  #31
Old 15th May 2015, 12:15 AM
glennzo Online
Un-Retired Administrator
Re: Oracle VirtualBox installation script
OK. Newest version of VirtualBox, 4.3.28
PHP Code:
#!/bin/bash
# 21_oracle_virtualbox.sh
# Install and configure the Oracle version of VirtualBox for Fedora 20 and later.
# Install the Oracle VirtualBox Extension Pack.
# Handle all platforms, i686, PAE and x86_64 .
# Clean up when finished.
# Use DNF for Fedora 21 and up, YUM for Fedora 20 and earlier.
# Remove previously installed VirtualBox.
# Support color / no color (sudo NOCOLOR=1 21_oracle_virtualbox.sh)
# Glenn A. Johnson
# Started January 18, 2015
# Updated May 14, 2015
# 05.14.15 - Add feature to import and install the Oracle public key
# 05.14.15 - Update VirtualBox version to 4.3.28
# 05.12.15 - Test run under Fedora 22 Beta.
# 04.26.15 - Can I add an uninstall (safely) feature?
# 04.26.15 - Testing... 1,2,3
# 03.26.15 - Cosmetic changes and version update
# 03.15.15 - Tested under Fedora 22 Workstation Alpha (x86_64).
# 03.14.15 - New VirtualBox version
# 02.25.15 - Betterer code to discover kernel arch.
# 02.23.15 - New code to discover kernel arch
# 02.22.15 - Seems that kernel arch discovery is not working.
# 02.21.15 - New version of VirtualBox
# A tip of the fedora to Fedora Forum members Sea, Skull One, marko, Dangermouse
# for help with code
# Variables - Additional packages usually needed for a successful install of VirtualBox
# over the different platforms, x86_64, i686 and i686+PAE
#PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms wget SDL"
# Determine OS platform and install correct packages.
# PAE or no?
GETVERS=$(uname -grep "PAE")
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms wget SDL"
else
fi
# We can easily make changes to the source file versions by changing a few variables below.
# Most recent is [url]http://download.virtualbox.org/virtualbox/4.3.28/VirtualBox-4.3-4.3.28_100309_fedora18-1.x86_64.rpm[/url]
VB_REL_VER="4.3-4.3.28_100309"
VB_EXT_VER="4.3.28-100309"
VB_REL_DIST="fedora18-1"
VBOX_SRC_FILE="VirtualBox-${VB_REL_VER}_${VB_REL_DIST}."`uname -m`".rpm"
VBOX_EXT_SRC="Oracle_VM_VirtualBox_Extension_Pack-${VB_EXT_VER}.vbox-extpack"
SRC_PATH="http://download.virtualbox.org/virtualbox/4.3.28"
PUB_KEY="oracle_vbox.asc"
# Color definitions; the variables are null if the option NOCOLOR is set.
# Thanks Skull One!
if [ -"$NOCOLOR]; then
    OKB
=$(tput bold;tput setaf 6)
OK=$(tput setaf 6)
ERRB=$(tput bold;tput setaf 1)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
# Need root permissions at some point, might as well do it now.
if [[ $EUID -ne 0 ]] ; then
    clear
       printf $OK
"You're going to need root permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 20 and later only
function get_release()
printf $OK"Checking Fedora release version... "$RST
    RELNUM
=$(rpm -qa --queryformat '%{version}\n' fedora-release)
    if [[
$RELNUM "20" ]] ; then
        printf $ERR
"\nThis script is for Fedora release 20 and later only.\n"$RST
exit 0
else printf $OK"Fedora $RELNUM $OKB✓"$RST
# Determine if we're going to use dnf or yum.
if [[ $RELNUM "21" ]] ; then
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
# Clear screen and print a headline.
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 20 and up.\n"$RST
    printf $OK
"==>$OKB Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
    printf $OK
"==>$OKB VirtualBox release $VB_REL_VER\n"$RST
# Remove Oracle VirtualBox source files if they exist in the current working directory.
function remove_source()
    for
i in $VBOX_SRC_FILE $VBOX_EXT_SRC $PUB_KEY; do
rm -f $i
    done
# Remove any installed version of VirtualBox.
function remove_fed_vbox()
VBOX_INSTALLED=$(rpm -qa grep VirtualBox)
if [[
$VBOX_INSTALLED ]] ; then
    printf $OK
"Removing previously installed instance of VirtualBox. Please wait..."$RST
    $install_with
--q erase $VBOX_INSTALLED 2>/dev/null
    printf $OKB
" ✓\n\n"$RST
fi
# Download and import the Oracle public key.
function get_public_key()
printf $OK"Installing the Oracle public key.\n"$RST
wget
-q https://www.virtualbox.org/download/$PUB_KEY
rpm --import $PUB_KEY
# Install Oracle VirtualBox from the downloaded source RPM.
function install_source()
    if [[ -
f $VBOX_SRC_FILE ]] ; then
        printf $OK
"Installing Oracle VirtualBox\n"$RST
        rpm
-Uvh $VBOX_SRC_FILE
else
printf $ERR"The source file missing.\nThere was an error downloading the file.\n"$RST
exit 0
    fi
function install_extpack()
    if [[ -
f $VBOX_EXT_SRC ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack."$RST
        VBoxManage extpack install
--replace $VBOX_EXT_SRC
else
printf $ERR"Oracle VirtualBox extension pack source file missing!\n"$RST
    fi
# Get any Fedora packages typically needed to complete the VirtualBox installation without errors.
function get_packages()
printf $OK"Checking for necessary packages..."$RST
echo
NEWPKGS=""
for i in $PACKFILES ; do
printf $OK"==> $i: "
rpm -q $i > /dev/null
if [ $? -eq 0 ] ; then
        printf $OKB
"✓\n"$RST
else
printf $ERR"✗\n"$RST
        NEWPKGS
="${NEWPKGS} $i"
fi
done
if [ -"${NEWPKGS}]; then
echo --n $OK"==> Installing necessary packages$OKB "${NEWPKGS}"... "$RST
    $install_with
--q install ${NEWPKGS2>/dev/null
echo -e $OKB"\nDone installing packages.\n"$RST
else
printf $OK"==>$OKB Nothing new to install.\n"$RST
fi
# Get the VirtualBox source files from Oracle
function get_source()
printf $OK"Getting the VirtualBox source RPM from the Oracle download site..."$RST
    remove_source
    wget
-q $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
"Getting the VirtualBox Extension Pack source file..."$RST
    wget
-q $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
# The script run has completed. Print a short message stating same.
function script_complete()
remove_source
    printf $OKB
"Oracle VirtualBox is now installed.\n"
printf $OKB"Script run complete.\n"$RST
# The test script run has completed.
function script_test_complete()
remove_source
    printf $OKB
"This script test is now complete.\n"
printf $OKB"All necessary Fedora packages are installed.\n"$RST
# Script execution has been cancelled by the user.
function script_cancel()
tput cuu1
    tput el
    printf $OK
"Script cancelled.\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n/t> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
        get_packages
                get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry used for development. End user should ignore this menu option.
# All this does is install missing packages. It also downloads VirtualBox and the Extension Pack.
t)     get_release
           get_packages
           get_source
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 5th June 2015, 11:29 AM
MadmanRB Offline
linuxfedorachrome
Its a no go it seems.
Why cant fedora just use a RPM?
What too busy pushing that piece of crap called boxes?
I think its just time to go to vmware, its too annoying to have to result to using scripts.
Dont have to do that with ubuntu, or OpenSUSE, hell even arch doesnt neerd a rotten script
Insane in the membrane
Old 5th June 2015, 11:08 PM
glennzo Online
linuxarchfirefox
So angry
Glenn
The Bassinator
Old 6th June 2015, 09:45 AM
glennzo Online
The script still works well as of this morning.
On a Fedora 22 host.
Glenn
The Bassinator
Old 6th June 2015, 11:51 AM
marko Offline
Fedora does have a VirtualBox rpm, it's in rpmfusion.
dnf search VirtualBox
Last metadata expiration check performed 0:04:18 ago on Sat Jun  6 06:44:15 2015.
================================ N/S Matched: VirtualBox =================================
VirtualBox.x86_64 : A general-purpose full virtualizer for PC hardware
VirtualBox-devel.x86_64 : VirtualBox SDK
VirtualBox-devel.i686 : VirtualBox SDK
VirtualBox-guest.x86_64 : VirtualBox Guest Additions
python-VirtualBox.x86_64 : Python bindings for VirtualBox
VirtualBox-kmodsrc.x86_64 : VirtualBox kernel module source code
akmod-VirtualBox.x86_64 : Akmod package for VirtualBox kernel module(s)
kmod-VirtualBox.x86_64 : Metapackage which tracks in VirtualBox kernel module for newest
                       : kernel
kmod-VirtualBox-4.0.2-300.fc22.x86_64.x86_64 : VirtualBox kernel module(s) for
                                             : 4.0.2-300.fc22.x86_64
libvirt-daemon-driver-vbox.x86_64 : VirtualBox driver plugin for the libvirtd daemon
RemoteBox.noarch : Open Source VirtualBox Client with Remote Management
libvirt-daemon-vbox.x86_64 : Server side daemon & driver required to run VirtualBox guests
Some people prefer to get the VirtualBox straight from VirtualBox, which is what the script is for
Old 8th July 2015, 01:39 PM
DrewP Offline
Thank you for that. The script worked perfectly for me this morning after having updated my computer to Fedora 22.
In response to a question above it is worth pointing out that the script DOES use an rpm (Oracle's own rpm), but as Oracle chooses not to maintain a repository that follows Fedora conventions the usual tools like yum and dnf cannot use it directly The script takes the pain out of locating, downloading and installling the rpm locally.
I was wondering if you had ever considered reading the contents of
http://download.virtualbox.org/virtualbox/LATEST.TXT into a variable (it's currently 4.3.28)
then parse the result of grepping for the fedora release and architecture in
http://download.virtualbox.org/virtualbox/(variable)/MD5SUMS
(currently http://download.virtualbox.org/virtu...4.3.28/MD5SUMS) to get the name of the file that currently has to be manually assigned to VBOX_SRC_FILE
I appreciate that the same rpm is used for Fedora releases 18,19,20 and 21 so would have to parse for the filename that contains the highest release version less than or equal to the installed Fedora release, which makes the process a bit less trivial than I am trying to make it look.
I think all the other manually assigned variables can be derived from what has been found above.
I wouldn't hesitate to do all the above in perl but my bash scripting is very weak.
It was only when I was reviewing your script to compose this comment that I realized I had concentrated so much on the Oracle numbers in the manually assigned variables that I had forgotten to update the Fedora release to 22.
The script appears to have worked equally well removing the 18 release and installing the 22 release.
I could guarantee you one grateful user if it's possible to assign all those variables programatically.
Thanks again.
Old 9th July 2015, 11:37 PM
glennzo Online
Version 5.0
DrewP. Your request duly noted.
PHP Code:
#!/bin/bash
# Glenn A. Johnson
# Updated July 9, 2015
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 21 and later.
Handle all platformsi686PAE and x86_64 .
 * Use
DNF for Fedora 21 and upYUM for Fedora 20 and earlier.
Support color no color (sudo NOCOLOR=1 21_oracle_virtualbox.sh)
COMMENT
# 07.09.15 - Fedora 21 and 22 only. No more Fedora 20.
# 07.09.15 - Version 5.0 ??
# 06.08.18 - Working with the Fedora 22 rpm
# 06.07.17 - Huh?
<< COMMENT
Additional packages needed
for a successful install of VirtualBox over the different platformsx86_64i686 and i686+PAE include
kernel-devel-$(uname -r), gccqtqt-x11libpng15libXmulibXtlibvpxdkmswget and SDL
COMMENT
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
else
fi
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.0.0/VirtualBox-5.0-5.0.0_101573_fedora22-1.x86_64.rpm[/url]
VB_REL_VER="5.0-5.0.0_101573"
VB_EXT_VER="5.0.0-101573"
VB_REL_DIST="fedora22-1"
SRC_PATH="http://download.virtualbox.org/virtualbox/5.0.0"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
# Release 21 and later only
    RELNUM
    if [[
        printf $ERR
"\nThis script is for Fedora release 21 and later only.\n"$RST
exit 0
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
function headline()
clear
    printf $OK
    printf $OK
    printf $OK
    for
rm -f $i
    done
if [[
    printf $OK
    $install_with
    printf $OKB
" ✓\n\n"$RST
fi
wget
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    $install_with
else
fi
    remove_source
    wget
    printf $OKB
" ✓\n"$RST
    printf $OK
    wget
    printf $OKB
" ✓\n"$RST
echo
remove_source
    printf $OKB
remove_source
    printf $OKB
tput cuu1
    tput el
    printf $OK
# Add a yum repository for Oracle VirtualBox
function add_yum_repo()
if [[ -
f $VBOX_REPO ]] ; then
        printf $OK
"A yum repository for Oracle VirtualBox already exists.\n"$RST
else
printf $OK"Creating a yum repository for Oracle VirtualBox.\n"$RST
    touch $VBOX_REPO
echo "
[virtualbox]
name=Fedora \$releasever - \$basearch - VirtualBox
baseurl=http://download.virtualbox.org/virtualbox/rpm/fedora/\$releasever/\$basearch
enabled=1
gpgcheck=1
gpgkey=https://www.virtualbox.org/download/oracle_vbox.asc"
$VBOX_REPO
fi
# Main script flow
function menu()
clear
headline
printf $OK
printf $OKB
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
t)     get_release
           get_packages
           get_source
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 20th July 2015, 08:26 PM
romu70 Offline
Thanks Glenn for the script. Unfortunately, it doesn't change anything to my problem, I can't get any USB device detected. Here is an example, I've connected a Sony eInk Reader. The lsusb ouput is:
Bus 001 Device 003: ID 054c:05c2 Sony Corp.
But VB says "No peripheral found" when I try to add the reader to my W8 VM. Any idea?
Of course, the extension pack is installed.
Old 21st July 2015, 09:19 AM
glennzo Online
The script was created to help install VirtualBox. As for personal settings / preferences I'm afraid I can't be of much help.
Glenn
The Bassinator
Old 21st July 2015, 09:51 AM
broadstairs Offline
I got the impression from that article that VirtualBox 4.3.30 or above would fix this but I've not yet checked.
Stuart
Old 21st July 2015, 10:03 AM
broadstairs Offline
Just modified the script variables and installed V5.0.5 successfully.
Stuart
Old 15th August 2015, 11:09 AM
glennzo Online
PHP Code:
#!/bin/bash
# Glenn A. Johnson
# Updated August 15, 2015
<< COMMENT
COMMENT
# 08.15.15 - Debug session. Trouble with extended versioning.
# 06.07.17 - Huh?
<< COMMENT
kernel-devel-$(uname -r), gccqtqt-x11libpng15libXmulibXtlibvpxdkms, and SDL
COMMENT
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms SDL"
else
PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms SDL"
fi
# Determine the current version of VirtualBox
curl -Os [url]http://download.virtualbox.org/virtualbox/LATEST.TXT[/url]
current_version=$(cat LATEST.TXT)
rm LATEST.TXT
# Most recent is [url]http://download.virtualbox.org/virtualbox/5.0.0/VirtualBox-5.0-5.0.0_102096_fedora22-1.x86_64.rpm[/url]
VB_REL_VER="5.0-"$current_version"_102096"
VB_EXT_VER="$current_version"-102096
VB_REL_DIST
="fedora22-1"
SRC_PATH="http://download.virtualbox.org/virtualbox/$current_version"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
    RELNUM
    if [[
        printf $ERR
exit 0
fi
echo
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 21 and up.\n"$RST
    printf $OK
    printf $OK
    for
rm -f $i
    done
if [[
    printf $OK
    dnf
    printf $OKB
" ✓\n\n"$RST
fi
curl
-Os https://www.virtualbox.org/download/$PUB_KEY
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    dnf
else
fi
    remove_source
    curl
-Os $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
    curl
-Os $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
remove_source
    printf $OKB
clear
    printf $OK
"Script execution cancelled.\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
printf $OKB
"\nShall we continue? <y/n> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 15th August 2015, 06:03 PM
broadstairs Offline
The only problem I had using this script was that the dkms.conf for the old version of VirtualBox was not removed and caused issues and would not update the kernel modifcations properly until I removed it.
Stuart
Old 15th August 2015, 10:31 PM
glennzo Online
Haven't had that happen to me, at least not yet.
Glenn
The Bassinator
Old 8th September 2015, 09:37 AM
glennzo Online
A minor update to the script this morning. One test run. Worked perfectly.
PHP Code:
#!/bin/bash
# 22_oracle_virtualbox.sh
# Glenn A. Johnson
# Updated September 8, 2015
<< COMMENT
Install and configure the Oracle version of VirtualBox for Fedora 22 only.
Support color no color (sudo NOCOLOR=1 22_oracle_virtualbox.sh)
COMMENT
# 09.08.15 - Minor VirtualBox version change
# 07.22.15 - Decided to support only the current release of Fedora
# 07.19.15 - No longer need YUM since we're Fedora 21 and later.
# 07.19.15 - Got me a couple errors to deal with ...
# 06.07.17 - Huh?
<< COMMENT
COMMENT
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
else
fi
rm LATEST.TXT
VB_REL_DIST
="fedora22-1"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
# Need elevated permissions at some point, might as well do it now.
    clear
       printf $OK
"You're going to need elevated permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 22 only
    RELNUM
    if [[
$RELNUM "22" ]] ; then
        clear
        printf $ERR
"This script is for Fedora release 22 only.\n"$RST
exit 0
fi
echo
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 22.\n"$RST
    printf $OK
    printf $OK
    for
rm -f $i
    done
if [[
    printf $OK
    dnf
    printf $OKB
" ✓\n\n"$RST
fi
curl
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    dnf
else
fi
# Test retrieval of any Fedora packages typically needed to complete the VirtualBox installation without errors.
function test_get_packages()
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
echo --n $OK"==> Packages that need to be installed are: $OKB "${NEWPKGS}"... "$RST
echo
else
echo
fi
    remove_source
    curl
    printf $OKB
" ✓\n"$RST
    printf $OK
    curl
    printf $OKB
" ✓\n"$RST
echo
#remove_source
printf $OKB"Oracle VirtualBox is now installed.\n"
remove_source
    printf $OKB
clear
    printf $OK
# Testing only. Show value of all variables
function show_vars()
        echo
printf $OK"VB_REL_VER is $OKB$VB_REL_VER\n"$RST
        printf $OK
"VB_EXT_VER is $OKB$VB_EXT_VER\n"$RST
        printf $OK
"VB_REL_DIST is $OKB$VB_REL_DIST\n"$RST
        printf $OK
"VBOX_SRC_FILE is $OKB$VBOX_SRC_FILE\n"$RST
        printf $OK
"VBOX_EXT_SRC is $OKB$VBOX_EXT_SRC\n"$RST
        printf $OK
"SRC_PATH is $OKB$SRC_PATH\n"$RST
function
testonly()
clear
printf $ERRB
"===== TEST ONLY. NO PACKAGES ARE BEING INSTALLED. NOTHING IS BEING WRITTEN TO DISK.=====\n"$RST
# Main script flow
function menu()
clear
headline
printf $OK
printf $OKB
"\nShall we continue? <y/n/t/v> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
        get_public_key
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
t)     testonly
        get_release
           test_get_packages
           get_source
# All this does is show the current value of all of the variables.
v)  get_release
        show_vars
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
installation, oracle, script, virtualbox
oracle virtualbox not working pythonkr11 Wibble 1 7th September 2012 07:48 PM
oracle virtualbox not working pythonkr11 Fedora Focus 1 7th September 2012 07:20 PM
Oracle Virtualbox clueless Using Fedora 5 17th May 2011 10:39 AM
[SOLVED] oracle vm virtualbox postmanpat Using Fedora 5 24th November 2010 12:51 PM
Update Oracle VM VirtualBox error JValeck Using Fedora 2 12th October 2010 05:42 AM
Current GMT-time: 12:36 (Monday, 27-03-2017)
