Old 25th January 2015, 03:10 PM
glennzo Online
Un-Retired Administrator
Re: Oracle VirtualBox installation script
Originally Posted by MadmanRB View Post
Just seems odd that virtualbox is this hard to install, sure we have gnome boxes but boxes isnt that good IMHO
I not so sure that it's hard to install, I think some users just don't fully understand what needs to be done for a successful install.
Glenn
The Bassinator
Old 25th January 2015, 03:15 PM
MadmanRB Offline
Eh even I had issues and I am not entirely new to Fedora, the only other distro that I had this much trouble with virtualbox is Arch.
Insane in the membrane
Old 25th January 2015, 03:17 PM
rich1974 Offline
windows_7mozilla
is not that hard, the problem is that the virtualbox from fedora repository got broken when they update the kernel to 3.17.8-300.fc21.i686. using the previous kernel, it works okay!
the problem with this script is that it would have to be updated once the oracle release a new build of virtualbox.
also, this thread would be good to be pinned.
Old 25th January 2015, 03:23 PM
MadmanRB Offline
It also happened on my 64bit build too, still an odd issue.
Old 25th January 2015, 10:45 PM
glennzo Online
Script updated. Now Fedora 18 and 19 friendly. Of course, that wasn't too difficult
PHP Code:
#!/bin/bash
# 21_oracle_virtualbox.sh
# Install and configure the Oracle version of VirtualBox for Fedora 19 and later.
# Install the Oracle VirtualBox Extension Pack.
# Glenn A. Johnson
# Started January 18, 2015
# Updated January 25, 2015
# A tip of the fedora to Fedora Forum members Sea, Skull One, marko, Dangermouse
<< COMMENT
The idea behind this script is to install Oracle VirtualBox
and the Oracle VirtualBox Extension Pack for Fedora systems.
The script will detect and remove any installed version of Fedora VirtualBox.
It will clean up when finished by removing downloaded source files.
It will use DNF for Fedora 21 and upyum otherwise.
Supports color no color.
Does this script handle PAE kernelNot yet.
Guest additions need kernel-devel-$(uname -r) and gcc
COMMENT
# Variables
# Additional packages usually needed for a successful install of VirtualBox
packfiles="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 dkms wget SDL"
# At some point, when Oracle releases an updated RPM, these variables will need to be changed.
vbox_src_file="VirtualBox-4.3-4.3.20_96996_fedora18-1.`uname -m`.rpm"
vbox_ext_src="Oracle_VM_VirtualBox_Extension_Pack-4.3.20-96996.vbox-extpack"
# Color definitions; the variables are null if the option NOCOLOR is set
# Thanks Skull One!
if [ -"$NOCOLOR]; then
        OKB
=$(tput bold;tput setaf 2)
OK=$(tput setaf 2)
ERR=$(tput bold;tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERR=
RST=
fi
# Need root permissions at some point, might as well do it now.
if [[ $EUID -ne 0 ]] ; then
    clear
echo -"You're going to need root permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\""
exit 0
fi
# Release 19 and later only
function get_release()
printf $OK"Checking Fedora release version... "$RST
    relnum
=$(rpm -qa --queryformat '%{version}\n' fedora-release)
    if [[
$relnum "18" ]] ; then
        printf $ERR
"\nThis script is for Fedora release 18 and later only.\nThis appears to be Fedora release $relnum.\n"$RST
exit 0
else printf $OKB" ✓"$RST
# Determine if we're going to use dnf or yum.
if [[ $relnum "21" ]] ; then
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
# Clear screen and print a banner
function banner()
clear
    printf $OKB
"==> VirtualBox installation script for Fedora 18 and up.\n"$RST
    printf $OKB
"==> Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
# Remove Oracle VirtualBox source files if they exist
function remove_source()
    for
i in $vbox_src_file $vbox_ext_src ; do
rm -f $i
    done
# Remove any installed version of VirtualBox
function remove_fed_vbox()
vbox_installed=$(rpm -qa grep VirtualBox)
if [[
$vbox_installed ]] ; then
    printf $OK
"Removing previously installed instance of VirtualBox. Please wait..."$RST
    $install_with
--q erase $vbox_installed 2>/dev/null
    printf $OK
"\nDone.\n"$RST
fi
# Install the downloaded source RPM from Oracle
function install_source()
    if [[ -
f $vbox_src_file ]] ; then
        printf $OK
"Installing Oracle VirtualBox\n"$RST
        rpm
-Uvh $vbox_src_file
else
        echo
$ERR"Source file missing."$RST
exit 0
    fi
# Get any necessary packages needed to complete the VirtualBox installation without errors
function get_packages()
echo -
-n $OK"Checking for necessary packages..."$RST
echo
newpkgs=""
for i in $packfiles ; do
   echo -
-n $OK"==> $i: "
rpm -q $i > /dev/null
if [ $? -eq 0 ] ; then
echo $OKB"✓"$RST
else
        echo
$ERR"✗"$RST
        newpkgs
="${newpkgs} $i"
fi
done
if [ -"${newpkgs}]; then
echo --n $OK"==> Installing ${newpkgs}... "$RST
   $install_with
--q install ${newpkgs2>/dev/null
echo -e $OKB"\nDone installing packages.\n"$RST
else
   echo
$OKB"==> Nothing new to install."$RST
fi
# Get the VirtualBox source RPM from Oracle
function get_source()
    echo -
-n $OK"Getting VirtualBox source from the Oracle download site..."$RST
    remove_source
    wget
-q http://download.virtualbox.org/virtualbox/4.3.20/$vbox_src_file
echo -e $OKB" ✓"$RST
echo --n $OK"Getting the VirtualBox Extension Pack source file..."$RST
    wget
-q http://download.virtualbox.org/virtualbox/4.3.20/$vbox_ext_src
echo
function
install_extpack()
    if [[ -
f $vbox_ext_src ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack"$RST
        VBoxManage extpack install
--replace $vbox_ext_src
else
        echo
$OK"Trying to install the Oracle VirtualBox extension pack but can't find the source file!"$RST
    fi
function
script_complete()
remove_source
        printf $OKB
"Oracle VirtualBox is now installed.\n"
printf $OKB"Script run complete.\n"$RST
function
script_cancel()
tput cuu1
    tput el
    printf $OK
"Script cancelled.\n"$RST
function
menu()
clear
banner
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into to newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n> "$RST
read yn
case $yn in
    y
get_release
        remove_source
        remove_fed_vbox
        get_packages
        get_source
        install_source
        install_extpack
        script_complete
nscript_cancel
exit 0
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 27th January 2015, 01:27 AM
glennzo Online
I'm open to suggestions if anyone feels that the script can be improved.
So far it has proven useful to a couple Fedora users. Hope it helps a few more.
Glenn
The Bassinator
Old 27th January 2015, 11:30 AM
sea Offline
"Shells" (of a sub world)
Originally Posted by glennzo
@ marko. I'm all about how the script looks. ....
Well...
In that case, let me ask, did you like (visualy) my efi-helper script, vhs or alike?
They all use TUI.
Have a preview of what it (or the single commands) could look like: Screenshots/
The installation is 2 lines: https://github.com/sri-arjuna/tui/wiki/Installation.
I've been asked what TUI is about, its about to help others with the task of making a script with an interface.
For example: tui-download would show how much it already downloaded (eg: 5mb, 1gb) (remember my 'game' script with zak mckracken? you pointed that out )
Hope this helps
EFI Cheatsheet :: http://forums.fedoraforum.org/showthread.php?t=298546
Video Handler Script (VHS) (mass re-encode videos, screenrecorder, console music/webradio player, ...) :: http://forums.fedoraforum.org/showthread.php?t=299182
Windows 8+ & Fedora 20+ Dualboot :: http://forums.fedoraforum.org/showthread.php?t=298161
Old 1st February 2015, 09:53 AM
glennzo Online
linuxarchfirefox
The latest version of my script. Works for Fedora 18 and up, I686, I686+PAE and x86_64.
PHP Code:
#!/bin/bash
# Install and configure the Oracle version of VirtualBox for Fedora 20 and later.
# Handle all platforms, i686, PAE and x86_64 .
# Clean up when finished.
# Use DNF for Fedora 21 and up, YUM for Fedora 20 and earlier.
# Remove previously installed VirtualBox.
# Support color / no color (sudo NOCOLOR=1 21_oracle_virtualbox.sh)
# Glenn A. Johnson
# Updated February 27, 2015
# 02.25.15 - Betterer code to discover kernel arch.
# 02.23.15 - New code to discover kernel arch
# 02.22.15 - Seems that kernel arch discovery is not working.
# 02.21.15 - New version of VirtualBox
# for help with code
# Variables - Additional packages usually needed for a successful install of VirtualBox
# over the different platforms, x86_64, i686 and i686+PAE
#PACKFILES="kernel-devel-$(uname -r) gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms wget SDL"
# Determine OS platform and install correct packages.
getvers=$(uname -grep "PAE")
if [[
$getvers ]] ; then
    PACKFILES
="kernel-PAE-devel gcc qt qt-x11 libpng15 libXmu libXt libvpx dkms wget SDL"
else
fi
# We can easily make changes to the source file versions by changing
# a few variables below.
VB_REL_VER="4.3-4.3.22_98236"
VB_EXT_VER="4.3.22-98236"
VB_REL_DIST="fedora18-1"
VBOX_SRC_FILE="VirtualBox-${VB_REL_VER}_${VB_REL_DIST}."`uname -m`".rpm"
VBOX_EXT_SRC="Oracle_VM_VirtualBox_Extension_Pack-${VB_EXT_VER}.vbox-extpack"
SRC_PATH="http://download.virtualbox.org/virtualbox/4.3.22"
#http://download.virtualbox.org/virtualbox/4.3.22/VirtualBox-4.3-4.3.22_98236_fedora18-1.i686.rpm
# Color definitions; the variables are null if the option NOCOLOR is set.
# Thanks Skull One!
        OKB
=$(tput bold;tput setaf 6)
OK=$(tput setaf 6)
ERRB=$(tput bold;tput setaf 1)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
"You're going to need root permissions at some point. Let's get that out of the way now.\nUse \"sudo\" or \"su -c\"\n"$RST
exit 0
fi
# Release 20 and later only
    RELNUM
    if [[
$RELNUM "20" ]] ; then
        printf $ERR
"\nThis script is for Fedora release 20 and later only.\n"$RST
exit 0
else printf $OKB"Fedora $RELNUM ✓"$RST
if [[ $RELNUM "21" ]] ; then
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
# Clear screen and print a headline.
function headline()
clear
    printf $OKB
"==> VirtualBox installation script for Fedora 20 and up.\n"$RST
    printf $OKB
# Remove Oracle VirtualBox source files if they exist in the current working directory.
    for
i in $VBOX_SRC_FILE $VBOX_EXT_SRC ; do
rm -f $i
    done
# Remove any installed version of VirtualBox.
VBOX_INSTALLED=$(rpm -qa grep VirtualBox)
if [[
$VBOX_INSTALLED ]] ; then
    printf $OK
    $install_with
--q erase $VBOX_INSTALLED 2>/dev/null
    printf $OKB
" ✓\n\n"$RST
fi
# Install Oracle VirtualBox from the downloaded source RPM.
    if [[ -
f $VBOX_SRC_FILE ]] ; then
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
printf $ERR"The source file missing.\nThere was an error downloading the file.\n"$RST
exit 0
    fi
function install_extpack()
    if [[ -
f $VBOX_EXT_SRC ]] ; then
echo $OK"Installing Oracle VirtualBox extension pack."$RST
--replace $VBOX_EXT_SRC
else
printf $ERR"Oracle VirtualBox extension pack source file missing!\n"$RST
    fi
# Get any Fedora packages typically needed to complete the VirtualBox installation without errors.
printf $OK"Checking for necessary packages..."$RST
echo
NEWPKGS=""
for i in $PACKFILES ; do
printf $OK"==> $i: "
        printf $OKB
"✓\n"$RST
else
printf $ERR"✗\n"$RST
        NEWPKGS
="${NEWPKGS} $i"
fi
done
if [ -"${NEWPKGS}]; then
echo --n $OK"==> Installing necessary packages$OKB "${NEWPKGS}"... "$RST
#echo "Installing ${NEWPKGS}"
$install_with --q install ${NEWPKGS2>/dev/null
else
printf $OK"==>$OKB Nothing new to install.\n"$RST
fi
# Get the VirtualBox source files from Oracle
printf $OK"Getting VirtualBox source from the Oracle download site..."$RST
    remove_source
    wget
-q $SRC_PATH/$VBOX_SRC_FILE
    printf $OKB
" ✓\n"$RST
    printf $OK
    wget
-q $SRC_PATH/$VBOX_EXT_SRC
    printf $OKB
" ✓\n"$RST
echo
# The script run has completed. Print a short message stating same.
function script_complete()
remove_source
    printf $OKB
# Script execution has been cancelled by the user.
function script_cancel()
tput cuu1
    tput el
    printf $OK
# Main script flow
function menu()
clear
headline
printf $OK
"\nFor this script to succeed you need to be running the newest available and installed kernel.\n\nIf you aren't running the newest available and installed kernel please exit this script\nand update your system. Then boot into the newest kernel and run this script again.\n"$RST
printf $OKB
"\nShall we continue? <y/n/t> "$RST
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry
t)     get_release
           get_packages
           get_source
           script_complete
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 27th February 2015, 12:02 PM
glennzo Online
Has anyone else tried this script? How well did it work? I've tested it fairly extensively on virtual machines, Fedora 21 and 20, x86_64, i686 and i686+PAE. Feedback would be awesome.
Updated code in post #23 as of today.
Disregard the "test" menu option. I needed something that would do some quick testing without doing the full installation.
Glenn
The Bassinator
Old 15th March 2015, 10:46 PM
glennzo Online
Minor code updates and tested for Fedora 22 Workstation Alpha x86_64.
PHP Code:
#!/bin/bash
# Glenn A. Johnson
# Updated March 15, 2015
# 03.15.15 - Tested under Fedora 22 Workstation Alpha (x86_64).
# 03.14.15 - New VirtualBox version
GETVERS=$(uname -grep "PAE")
if [[
$GETVERS ]] ; then
    PACKFILES
else
fi
VB_REL_VER="4.3-4.3.24_98716"
VB_EXT_VER="4.3.24-98716"
SRC_PATH="http://download.virtualbox.org/virtualbox/4.3.24"
# Thanks Skull One!
        OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
    RELNUM
    if [[
        printf $ERR
exit 0
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
function headline()
clear
    printf $OK
"==>$OKB VirtualBox installation script for Fedora 20 and up.\n"$RST
    printf $OK
"==>$OKB Oracle VirtualBox and Oracle VirtualBox Extension Pack will be installed.\n"$RST
    for
rm -f $i
    done
if [[
    printf $OK
    $install_with
    printf $OKB
" ✓\n\n"$RST
fi
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    $install_with
else
fi
    remove_source
    wget
    printf $OKB
" ✓\n"$RST
    printf $OK
    wget
    printf $OKB
" ✓\n"$RST
echo
remove_source
    printf $OKB
# The test script run has completed.
function script_test_complete()
remove_source
    printf $OKB
"This script test is now complete.\n"
printf $OKB"All necessary Fedora packages are installed.\n"$RST
tput cuu1
    tput el
    printf $OK
# Main script flow
function menu()
clear
headline
printf $OK
printf $OKB
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry
t)     get_release
           get_packages
           get_source
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 29th March 2015, 07:09 PM
medicman2002 Offline
windows_7chrome
Hello, if I could make this work then it would be great. Something in your code would likely correct my install issues. I do not understand at what point I'd use your script though. I am very new to fedora and have limited experience with VMBox. I've DL the latest VMBox (4.3.26) and am on a host Windows 7 64-bit Dell Inspiron laptop. I need to get some version of fedora (my text book uses fedora 13 to show how far behind our professors are) on my VMBox. I've tried already with fedora 21 (worstation) x86 version. I'd like to try with an iso of fedora 13 but don't know where to find that archived file.
Where or how does your script come into play-- and could you tell me generally what I've done incorrectly? I'd appreciate any help at all.
Old 30th March 2015, 09:52 AM
glennzo Online
My script will be of no use to you. It is for a Fedora host.
You need the VirtualBox.exe file for a Windows host. http://download.virtualbox.org/virtu...-98988-Win.exe
Install that along with VirtualBox Extension Pack http://download.virtualbox.org/virtu...8.vbox-extpack. Click on the extension pack file and VirtualBox will open and offer to install it.
Then you need Fedora 13 32 Bit or 64 Bit.
Glenn
The Bassinator
Old 26th April 2015, 01:26 PM
glennzo Online
Has anyone else tried this script? It would be wonderful to get some feedback. Did it work well?
Tested under Fedora 22 Beta x86_64 (virtual machine). Worked well
Still can't upload attachments
Copy and paste. Save as anythingyoulike.sh
Run
PHP Code:
sudo ./anythingyoulike.sh
PHP Code:
#!/bin/bash
# Glenn A. Johnson
# Updated April 26, 2015
# 04.26.15 - Can I add an uninstall (safely) feature?
# 04.26.15 - Testing... 1,2,3
# 03.26.15 - Cosmetic changes and version update
# PAE or no?
if [[
$GETVERS ]] ; then
    PACKFILES
else
fi
# We can easily make changes to the source file versions by changing a few variables below.
# Most recent is http://download.virtualbox.org/virtualbox/4.3.26/VirtualBox-4.3-4.3.26_98988_fedora18-1.x86_64.rpm
VB_REL_VER="4.3-4.3.26_98988"
VB_EXT_VER="4.3.26-98988"
SRC_PATH="http://download.virtualbox.org/virtualbox/4.3.26"
# Thanks Skull One!
    OKB
OK=$(tput setaf 6)
ERR=$(tput setaf 1)
RST=$(tput sgr0)
else
OKB=
OK=
ERRB=
ERR=
RST=
fi
    clear
       printf $OK
exit 0
fi
    RELNUM
    if [[
        printf $ERR
exit 0
        install_with
="yum"
else
install_with="dnf"
fi
fi
echo
function headline()
clear
    printf $OK
    printf $OK
    printf $OK
"==>$OKB VirtualBox release $VB_REL_VER\n"$RST
    for
rm -f $i
    done
if [[
    printf $OK
    $install_with
    printf $OKB
" ✓\n\n"$RST
fi
    if [[ -
        printf $OK
        rpm
-Uvh $VBOX_SRC_FILE
else
exit 0
    fi
    if [[ -
else
    fi
echo
NEWPKGS=""
        printf $OKB
"✓\n"$RST
else
        NEWPKGS
="${NEWPKGS} $i"
fi
done
    $install_with
else
fi
printf $OK"Getting the VirtualBox source RPM from the Oracle download site..."$RST
    remove_source
    wget
    printf $OKB
" ✓\n"$RST
    printf $OK
    wget
    printf $OKB
" ✓\n"$RST
echo
remove_source
    printf $OKB
remove_source
    printf $OKB
tput cuu1
    tput el
    printf $OK
# Main script flow
function menu()
clear
headline
printf $OK
printf $OKB
read yn
case $yn in
    y
)    get_release
        remove_fed_vbox
           get_packages
           get_source
           install_source
           install_extpack
           script_complete
n)    script_cancel
exit 0
# Test menu entry used for development. End user should ignore this menu option.
# All this does is install missing packages. It also downloads VirtualBox and the Extension Pack.
t)     get_release
           get_packages
           get_source
script_cancel
exit 0
esac
menu
Glenn
The Bassinator
Old 14th May 2015, 05:57 PM
zuser Online
windows_98_nt_2000firefox
glennzo:
Thanks again for this. After several upgrades in both kernel and VirtualBox, script continues to work flawlessly. Staying current is sooooo easy.
Old 14th May 2015, 06:08 PM
glennzo Online
windows_xp_2003chrome
You're welcome.
Oddly enough, there is a new version of VirtualBox. I've updated the script for that version but haven't had time to update here. (At work at the moment). I believe, and correct me if I'm wrong, that there is an extremely serious vulnerability with virtual machines run under VirtualBox. Here's an example of what I've read somewhere else.
http://www.zdnet.com/article/venom-s...s-datacenters/
Glenn
The Bassinator
installation, oracle, script, virtualbox
oracle virtualbox not working pythonkr11 Wibble 1 7th September 2012 07:48 PM
oracle virtualbox not working pythonkr11 Fedora Focus 1 7th September 2012 07:20 PM
Oracle Virtualbox clueless Using Fedora 5 17th May 2011 10:39 AM
[SOLVED] oracle vm virtualbox postmanpat Using Fedora 5 24th November 2010 12:51 PM
Update Oracle VM VirtualBox error JValeck Using Fedora 2 12th October 2010 05:42 AM
Current GMT-time: 12:37 (Monday, 27-03-2017)
