  #46
Old 22nd September 2015, 10:57 PM
zuser Offline
Re: Oracle VirtualBox installation script
glennzo,
Updated script has failed for the 1st time.
While running it produces a long list of "format" errors and ends with the following:
Installing Oracle VirtualBox extension pack.
./InstallVBox.sh: line 162: VBoxManage: command not found
Oracle VirtualBox is now installed.
Script run complete.
While it states installation is complete, it actually is not. No icon installed and cannot find any new files.
I am running F22_64 workstation (gnome 3)
Any suggestions?
Old 2nd October 2015, 01:55 AM
A1MiXeS Offline
windows_7mozilla
OK, so im new to different operating systems. New to coding,,,, just a basic newb. Ive spent the last two days installing Fedora 22 on Virtualbox host windows 7. Everytime it installs and reboots, it reboots to the installation screen again. It just wont start up. Hopefully this problem can be fixed by noone of that stuff up there ^^^^^^^^ and its something simple i can change in settings. Ive literally fumbled through it to this point using youtube vids and scanning forums. Plese dont write me off i really want to know what im doing, im a quick learner and just need a little help.
Old 2nd October 2015, 09:19 AM
glennzo Online
Un-Retired Administrator
Originally Posted by zuser View Post
glennzo,
Any suggestions?
Sorry, didn't see this post until just now. Have you tried the script in the last few days? I believe the errror(s) were caused by a version mismatch type of issue. The Oracle web page that I pull latest version info from was not updated at the same time VirtualBox was, so for several days it was at 5.0.2 when everything VirtualBox was at 5.0.4. The script has worked well for me once the versioning info was updated on Oracle's end.
Glenn
The Bassinator
Old 2nd October 2015, 09:24 AM
glennzo Online
In the menu, go to Settings>System and move "Hard Disk" to the top of the list. I'm guessing that Optical is currently at the top, hence the constant attempt to install the OS.
Glenn
The Bassinator
Old 2nd October 2015, 03:20 PM
A1MiXeS Offline
windows_7mozilla
Talking Re: Oracle VirtualBox installation script
Bloody Legend mate! Knew it was something simple
Old 4th October 2015, 10:02 AM
glennzo Online
New numbers, new version... Still seems to be working really well for Fedora 22/23.
PHP Code:
#!/bin/bash
# 22_oracle_virtualbox.sh
# Glenn A. Johnson
# Started January 18, 2015
# Updated October 4, 2015
# A tip of the fedora to Fedora Forum members Sea, Skull One, marko, Dangermouse
# for help with code
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 22 only.
Install the Oracle VirtualBox Extension Pack.
Handle all platformsi686PAE and x86_64 .
Clean up when finished.
Remove previously installed VirtualBox.
Support color no color (sudo NOCOLOR=1 22_oracle_virtualbox.sh)
COMMENT
# 10.04.15 - Constantly updating the current VirtualBox versioning numbers.
# 09.13.15 - Adding Fedora 23 to the mix, I think...
# 09.12.15 - Constantly changing VirtualBox versions
# 07.22.15 - Decided to support only the current release of Fedora
# 07.19.15 - No longer need YUM since we're Fedora 21 and later.
# 07.19.15 - Got me a couple errors to deal with ...
# 07.09.15 - Fedora 21 and 22 only. No more Fedora 20.
# 07.09.15 - Version 5.0 ??
# 06.08.18 - Working with the Fedora 22 rpm
# 06.07.17 - Huh?
# 05.14.15 - Add feature to import and install the Oracle public key
# 05.14.15 - Update VirtualBox version to 4.3.28
# 05.12.15 - Test run under Fedora 22 Beta.
# 04.26.15 - Can I add an uninstall (safely) feature?
# 04.26.15 - Testing... 1,2,3
# 03.26.15 - Cosmetic changes and version update
# 03.15.15 - Tested under Fedora 22 Workstation Alpha (x86_64).
# 03.14.15 - New VirtualBox version
# 02.25.15 - Betterer code to discover kernel arch.
# 02.23.15 - New code to discover kernel arch
# 02.22.15 - Seems that kernel arch discovery is not working.
# 02.21.15 - New version of VirtualBox
<< COMMENT
Additional packages needed
for a successful install of VirtualBox over the different platformsx86_64i686 and i686+PAE include
kernel-devel-$(uname -r), gccqtqt-x11libpng15libXmulibXtlibvpxdkms, and SDL
COMMENT
# Determine OS platform and install correct packages.
# PAE or no?
GETVERS=$(uname -grep "PAE")
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms SDL"
else
PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms SDL"
fi
# Determine the current version of VirtualBox
curl -Os [url]http://download.virtualbox.org/virtualbox/LATEST.TXT[/url]
current_version=$(cat LATEST.TXT)
echo
$current_version
rm LATEST
.TXT
# We can easily make changes to the source file versions by changing a few variables below.
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.0.0/VirtualBox-5.0-5.0.0_102096_fedora22-1.x86_64.rpm[/url]
# [url]http://download.virtualbox.org/virtualbox/5.0.6/VirtualBox-5.0-5.0.6_103037_fedora22-1.x86_64.rpm[/url]
VB_REL_VER="5.0-"$current_version"_103037"
VB_EXT_VER="$current_version"-103037
VB_REL_DIST
="fedora22-1"
VBOX_SRC_FILE="VirtualBox-${VB_REL_VER}_${VB_REL_DIST}."`uname -m`".rpm"
VBOX_EXT_SRC="Oracle_VM_VirtualBox_Extension_Pack-${VB_EXT_VER}.vbox-extpack"
SRC_PATH="http://download.virtualbox.org/virtualbox/$current_version"
PUB_KEY="oracle_vbox.asc"
# Color definitions; the variables are null if the option NOCOLOR is set.
# Thanks Skull One!
if [ -"$NOCOLOR]; then
    OKB
=$(tput bold;tput setaf 6)
OK=$(tput setaf 6)
ERRB=$(tput bold;tput setaf 1)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
# Need elevated permissions at some point, might as well do it now.
if [[ $EUID -ne 0 ]] ; then
    clear
       printf $OK
"You're going to need elevated permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 22 or later
function get_release()
printf $OK"Checking Fedora release version... "$RST
    RELNUM
=$(rpm -qa --queryformat '%{version}\n' fedora-release)
    if [[
$RELNUM -lt "22" ]] ; then
        clear
        printf $ERR
"This script is for Fedora release 22 or later.\n"$RST
exit 0
else printf $OK"Fedora $RELNUM $OKB✓"$RST
fi
echo
# Clear screen and print a headline.
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 22.\n"$RST
    printf $OK
"==>$OKB Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
    printf $OK
"==>$OKB VirtualBox release $VB_REL_VER\n"$RST
# Remove Oracle VirtualBox source files if they exist in the current working directory.
function remove_source()
    for
i in $VBOX_SRC_FILE $VBOX_EXT_SRC $PUB_KEY; do
rm -f $i
    done
# Remove any installed version of VirtualBox.
function remove_fed_vbox()
VBOX_INSTALLED=$(rpm -qa grep VirtualBox)
if [[
$VBOX_INSTALLED ]] ; then
    printf $OK
"Removing previously installed instance of VirtualBox. Please wait..."$RST
    dnf
--q erase $VBOX_INSTALLED 2>/dev/null
    printf $OKB
" ✓\n\n"$RST
fi
# Download and import the Oracle public key.
function get_public_key()
printf $OK"Installing the Oracle public key.\n"$RST
curl
-Os https://www.virtualbox.org/download/$PUB_KEY
rpm --import $PUB_KEY
# Install Oracle VirtualBox from the downloaded source RPM.
function install_source()
    if [[ -
f $VBOX_SRC_FILE ]] ; then
        printf $OK
"Installing Oracle VirtualBox\n"$RST
        rpm
-Uvh $VBOX_SRC_FILE
else
printf $ERR"The source file missing.\nThere was an error downloading the file.\n"$RST
exit 0
    fi
# Install the Oracle VirtualBox Extension Pack.
function install_extpack()
    if [[ -
f $VBOX_EXT_SRC ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack."$RST
        VBoxManage extpack install
--replace $VBOX_EXT_SRC
else
printf $ERR"Oracle VirtualBox extension pack source file missing!\n"$RST
    fi
# Get any Fedora packages typically needed to complete the VirtualBox installation without errors.
function get_packages()
printf $OK"Checking for necessary packages..."$RST
echo
NEWPKGS=""
for i in $PACKFILES ; do
printf $OK"==> $i: "
rpm -q $i > /dev/null
if [ $? -eq 0 ] ; then
        printf $OKB
"✓\n"$RST
else
printf $ERR"✗\n"$RST
        NEWPKGS
="${NEWPKGS} $i"
fi
done
if [ -"${NEWPKGS}]; then
echo --n $OK"==> Installing necessary packages$OKB "${NEWPKGS}"... "$RST
    dnf
--q install ${NEWPKGS2>/dev/null
echo -e $OKB"\nDone installing packages.\n"$RST
else
printf $OK"==>$OKB Nothing new to install.\n"$RST
fi
# Test retrieval of any Fedora packages typically needed to complete the VirtualBox installation without errors.
function test_get_packages()
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo --n $OK"==> Packages that need to be installed are: $OKB "${NEWPKGS}"... "$RST
echo
else
echo
fi
# Get the VirtualBox source files from Oracle
function get_source()
printf $OK"Getting the VirtualBox source RPM from the Oracle download site..."$RST
    remove_source
    curl
-Os $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
"Getting the VirtualBox Extension Pack source file..."$RST
    curl
-Os $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
# The script run has completed. Print a short message stating same.
function script_complete()
#remove_source
printf $OKB"Oracle VirtualBox is now installed.\n"
printf $OKB"Script run complete.\n"$RST
# The test script run has completed.
function script_test_complete()
remove_source
    printf $OKB
"This script test is now complete.\n"
printf $OKB"All necessary Fedora packages are installed.\n"$RST
# Script execution has been cancelled by the user.
function script_cancel()
clear
    printf $OK
"Script execution cancelled.\n"$RST
# Testing only. Show value of all variables
function show_vars()
        echo
printf $OK"VB_REL_VER is $OKB$VB_REL_VER\n"$RST
        printf $OK
"VB_EXT_VER is $OKB$VB_EXT_VER\n"$RST
        printf $OK
"VB_REL_DIST is $OKB$VB_REL_DIST\n"$RST
        printf $OK
"VBOX_SRC_FILE is $OKB$VBOX_SRC_FILE\n"$RST
        printf $OK
"VBOX_EXT_SRC is $OKB$VBOX_EXT_SRC\n"$RST
        printf $OK
"SRC_PATH is $OKB$SRC_PATH\n"$RST
function
testonly()
clear
printf $ERRB
"===== TEST ONLY. NO PACKAGES ARE BEING INSTALLED.=====\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n/t/v> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry used for development. End user should ignore this menu option.
# All this does is install missing packages. It also downloads VirtualBox and the Extension Pack.
t)     testonly
        get_release
           test_get_packages
           get_source
# All this does is show the current value of all of the variables.
v)  get_release
        show_vars
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 4th October 2015, 04:08 PM
glennzo Online
Got an error while using the script on a fresh install to a physical machine.
PHP Code:
errorFailed dependencies:
libvpx.so.1()(64bitis needed by VirtualBox-5.0-5.0.6_103037_fedora22-1.x86_64
I solved this by installing compat-libvpx1 and re-running the installation script.
PHP Code:
dnf install compat-libvpx1
This was on a Fedora 23 Mate install. You may not get the same error under Gnome or others.
Glenn
The Bassinator
Old 4th October 2015, 09:00 PM
zuser Offline
unknownfirefox
glennzo,
Thanks for that. I'm away for a few days but will try again when I get back
Old 5th October 2015, 12:30 PM
flyingdutchman Offline
I always install Virtualbox with Autoten from autoten.co.uk it works perfectly.
There is no need to re-invent the wheel.
Have fun!
http://www.aeronetworks.ca
Old 5th October 2015, 01:02 PM
glennzo Online
Helpful. Thanks!
Glenn
The Bassinator
Old 12th November 2015, 05:24 PM
MrNice Offline
I had to update your script to get the last version:
COMMENT
# 10.12.15 - Update to current version VirtualBox-5.0-5.0.10_104061_fedora22-1.x86_64
VB_REL_VER="5.0-"$current_version"_104061"
VB_EXT_VER="$current_version"_104061
However I had a first error and I fixed it by removing the tags in the curl command
# curl -Os http://download.virtualbox.org/virtualbox/LATEST.TXT
echo $current_version
rm LATEST.TXT
The I had a second error and I am stuck:
Updating / installing...
   1:VirtualBox-5.0-5.0.10_104061_fedo################################# [100%]
Creating group 'vboxusers'. VM users must be member of that group!
No precompiled module for this kernel found -- trying to build one. Messages
emitted during module compilation will be logged to /var/log/vbox-install.log.
Stopping VirtualBox kernel modules                         [  OK  ]
Uninstalling old VirtualBox DKMS kernel modules            [  OK  ]
Trying to register the VirtualBox kernel modules using DKMS[  OK  ]
Starting VirtualBox kernel modules                         [FAILED]
  (modprobe vboxdrv failed. Please use 'dmesg' to find out why)
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
         available for the current kernel (4.2.5-201.fc22.x86_64) or it failed to
         load. Please recompile the kernel module and install it by
           sudo /sbin/vboxconfig
         You will not be able to start VMs until this problem is fixed.
VBoxManage: error: RTZipGzipDecompressIoStream failed: VERR_ZIP_BAD_HEADER
VBoxManage: error: Details: code NS_ERROR_FAILURE (0x80004005), component ExtPackFileWrap, interface IExtPackFile, callee nsISupports
VBoxManage: error: Context: "Install(fReplace, __null, ptrProgress.asOutParam())" at line 1156 of file VBoxManageMisc.cpp
dmesg says
[ 3315.864431] audit: type=1130 audit(1447344605.514:222): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vboxballoonctrl-service comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3315.886832] audit: type=1130 audit(1447344605.536:223): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vboxautostart-service comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3315.909387] audit: type=1130 audit(1447344605.559:224): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=vboxweb-service comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3316.162429] audit: type=1106 audit(1447344605.812:225): pid=3235 uid=1000 auid=1000 ses=1 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_xauth acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=pts/0 res=success'
[ 3316.162666] audit: type=1104 audit(1447344605.812:226): pid=3235 uid=1000 auid=1000 ses=1 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=pts/0 res=success'
Could you help me?
Thanks
Old 13th November 2015, 09:14 AM
glennzo Online
First thing that comes to mind is kernel-devel. Is that installed? The script should have installed it, but ...
PHP Code:
gjohnson@toshiba23=> rpm -qa grep kernel-devel
kernel
-devel-4.2.5-300.fc23.x86_64
This script is not the be all to end all. It needs constant tweaking so it will be able to stay with the current version of VirtualBox and the Extension Pack. There is a constant chase to remain current that I don't know how to handle in the script.
I just made a change to the minor version (101573 to 104061) and the script ran flawlessly on a Fedora 22 LXDE virtual machine.
Works for Fedora 23 also, but need to install compat-libvpx1 (at least for LXDE) which was not installed by the script.
There is a minor error under Fedora 23 when the script looks at the Fedora release number but it doesn't negatively affect the script's execution or results.
Glenn
The Bassinator
Old 13th November 2015, 10:35 AM
MrNice Offline
Kernel-devel is installed
rpm -qa | grep kernel-devel
kernel-devel-4.2.5-201.fc22.x86_64
kernel-devel-4.1.7-200.fc22.x86_64
kernel-devel-4.2.3-200.fc22.x86_64
Another idea?
Edit: Maybe I should upgrade to F23 before?
Old 13th November 2015, 10:38 AM
glennzo Online
May be a silly question but, are you running kernel 4.2.5-201? Sometimes we forget that we need to reboot the machine...
Glenn
The Bassinator
Old 13th November 2015, 10:56 AM
MrNice Offline
uname -r
I think so
installation, oracle, script, virtualbox
oracle virtualbox not working pythonkr11 Wibble 1 7th September 2012 07:48 PM
oracle virtualbox not working pythonkr11 Fedora Focus 1 7th September 2012 07:20 PM
Oracle Virtualbox clueless Using Fedora 5 17th May 2011 10:39 AM
[SOLVED] oracle vm virtualbox postmanpat Using Fedora 5 24th November 2010 12:51 PM
Update Oracle VM VirtualBox error JValeck Using Fedora 2 12th October 2010 05:42 AM
Current GMT-time: 11:00 (Wednesday, 29-03-2017)
