Go Back   FedoraForum.org > Fedora 24/25 > Using Fedora
Using Fedora General support for current versions. Ask questions about Fedora that do not belong in any other forum.
  #46
Old 8th October 2016, 05:53 PM
srakitnican Offline
Re: flash-plugin-11.2.202.394-release.x86_64 - is it security update or not ?
$ sudo dnf clean metadata
Old 8th October 2016, 06:03 PM
boycottsystemd Offline
I did
sudo dnf clean all
but it didn't help.
Old 2nd March 2017, 04:53 PM
Previous errors have disappeared (I don't know what caused that), but another error has appeared:
No Match for argument : iio-sensor-proxy-2.1-1.fc24.x86_64
No Match for argument : perl-Memoize-1.03-362.fc24.noarch
Error: No Packages marked for update
Does anyone know please how to fix this ?
Old 2nd March 2017, 05:33 PM
PabloTwo Offline
"Registered User" T-Shirt Winner
No. Because you have provided absolutely no information about what generated the output you have shown.
Old 7th March 2017, 07:22 AM
I've mentioned previous errors which are result of a script placed few posts back: http://www.forums.fedoraforum.org/sh...4&postcount=45
(It's #45 - Is it hard to find it ?)
Old 7th March 2017, 11:34 AM
srakitnican Offline
Well, the thread title is about flash-plugin...
If refreshing dnf cache does not help I guess this is some weird sync issue between mirror and master, it should go away by itself with time.
Old 18th March 2017, 11:09 AM
Refreshing dnf cache didn't help. It should be solved by updating manually too. If it is caused by bug in script http://www.forums.fedoraforum.org/sh...4&postcount=45, I would like to repair it.
Is it safe to run Fedora with these outdated packages ?
security, update
[SOLVED] Can't install flash-plugin 11.1.102-62-release i386 JohnJasonJordan Using Fedora 9 4th February 2015 05:49 AM
F11 x86_64, Firefox 3.5, flash-plugin i386, mozilla-plugin-config bongoman Using Fedora 21 30th July 2009 02:58 AM
Current GMT-time: 09:01 (Thursday, 27-04-2017)
