script_test_complete()
remove_source
    printf $OKB
"This script test is now complete.\n"
#printf $OKB"All necessary Fedora packages are installed.\n"$RST
# Script execution has been cancelled by the user.
function script_cancel()
clear
    printf $OK
"Script execution cancelled.\n"$RST
# Testing only. Show value of all variables
function show_vars()
        echo
printf $OK"VB_REL_VER is $OKB$VB_REL_VER\n"$RST
        printf $OK
"VB_EXT_VER is $OKB$VB_EXT_VER\n"$RST
        printf $OK
"VB_REL_DIST is $OKB$VB_REL_DIST\n"$RST
        printf $OK
"VBOX_SRC_FILE is $OKB$VBOX_SRC_FILE\n"$RST
        printf $OK
"VBOX_EXT_SRC is $OKB$VBOX_EXT_SRC\n"$RST
        printf $OK
"SRC_PATH is $OKB$SRC_PATH\n"$RST
function
testonly()
clear
printf $ERRB
"===== TEST ONLY. NO PACKAGES ARE BEING INSTALLED.=====\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n/t/v> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry used for development. End user should ignore this menu option.
# All this does is install missing packages. It also downloads VirtualBox and the Extension Pack.
t)     testonly
        get_release
           test_get_packages
           get_source
# All this does is show the current value of all of the variables.
v)  get_release
        show_vars
script_cancel
exit 0
esac
menu    # Call the main menu.
Glenn
The Bassinator
Old 14th January 2016, 10:21 AM
romu70 Offline
Doesn't work for me Glenn, here is an extract of the output:
Getting the VirtualBox source RPM from the Oracle download site... ✓
Getting the VirtualBox Extension Pack source file... ✓
error: open of <html> failed: No such file or directory
error: open of <head> failed: No such file or directory
Old 17th January 2016, 11:18 AM
glennzo Offline
linuxarchfirefox
Did the virtuabox rpm and the extension pack download as expected? Do those files exist in your working folder?
Possible cause and solution here.
Glenn
The Bassinator
Old 18th January 2016, 11:38 AM
romu70 Offline
Hi Glenn,
I managed to get VB thanks to another way, but here is what I remembered:
- yes, both files (VB and VB Extension Pack) did exist in my home folder
- The VB RPM was not completely downloaded, because at the script crash, the file was less than 60 kB.
Old 19th January 2016, 04:17 AM
roundboy Offline
Hi Glenn,
I had 2 problems with the script, both easy to fix:
1) I cut and past of the script into a 22_oracle_virtualbox.sh file using gedit. The copy included a space at the end of each line. For some reason COMMENT didn't like this. I do not know why. All I did was remove the spaces at the end of lines 11 thru 21.
2) The invocation of curl on line 33 is causing a problem. The copy expands the link's markup. I took out the {url} and {/url} and the script worked for me.
I had fun debugging this script. I haven't done this in at least 10 years and I now know how the rust builds up in the brain.
Great script. Works great. Thanks.
Dave
installation, oracle, script, virtualbox
oracle virtualbox not working pythonkr11 Wibble 1 7th September 2012 07:48 PM
oracle virtualbox not working pythonkr11 Fedora Focus 1 7th September 2012 07:20 PM
Oracle Virtualbox clueless Using Fedora 5 17th May 2011 10:39 AM
[SOLVED] oracle vm virtualbox postmanpat Using Fedora 5 24th November 2010 11:51 AM
Update Oracle VM VirtualBox error JValeck Using Fedora 2 12th October 2010 05:42 AM
Current GMT-time: 18:35 (Sunday, 28-05-2017)
