Go Back   FedoraForum.org > Fedora 24/25 > Using Fedora
Using Fedora General support for current versions. Ask questions about Fedora that do not belong in any other forum.
Old 28th July 2014, 03:04 PM
boycottsystemd Offline
Re: flash-plugin-11.2.202.394-release.x86_64 - is it security update or not ?
Originally Posted by Kobuck View Post
I would be interested in where you picked up that expectation.
How can user learn that
yum update --security
isn't working with non-fedora repositories ?
Old 29th July 2014, 05:39 AM
Kobuck Online
Where did you find the info about the command:
$ yum update --security
So far I haven't been able to find that command is supposed to work.
The only place I can find --security used as an argument is in the " yum updateinfo " command.
We are talking about Fedora 20, right??
Laptop: ASUS K61IC/ Intel T6600 2.20Ghz x2/ 4GB/ 320GB SataII/ NVidia G96M/ F25 x86_64
Tower: GigaByte (990FXA)/ AMD 1100T 3.3Ghz x6/ 16GB/ 3.75TB Sata III/ AMD 6770HD/ F25 x86_64
Bookshelf: Shuttle DS61 (H61)/ i3-3225 3.3Ghz x2/ 16GB/ 320GB Sata II/ Intel HD 4000/ F24 x86_64
Embedded: BeagleBone Blk / ARM AM3358 1 GHz x1/ 512MB/ 2GB eMMC/ PowerVR SGX530/ DEB armv7l
Old 29th July 2014, 08:04 AM
yum -h
and
http://docs.fedoraproject.org/en-US/..._security.html
and here in forum, e.g.
http://forums.fedoraforum.org/showthread.php?t=256421
Yes, Fedora 20
Old 29th July 2014, 05:06 PM
Kobuck Online
The Fedora docs link is from F16 documentation and the forum link dates to 2010.
The current yum man info positions the --security as a "Yum updateinfo" argument.
Also note the "yum-plugin-security" plugin is obsolete:
# yum install yum-plugin-security
Loaded plugins: langpacks, refresh-packagekit
Package yum-plugin-security-1.1.31-18.fc20.noarch is obsoleted by yum-3.4.3-152.fc20.noarch which is already installed
Nothing to do
Rather than looking in Fedora docs, I have been trying to find info in the yum project itself.
 $ yum info yum
Installed Packages
Arch        : noarch
Version     : 3.4.3
Release     : 152.fc20
Repo        : installed
From repo   : updates
Summary     : RPM package installer/updater/manager
URL         : http://yum.baseurl.org/
License     : GPLv2+
Description : Yum is a utility that can check for and automatically download and
            : install updated RPM packages. Dependencies are obtained and
            : downloaded automatically, prompting the user for permission as
            : necessary.
The URL defined in the package is listed as:
However, I question the value of this site given the futures page lists " 2011 goals "
I enjoy taking on your type of question as a way to improve my own understanding of Fedora and the Linux environment in general. It would appear this question is a classic demonstration of the chaos in open development.
My efforts so far are taken on to answer the OP's reasonable question:
How can user learn that .....
So far, no joy in finding comprehensive yum documentation. Lacking that it looks like the fallback of "test and take good notes" is the answer.
Old 7th August 2014, 12:12 PM
linuxubuntufirefox
One thing has been proven:
yum --security update
behaves in different way than
yum update
does.
I was recommended to report this issue in Red Hat Bugzilla and so I did.
Old 8th February 2016, 09:25 PM
What is the situation like in dnf ? Can it download ALL security updates only ?
Old 8th February 2016, 09:50 PM
PabloTwo Offline
"Registered User" T-Shirt Winner
Not sure about that, but you can get a list.
$ sudo dnf --enablerepo=updates-testing updateinfo list security
Last metadata expiration check performed 0:14:21 ago on Mon Feb  8 15:31:53 2016.
FEDORA-2016-a69ee02554 security xulrunner-44.0-1.fc23.x86_64
Since I'm already fully updated from the "updates" repo, I had to enable the "updates-testing" repo to find a hit. Checking the repo for a security specific dnf plugin, I don't see one.
Old 20th February 2016, 12:16 PM
Thank you for reply. I know this command but I'm not sure whether it show all security updates. I think that security of any OS is so important that managing it must be absolutely unequivocal and determinable.
Old 20th March 2016, 09:17 AM
dnf updateinfo list security
yields
bumblebee for fedora Linux 22 - x86_64 - Base                                                             37 kB/s |  14 kB     00:00
RPM Fusion for Fedora 22 - Free - Updates        799 kB/s | 223 kB     00:00
Adobe Systems Incorporated        8.6 kB/s | 1.8 kB     00:00
RPM Fusion for Fedora 22 - Free        722 kB/s | 551 kB     00:00
Fedora 22 - x86_64 - Updates        1.4 MB/s |  22 MB     00:15
Vérification de l'expiration des métadonnées effectuée il y a 0:00:13 sur Sun Mar 20 08:31:26 2016.
FEDORA-2016-962c0d156d sécurité autocorr-en-1:4.4.7.2-3.fc22.noarch
FEDORA-2015-2df40de264 sécurité bind-libs-32:9.10.3-7.P2.fc22.x86_64
FEDORA-2016-1ab53bf440 sécurité bind-libs-32:9.10.3-8.P3.fc22.x86_64
FEDORA-2015-2df40de264 sécurité bind-libs-lite-32:9.10.3-7.P2.fc22.x86_64
FEDORA-2016-1ab53bf440 sécurité bind-libs-lite-32:9.10.3-8.P3.fc22.x86_64
FEDORA-2015-2df40de264 sécurité bind-license-32:9.10.3-7.P2.fc22.noarch
FEDORA-2016-1ab53bf440 sécurité bind-license-32:9.10.3-8.P3.fc22.noarch
FEDORA-2015-2df40de264 sécurité bind-utils-32:9.10.3-7.P2.fc22.x86_64
FEDORA-2016-1ab53bf440 sécurité bind-utils-32:9.10.3-8.P3.fc22.x86_64
FEDORA-2016-1323b9078a sécurité bind99-libs-9.9.8-2.P3.fc22.x86_64
FEDORA-2016-1323b9078a sécurité bind99-license-9.9.8-2.P3.fc22.noarch
FEDORA-2016-6f783d1768 sécurité chrony-2.1.1-2.fc22.x86_64
FEDORA-2015-998911cf3f sécurité cups-filters-1.4.0-1.fc22.x86_64
FEDORA-2015-998911cf3f sécurité cups-filters-libs-1.4.0-1.fc22.x86_64
FEDORA-2016-3fa315a5dd sécurité curl-7.40.0-8.fc22.x86_64
FEDORA-2016-adb533a418 sécurité dhcp-client-12:4.3.2-7.fc22.x86_64
FEDORA-2016-adb533a418 sécurité dhcp-common-12:4.3.2-7.fc22.noarch
FEDORA-2016-adb533a418 sécurité dhcp-libs-12:4.3.2-7.fc22.x86_64
FEDORA-2016-7b9a2fe987 sécurité ecryptfs-utils-109-1.fc22.x86_64
FEDORA-2016-ff39572e31 sécurité exiv2-libs-0.24-5.fc22.x86_64
FEDORA-2016-5b2c402bb1 sécurité firefox-45.0-4.fc22.x86_64
FEDORA-2016-3c0b37e056 sécurité imlib2-1.4.7-1.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-4.4.4-200.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-core-4.4.4-200.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-devel-4.4.4-200.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-headers-4.4.4-200.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-modules-4.4.4-200.fc22.x86_64
FEDORA-2016-746bb5851d sécurité kernel-modules-extra-4.4.4-200.fc22.x86_64
FEDORA-2016-35492207cb sécurité krb5-libs-1.13.2-13.fc22.i686
FEDORA-2016-35492207cb sécurité krb5-libs-1.13.2-13.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité libcacard-2:2.3.1-12.fc22.x86_64
FEDORA-2016-3fa315a5dd sécurité libcurl-7.40.0-8.fc22.x86_64
FEDORA-2016-3d9efe44d8 sécurité libnghttp2-1.7.1-1.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité libsmbclient-2:4.2.9-0.fc22.x86_64
FEDORA-2015-0be7a2e1b8 sécurité libsndfile-1.0.25-18.fc22.i686
FEDORA-2015-0be7a2e1b8 sécurité libsndfile-1.0.25-18.fc22.x86_64
FEDORA-2016-7942ee2cc5 sécurité libssh2-1.5.0-2.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité libwbclient-2:4.2.9-0.fc22.x86_64
FEDORA-2016-8ee88aee21 sécurité nettle-2.7.1-6.fc22.i686
FEDORA-2016-8ee88aee21 sécurité nettle-2.7.1-6.fc22.x86_64
FEDORA-2016-34bc10a2c8 sécurité ntpdate-4.2.6p5-36.fc22.x86_64
FEDORA-2016-c330264861 sécurité openssh-6.9p1-10.fc22.x86_64
FEDORA-2016-c330264861 sécurité openssh-askpass-6.9p1-10.fc22.x86_64
FEDORA-2016-c330264861 sécurité openssh-clients-6.9p1-10.fc22.x86_64
FEDORA-2016-c330264861 sécurité openssh-server-6.9p1-10.fc22.x86_64
FEDORA-2016-e6807b3394 sécurité openssl-1:1.0.1k-14.fc22.x86_64
FEDORA-2016-e6807b3394 sécurité openssl-libs-1:1.0.1k-14.fc22.i686
FEDORA-2016-e6807b3394 sécurité openssl-libs-1:1.0.1k-14.fc22.x86_64
FEDORA-2016-51195e6b92 sécurité openvpn-2.3.10-1.fc22.x86_64
FEDORA-2016-f5af8e27ce sécurité pcre-8.38-3.fc22.i686
FEDORA-2016-f5af8e27ce sécurité pcre-8.38-3.fc22.x86_64
FEDORA-2016-1fb63e3bf3 sécurité perl-4:5.20.3-329.fc22.x86_64
FEDORA-2016-4ca904238f sécurité perl-PathTools-3.47-312.fc22.x86_64
FEDORA-2016-1fb63e3bf3 sécurité perl-Pod-Escapes-1:1.06-329.fc22.noarch
FEDORA-2016-1fb63e3bf3 sécurité perl-libs-4:5.20.3-329.fc22.x86_64
FEDORA-2016-1fb63e3bf3 sécurité perl-macros-4:5.20.3-329.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité qemu-common-2:2.3.1-12.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité qemu-guest-agent-2:2.3.1-12.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité qemu-img-2:2.3.1-12.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité qemu-kvm-2:2.3.1-12.fc22.x86_64
FEDORA-2016-be042f7e6f sécurité qemu-system-x86-2:2.3.1-12.fc22.x86_64
FEDORA-2016-4a21ce89d3 sécurité rsync-3.1.1-7.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-client-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-client-libs-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-common-2:4.2.9-0.fc22.noarch
FEDORA-2016-cad77a4576 sécurité samba-common-libs-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-libs-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-winbind-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-winbind-clients-2:4.2.9-0.fc22.x86_64
FEDORA-2016-cad77a4576 sécurité samba-winbind-modules-2:4.2.9-0.fc22.x86_64
FEDORA-2016-191ff70357 sécurité shotwell-0.23.0-0.1.20160105gitf2fb1f7.fc22.x86_64
FEDORA-2015-6efa349a85 sécurité subversion-libs-1.8.15-1.fc22.x86_64
FEDORA-2016-143a48536c sécurité webkitgtk4-2.10.7-1.fc22.x86_64
FEDORA-2016-f8121efdac sécurité xen-libs-4.5.2-8.fc22.x86_64
FEDORA-2016-38b20aa50f sécurité xen-libs-4.5.2-9.fc22.x86_64
FEDORA-2016-f8121efdac sécurité xen-licenses-4.5.2-8.fc22.x86_64
FEDORA-2016-38b20aa50f sécurité xen-licenses-4.5.2-9.fc22.x86_64
dnf update --security
yields
Vérification de l'expiration des métadonnées effectuée il y a 0:01:36 sur Sun Mar 20 08:31:26 2016.
Aucune correspondance pour l'argument*: --security
Erreur*: Aucun paquet marqué pour mise à jour
Old 20th March 2016, 09:27 AM
dnf update
yields
Vérification de l'expiration des métadonnées effectuée il y a 0:03:21 sur Sun Mar 20 08:31:26 2016.
Dépendances résolues.
 Paquet                                         Architecture
                                                            Version                                    Dépôt                       Taille
Installation de :
 GeoIP                                          x86_64      1.6.5-1.fc22                               fedora                      117 k
 GeoIP-GeoLite-data                             noarch      2015.12-1.fc22                             updates                     381 k
 copy-jdk-configs                               noarch      1.1-3.fc22                                 updates                      18 k
 kernel                                         x86_64      4.4.5-200.fc22                             updates                      78 k
 kernel-core                                    x86_64      4.4.5-200.fc22                             updates                      20 M
 kernel-devel                                   x86_64      4.4.5-200.fc22                             updates                      10 M
 kernel-modules                                 x86_64      4.4.5-200.fc22                             updates                      18 M
 kernel-modules-extra                           x86_64      4.4.5-200.fc22                             updates                     2.2 M
 libnatpmp                                      x86_64      20150609-1.fc22                            updates                      19 k
 libsss_autofs                                  x86_64      1.13.3-5.fc22                              updates                      77 k
 libsss_sudo                                    x86_64      1.13.3-5.fc22                              updates                      75 k
 lua-posix                                      x86_64      33.2.1-1.fc22                              fedora                      171 k
 opusfile                                       x86_64      0.7-1.fc22                                 updates                      51 k
 python2-rsa                                    noarch      3.3-2.fc22                                 updates                      66 k
     remplacement de  python-rsa.noarch 3.1.1-6.fc22
 python2-systemd                                x86_64      231-4.fc22                                 updates                      67 k
     remplacement de  python-systemd.x86_64 230-1.fc23
 sqlite-libs                                    i686        3.11.0-3.fc22                              updates                     464 k
     remplacement de  sqlite.i686 3.9.0-1.fc22
     remplacement de  sqlite.x86_64 3.9.0-1.fc22
 sqlite-libs                                    x86_64      3.11.0-3.fc22                              updates                     449 k
Mise à jour:
 NetworkManager                                 x86_64      1:1.0.10-3.fc22                            updates                     1.9 M
 NetworkManager-adsl                            x86_64      1:1.0.10-3.fc22                            updates                     115 k
 NetworkManager-bluetooth                       x86_64      1:1.0.10-3.fc22                            updates                     136 k
 NetworkManager-config-connectivity-fedora      x86_64      1:1.0.10-3.fc22                            updates                     103 k
 NetworkManager-glib                            x86_64      1:1.0.10-3.fc22                            updates                     369 k
 NetworkManager-libnm                           x86_64      1:1.0.10-3.fc22                            updates                     482 k
 NetworkManager-openconnect                     x86_64      1.0.8-1.fc22                               updates                     326 k
 NetworkManager-openvpn                         x86_64      1:1.0.8-1.fc22                             updates                     193 k
 NetworkManager-openvpn-gnome                   x86_64      1:1.0.8-1.fc22                             updates                      70 k
 NetworkManager-team                            x86_64      1:1.0.10-3.fc22                            updates                     116 k
 NetworkManager-vpnc                            x86_64      1:1.0.8-1.fc22                             updates                     141 k
 NetworkManager-vpnc-gnome                      x86_64      1:1.0.8-1.fc22                             updates                      49 k
 NetworkManager-wifi                            x86_64      1:1.0.10-3.fc22                            updates                     144 k
 NetworkManager-wwan                            x86_64      1:1.0.10-3.fc22                            updates                     136 k
 PyYAML                                         x86_64      3.11-11.fc22                               updates                     168 k
 abrt                                           x86_64      2.6.1-10.fc22                              updates                     532 k
 abrt-addon-ccpp                                x86_64      2.6.1-10.fc22                              updates                     192 k
 abrt-addon-coredump-helper                     x86_64      2.6.1-10.fc22                              updates                     108 k
 abrt-addon-kerneloops                          x86_64      2.6.1-10.fc22                              updates                     124 k
 abrt-addon-pstoreoops                          x86_64      2.6.1-10.fc22                              updates                     103 k
 abrt-addon-python                              x86_64      2.6.1-10.fc22                              updates                     103 k
 abrt-addon-python3                             x86_64      2.6.1-10.fc22                              updates                     102 k
 abrt-addon-vmcore                              x86_64      2.6.1-10.fc22                              updates                     113 k
 abrt-addon-xorg                                x86_64      2.6.1-10.fc22                              updates                     103 k
 abrt-cli                                       x86_64      2.6.1-10.fc22                              updates                      94 k
 abrt-dbus                                      x86_64      2.6.1-10.fc22                              updates                     128 k
 abrt-desktop                                   x86_64      2.6.1-10.fc22                              updates                      94 k
 abrt-gui                                       x86_64      2.6.1-10.fc22                              updates                     191 k
 abrt-gui-libs                                  x86_64      2.6.1-10.fc22                              updates                     103 k
 abrt-libs                                      x86_64      2.6.1-10.fc22                              updates                     121 k
 abrt-plugin-bodhi                              x86_64      2.6.1-10.fc22                              updates                     103 k
 abrt-python                                    x86_64      2.6.1-10.fc22                              updates                     117 k
 abrt-python3                                   x86_64      2.6.1-10.fc22                              updates                     118 k
 abrt-retrace-client                            x86_64      2.6.1-10.fc22                              updates                     130 k
 abrt-tui
continue in next post...
Old 20th March 2016, 09:30 AM
 audacious                                      x86_64      3.6.2-3.fc22                               updates                     296 k
 audacious-libs                                 x86_64      3.6.2-3.fc22                               updates                     259 k
 audit                                          x86_64      2.4.5-1.fc22                               updates                     242 k
 audit-libs                                     i686        2.4.5-1.fc22                               updates                      96 k
 audit-libs                                     x86_64      2.4.5-1.fc22                               updates                      95 k
 audit-libs-python                              x86_64      2.4.5-1.fc22                               updates                      96 k
 autocorr-en                                    noarch      1:4.4.7.2-4.fc22                           updates                     178 k
 babl                                           x86_64      0.1.14-1.fc22                              updates                     294 k
 bash                                           x86_64      4.3.42-3.fc22                              updates                     1.6 M
 bind-libs                                      x86_64      32:9.10.3-8.P3.fc22                        updates                     150 k
 bind-libs-lite                                 x86_64      32:9.10.3-8.P3.fc22                        updates                     1.0 M
 bind-license                                   noarch      32:9.10.3-8.P3.fc22                        updates                      87 k
 bind-utils                                     x86_64      32:9.10.3-8.P3.fc22                        updates                     403 k
 bind99-libs                                    x86_64      9.9.8-2.P3.fc22                            updates                     656 k
 bind99-license                                 noarch      9.9.8-2.P3.fc22                            updates                      12 k
 bluez                                          x86_64      5.36-1.fc22                                updates                     1.2 M
 bluez-cups                                     x86_64      5.36-1.fc22                                updates                      84 k
 bluez-libs                                     x86_64      5.36-1.fc22                                updates                      81 k
 brasero-libs                                   x86_64      3.12.1-3.fc22                              updates                     345 k
 btrfs-progs                                    x86_64      4.3.1-1.fc22                               updates                     567 k
 chkconfig                                      x86_64      1.7-1.fc22                                 updates                     179 k
 chrony                                         x86_64      2.1.1-2.fc22                               updates                     289 k
 cpp                                            x86_64      5.3.1-2.fc22                               updates                     8.3 M
 crda                                           x86_64      3.18_2016.02.08-1.fc22                     updates                      43 k
 cups-filters                                   x86_64      1.4.0-1.fc22                               updates                     671 k
 cups-filters-libs                              x86_64      1.4.0-1.fc22                               updates                     109 k
 curl                                           x86_64      7.40.0-8.fc22                              updates                     280 k
 deja-dup                                       x86_64      34.0-3.1.fc22                              updates                     912 k
 deja-dup-nautilus                              x86_64      34.0-3.1.fc22                              updates                      24 k
 dhcp-client                                    x86_64      12:4.3.2-7.fc22                            updates                     296 k
 dhcp-common                                    noarch      12:4.3.2-7.fc22                            updates                     189 k
 dhcp-libs                                      x86_64      12:4.3.2-7.fc22                            updates                     136 k
 dnf                                            noarch      1.1.6-2.fc22                               updates                     291 k
 dnf-automatic                                  noarch      1.1.6-2.fc22                               updates                      94 k
 dnf-conf                                       noarch      1.1.6-2.fc22                               updates                      91 k
 dnf-plugin-system-upgrade                      noarch      0.7.1-1.fc22                               updates                      49 k
 dnf-plugins-core                               noarch      0.1.16-1.fc22                              updates                      37 k
 dnf-yum                                        noarch      1.1.6-2.fc22                               updates                      85 k
 dnsmasq                                        x86_64      2.75-3.fc22                                updates                     293 k
 ebtables                                       x86_64      2.0.10-18.fc22                             updates                     126 k
 eclipse-emf-core                               x86_64      1:2.11.2-1.fc22                            updates                     1.7 M
 ecryptfs-utils                                 x86_64      109-1.fc22                                 updates                     189 k
 elfutils                                       x86_64      0.165-2.fc22                               updates                     290 k
 elfutils-default-yama-scope                    noarch      0.165-2.fc22                               updates                      38 k
 elfutils-libelf                                i686        0.165-2.fc22                               updates                     218 k
 elfutils-libelf                                x86_64      0.165-2.fc22                               updates                     213 k
 elfutils-libs                                  i686        0.165-2.fc22                               updates                     298 k
 elfutils-libs                                  x86_64      0.165-2.fc22                               updates                     272 k
 enca                                           x86_64      1.18-1.fc22                                updates                     108 k
 eog                                            x86_64      3.16.4-1.fc22                              updates                     3.7 M
 evince                                         x86_64      3.16.1-4.fc22                              updates                     2.3 M
 evince-libs                                    x86_64      3.16.1-4.fc22                              updates                     352 k
 evince-nautilus                                x86_64      3.16.1-4.fc22                              updates                      42 k
 exiv2-libs                                     x86_64      0.24-5.fc22                                updates                     981 k
 ffmpeg-libs                                    x86_64      2.6.8-1.fc22                               rpmfusion-free-updates      5.1 M
 file                                           x86_64      5.22-5.fc22                                updates                      66 k
 file-libs                                      x86_64      5.22-5.fc22                                updates                     423 k
 findutils                                      x86_64      1:4.5.14-6.fc22                            updates                     523 k
 firefox                                        x86_64      45.0-4.fc22                                updates                      73 M
 flash-plugin                                   x86_64      11.2.202.577-release                       adobe-linux-x86_64          6.9 M
 gcc                                            x86_64      5.3.1-2.fc22                               updates                      19 M
 gcc-c++                                        x86_64      5.3.1-2.fc22                               updates                     9.8 M
 gegl03                                         x86_64      0.3.4-2.fc22                               updates                     1.8 M
 gkrellm                                        x86_64      2.3.6-0.1.rc1.git20160226.fc22             updates                     649 k
Old 20th March 2016, 09:32 AM
 glibc                                          i686        2.21-13.fc22                               updates                     4.2 M
 glibc                                          x86_64      2.21-13.fc22                               updates                     3.5 M
 glibc-common                                   x86_64      2.21-13.fc22                               updates                      12 M
 glibc-devel                                    x86_64      2.21-13.fc22                               updates                     904 k
 glibc-headers                                  x86_64      2.21-13.fc22                               updates                     495 k
 glusterfs                                      x86_64      3.6.9-1.fc22                               updates                     1.3 M
 glusterfs-api                                  x86_64      3.6.9-1.fc22                               updates                      74 k
 glusterfs-fuse                                 x86_64      3.6.9-1.fc22                               updates                     103 k
 glusterfs-libs                                 x86_64      3.6.9-1.fc22                               updates                     296 k
 gnome-documents                                x86_64      3.16.5-1.fc22                              updates                     493 k
 gnome-documents-libs                           x86_64      3.16.5-1.fc22                              updates                     224 k
 gnome-online-accounts                          x86_64      3.16.5-1.fc22                              updates                     1.0 M
 gnupg                                          x86_64      1.4.20-1.fc22                              updates                     1.3 M
 gnupg2                                         x86_64      2.1.11-1.fc22                              updates                     1.9 M
 gnutls                                         i686        3.3.21-2.fc22                              updates                     618 k
 gnutls                                         x86_64      3.3.21-2.fc22                              updates                     629 k
 gnutls-dane                                    x86_64      3.3.21-2.fc22                              updates                      37 k
 gnutls-utils                                   x86_64      3.3.21-2.fc22                              updates                     239 k
 grep                                           x86_64      2.21-9.fc22                                updates                     365 k
 gssdp                                          x86_64      0.14.14-1.fc22                             updates                      54 k
 gtk2                                           i686        2.24.29-1.fc22                             updates                     3.4 M
 gtk2                                           x86_64      2.24.29-1.fc22                             updates                     3.4 M
 gtk2-devel                                     x86_64      2.24.29-1.fc22                             updates                     3.0 M
 gtk2-immodule-xim                              x86_64      2.24.29-1.fc22                             updates                      21 k
 gtk3                                           x86_64      3.16.7-2.fc22                              updates                     4.0 M
 gtk3-immodule-xim                              x86_64      3.16.7-2.fc22                              updates                      21 k
 gtksourceview3                                 x86_64      3.16.2-1.fc22                              updates                     931 k
 guile                                          x86_64      5:2.0.11-7.fc22                            updates                     3.9 M
 gupnp                                          x86_64      0.20.16-1.fc22                             updates                      99 k
 gupnp-av                                       x86_64      0.12.8-1.fc22                              updates                      94 k
 gupnp-dlna                                     x86_64      0.10.4-1.fc22                              updates                      89 k
 gvfs                                           x86_64      1.24.3-1.fc22                              updates                     1.1 M
 gvfs-afc                                       x86_64      1.24.3-1.fc22                              updates                      78 k
 gvfs-afp                                       x86_64      1.24.3-1.fc22                              updates                      93 k
 gvfs-archive                                   x86_64      1.24.3-1.fc22                              updates                      46 k
 gvfs-fuse                                      x86_64      1.24.3-1.fc22                              updates                      48 k
 gvfs-goa                                       x86_64      1.24.3-1.fc22                              updates                      62 k
 gvfs-gphoto2                                   x86_64      1.24.3-1.fc22                              updates                      82 k
 gvfs-mtp                                       x86_64      1.24.3-1.fc22                              updates                      81 k
 gvfs-smb                                       x86_64      1.24.3-1.fc22                              updates                      62 k
 hawkey                                         x86_64      0.6.2-2.fc22                               updates                      92 k
 help2man                                       noarch      1.47.3-1.fc22                              updates                     170 k
 hplip-common                                   x86_64      3.15.9-3.fc22                              updates                      97 k
 hplip-libs                                     x86_64      3.15.9-3.fc22                              updates                     184 k
 htop                                           x86_64      2.0.1-1.fc22                               updates                     100 k
 httpd                                          x86_64      2.4.18-1.fc22                              updates                     1.3 M
 httpd-filesystem                               noarch      2.4.18-1.fc22                              updates                      25 k
 httpd-tools                                    x86_64      2.4.18-1.fc22                              updates                      88 k
 hwdata                                         noarch      0.286-1.fc22                               updates                     1.4 M
 ibus                                           x86_64      1.5.11-1.fc22.1                            updates                     371 k
 ibus-gtk2                                      x86_64      1.5.11-1.fc22.1                            updates                      51 k
 ibus-gtk3                                      x86_64      1.5.11-1.fc22.1                            updates                      51 k
 ibus-libpinyin                                 x86_64      1.7.4-1.fc22                               updates                     794 k
 ibus-libs                                      x86_64      1.5.11-1.fc22.1                            updates                     226 k
 ibus-setup                                     noarch      1.5.11-1.fc22.1                            updates                      80 k
 ibus-typing-booster                            noarch      1.3.1-1.fc22                               updates                     150 k
 ibus-wayland                                   x86_64      1.5.11-1.fc22.1                            updates                      46 k
Old 20th March 2016, 09:34 AM
 imlib2                                         x86_64      1.4.7-1.fc22                               updates                     211 k
 iwl100-firmware                                noarch      39.31.5.1-61.fc22                          updates                     154 k
 iwl1000-firmware                               noarch      1:39.31.5.1-61.fc22                        updates                     217 k
 iwl105-firmware                                noarch      18.168.6.1-61.fc22                         updates                     238 k
 iwl135-firmware                                noarch      18.168.6.1-61.fc22                         updates                     247 k
 iwl2000-firmware                               noarch      18.168.6.1-61.fc22                         updates                     241 k
 iwl2030-firmware                               noarch      18.168.6.1-61.fc22                         updates                     250 k
 iwl3160-firmware                               noarch      1:25.30.13.0-61.fc22                       updates                     979 k
 iwl3945-firmware                               noarch      15.32.2.9-61.fc22                          updates                      92 k
 iwl4965-firmware                               noarch      228.61.2.24-61.fc22                        updates                     105 k
 iwl5000-firmware                               noarch      8.83.5.1_1-61.fc22                         updates                     298 k
 iwl5150-firmware                               noarch      8.24.2.2-61.fc22                           updates                     151 k
 iwl6000-firmware                               noarch      9.221.4.1-61.fc22                          updates                     171 k
 iwl6000g2a-firmware                            noarch      18.168.6.1-61.fc22                         updates                     314 k
 iwl6000g2b-firmware                            noarch      18.168.6.1-61.fc22                         updates                     314 k
 iwl6050-firmware                               noarch      41.28.5.1-61.fc22                          updates                     247 k
 iwl7260-firmware                               noarch      1:25.30.13.0-61.fc22                       updates                     2.5 M
 java-1.8.0-openjdk-headless                    x86_64      1:1.8.0.72-1.b15.fc22                      updates                      32 M
 jwhois                                         x86_64      4.0-44.fc22                                updates                     120 k
 kernel-headers                                 x86_64      4.4.5-200.fc22                             updates                     1.0 M
 kmod                                           x86_64      22-2.fc22                                  updates                     111 k
 kmod-libs                                      x86_64      22-2.fc22                                  updates                      61 k
 krb5-libs                                      i686        1.13.2-13.fc22                             updates                     855 k
 krb5-libs                                      x86_64      1.13.2-13.fc22                             updates                     839 k
 libass                                         x86_64      0.13.1-1.fc22                              updates                      95 k
 libassuan                                      x86_64      2.4.2-1.fc22                               updates                      75 k
 libblkid                                       i686        2.26.2-4.fc22                              updates                     186 k
 libblkid                                       x86_64      2.26.2-4.fc22                              updates                     180 k
 libbluray                                      x86_64      0.9.1-1.fc22                               updates                     147 k
 libcacard                                      x86_64      2:2.3.1-12.fc22                            updates                      77 k
 libcdr                                         x86_64      0.1.2-1.fc22                               updates                     409 k
 libcmis                                        x86_64      0.5.1-1.fc22                               updates                     598 k
 libcurl                                        x86_64      7.40.0-8.fc22                              updates                     247 k
 libdvdread                                     i686        5.0.3-1.fc22                               updates                      71 k
 libdvdread                                     x86_64      5.0.3-1.fc22                               updates                      71 k
 libertas-usb8388-firmware                      noarch      2:20160204-61.git91d5dd13.fc22             updates                     117 k
 libetonyek                                     x86_64      0.1.6-1.fc22                               updates                     610 k
 libfdisk                                       x86_64      2.26.2-4.fc22                              updates                     217 k
 libfm                                          x86_64      1.2.4-1.fc22                               updates                     427 k
 libfm-gtk                                      x86_64      1.2.4-1.fc22                               updates                     197 k
 libfm-gtk-utils                                x86_64      1.2.4-1.fc22                               updates                      30 k
 libgcc                                         i686        5.3.1-2.fc22                               updates                      97 k
 libgcc                                         x86_64      5.3.1-2.fc22                               updates                      88 k
 libgdata                                       x86_64      0.17.4-2.fc22                              updates                     435 k
 libgfortran                                    x86_64      5.3.1-2.fc22                               updates                     291 k
 libgomp                                        i686        5.3.1-2.fc22                               updates                     154 k
 libgomp                                        x86_64      5.3.1-2.fc22                               updates                     152 k
 libgpg-error                                   i686        1.21-1.fc22                                updates                     156 k
 libgpg-error                                   x86_64      1.21-1.fc22                                updates                     153 k
 libical                                        x86_64      1.0.1-3.fc22                               updates                     176 k
 libinput                                       x86_64      1.1.4-1.fc22                               updates                      93 k
 libipa_hbac                                    x86_64      1.13.3-5.fc22                              updates                      73 k
 liblangtag                                     x86_64      0.5.8-1.fc22                               updates                     192 k
 libmount                                       x86_64      2.26.2-4.fc22                              updates                     196 k
 libmpg123                                      x86_64      1.22.4-1.fc22                              rpmfusion-free-updates      183 k
 libmwaw                                        x86_64      0.3.7-1.fc22                               updates                     2.3 M
 libnghttp2                                     x86_64      1.7.1-1.fc22                               updates                      67 k
 libnm-gtk                                      x86_64      1.0.10-1.fc22                              updates                      90 k
 libodfgen                                      x86_64      0.1.6-1.fc22                               updates                     219 k
 libpinyin                                      x86_64      1.3.0-1.fc22                               updates                     202 k
 libpinyin-data                                 x86_64      1.3.0-1.fc22                               updates                     9.0 M
 libpng                                         i686        2:1.6.19-1.fc22                            updates                     124 k
 libpng                                         x86_64      2:1.6.19-1.fc22                            updates                     118 k
 libpng-devel                                   x86_64      2:1.6.19-1.fc22                            updates                     310 k
 libpurple                                      x86_64      2.10.11-16.fc22                            updates                     5.8 M
 libquadmath                                    x86_64      5.3.1-2.fc22                               updates                     179 k
 libreport                                      x86_64      2.6.4-1.fc22                               updates                     466 k
 libreport-anaconda                             x86_64      2.6.4-1.fc22                               updates                      54 k
 libreport-cli                                  x86_64      2.6.4-1.fc22                               updates                      58 k
 libreport-fedora                               x86_64      2.6.4-1.fc22                               updates                      51 k
 libreport-filesystem                           x86_64      2.6.4-1.fc22                               updates                      45 k
Old 20th March 2016, 09:35 AM
 libreport-gtk                                  x86_64      2.6.4-1.fc22                               updates                     110 k
 libreport-plugin-bugzilla                      x86_64      2.6.4-1.fc22                               updates                      91 k
 libreport-plugin-kerneloops                    x86_64      2.6.4-1.fc22                               updates                      56 k
 libreport-plugin-logger                        x86_64      2.6.4-1.fc22                               updates                      61 k
 libreport-plugin-reportuploader                x86_64      2.6.4-1.fc22                               updates                      68 k
 libreport-plugin-ureport                       x86_64      2.6.4-1.fc22                               updates                      64 k
 libreport-python                               x86_64      2.6.4-1.fc22                               updates                      79 k
 libreport-python3                              x86_64      2.6.4-1.fc22                               updates                      80 k
 libreport-web                                  x86_64      2.6.4-1.fc22                               updates                      62 k
 libreswan                                      x86_64      3.16-1.fc22                                updates                     1.1 M
 librevenge                                     x86_64      0.0.4-1.fc22                               updates                     243 k
 librsvg2                                       i686        2.40.13-1.fc22                             updates                     138 k
 librsvg2                                       x86_64      2.40.13-1.fc22                             updates                     134 k
 librtmp                                        x86_64      2.4-5.20150925.gita107cef.fc22             rpmfusion-free-updates       74 k
 libsane-hpaio                                  x86_64      3.15.9-3.fc22                              updates                     112 k
 libsmartcols                                   x86_64      2.26.2-4.fc22                              updates                     138 k
 libsmbclient                                   x86_64      2:4.2.9-0.fc22                             updates                     118 k
 libsndfile                                     i686        1.0.25-18.fc22                             updates                     170 k
 libsndfile                                     x86_64      1.0.25-18.fc22                             updates                     156 k
 libssh2                                        x86_64      1.5.0-2.fc22                               updates                     145 k
 libsss_idmap                                   x86_64      1.13.3-5.fc22                              updates                      79 k
 libsss_nss_idmap                               x86_64      1.13.3-5.fc22                              updates                      77 k
 libstdc++                                      i686        5.3.1-2.fc22                               updates                     450 k
 libstdc++                                      x86_64      5.3.1-2.fc22                               updates                     425 k
 libstdc++-devel                                x86_64      5.3.1-2.fc22                               updates                     1.8 M
 libteam                                        x86_64      1.23-1.fc22                                updates                      55 k
 libtiff                                        i686        4.0.3-21.fc22                              updates                     177 k
 libtiff                                        x86_64      4.0.3-21.fc22                              updates                     172 k
 libtool                                        x86_64      2.4.2-35.fc22                              updates                     594 k
 libtool-ltdl                                   i686        2.4.2-35.fc22                              updates                      55 k
 libtool-ltdl                                   x86_64      2.4.2-35.fc22                              updates                      54 k
 libusbx                                        i686        1.0.21-0.1.git448584a.fc22                 updates                      68 k
 libusbx                                        x86_64      1.0.21-0.1.git448584a.fc22                 updates                      67 k
 libuuid                                        i686        2.26.2-4.fc22                              updates                      79 k
 libuuid                                        x86_64      2.26.2-4.fc22                              updates                      79 k
 libvirt-client                                 x86_64      1.2.13.2-2.fc22                            updates                     4.4 M
 libvirt-daemon                                 x86_64      1.2.13.2-2.fc22                            updates                     523 k
 libvirt-daemon-config-network                  x86_64      1.2.13.2-2.fc22                            updates                      46 k
 libvirt-daemon-driver-interface                x86_64      1.2.13.2-2.fc22                            updates                      89 k
 libvirt-daemon-driver-network                  x86_64      1.2.13.2-2.fc22                            updates                     226 k
 libvirt-daemon-driver-nodedev                  x86_64      1.2.13.2-2.fc22                            updates                      88 k
 libvirt-daemon-driver-nwfilter                 x86_64      1.2.13.2-2.fc22                            updates                     114 k
 libvirt-daemon-driver-qemu                     x86_64      1.2.13.2-2.fc22                            updates                     494 k
 libvirt-daemon-driver-secret                   x86_64      1.2.13.2-2.fc22                            updates                      82 k
 libvirt-daemon-driver-storage                  x86_64      1.2.13.2-2.fc22                            updates                     253 k
 libvirt-daemon-kvm                             x86_64      1.2.13.2-2.fc22                            updates                      44 k
 libvisio                                       x86_64      0.1.5-1.fc22                               updates                     240 k
 libvncserver                                   x86_64      0.9.10-3.fc22                              updates                     258 k
 libwbclient                                    x86_64      2:4.2.9-0.fc22                             updates                      94 k
 libwebp                                        i686        0.4.4-1.fc22                               updates                     235 k
 libwebp                                        x86_64      0.4.4-1.fc22                               updates                     228 k
 libwpd                                         x86_64      0.10.1-1.fc22                              updates                     223 k
 libwpg                                         x86_64      0.3.1-1.fc22                               updates                      70 k
 libxdo                                         x86_64      1:3.20150503.1-1.fc22                      updates                      39 k
 linux-firmware                                 noarch      20160204-61.git91d5dd13.fc22               updates                      33 M
 lirc-core                                      x86_64      0.9.2a-3.fc22                              updates                     332 k
 lirc-libs                                      x86_64      0.9.2a-3.fc22                              updates                      92 k
 lldpad                                         x86_64      1.0.1-2.git986eb2e.fc22                    updates                     290 k
 lua                                            x86_64      5.3.2-2.fc22                               updates                     307 k
 lxdm                                           x86_64      0.4.1-11.fc22                              updates                     136 k
 microcode_ctl                                  x86_64      2:2.1-10.fc22                              updates                     566 k
 mingw32-wine-gecko                             noarch      2.44-1.fc22                                updates                      33 M
 mingw64-wine-gecko                             noarch      2.44-1.fc22                                updates                      34 M
 mplayer                                        x86_64      1.2.1-1.fc22                               rpmfusion-free-updates      1.2 M
 mplayer-common                                 x86_64      1.2.1-1.fc22                               rpmfusion-free-updates      1.2 M
Old 20th March 2016, 09:37 AM
 nautilus                                       x86_64      3.16.3-1.fc22                              updates                     2.5 M
 nautilus-extensions                            x86_64      3.16.3-1.fc22                              updates                      80 k
 nettle                                         i686        2.7.1-6.fc22                               updates                     339 k
 nettle                                         x86_64      2.7.1-6.fc22                               updates                     332 k
 network-manager-applet                         x86_64      1.0.10-1.fc22                              updates                     207 k
 nfs-utils                                      x86_64      1:1.3.3-6.rc3.fc22                         updates                     368 k
 nm-connection-editor                           x86_64      1.0.10-1.fc22                              updates                     965 k
 nmap-ncat                                      x86_64      2:7.00-1.fc22                              updates                     218 k
 nspr                                           i686        4.12.0-1.fc22                              updates                     139 k
 nspr                                           x86_64      4.12.0-1.fc22                              updates                     135 k
 nss                                            i686        3.23.0-1.0.fc22                            updates                     884 k
 nss                                            x86_64      3.23.0-1.0.fc22                            updates                     871 k
 nss-softokn                                    i686        3.23.0-1.0.fc22                            updates                     329 k
 nss-softokn                                    x86_64      3.23.0-1.0.fc22                            updates                     317 k
 nss-softokn-freebl                             i686        3.23.0-1.0.fc22                            updates                     200 k
 nss-softokn-freebl                             x86_64      3.23.0-1.0.fc22                            updates                     214 k
 nss-sysinit                                    x86_64      3.23.0-1.0.fc22                            updates                      57 k
 nss-tools                                      x86_64      3.23.0-1.0.fc22                            updates                     493 k
 nss-util                                       i686        3.23.0-1.0.fc22                            updates                      82 k
 nss-util                                       x86_64      3.23.0-1.0.fc22                            updates                      82 k
 ntpdate                                        x86_64      4.2.6p5-36.fc22                            updates                      90 k
 openssh                                        x86_64      6.9p1-10.fc22                              updates                     445 k
 openssh-askpass                                x86_64      6.9p1-10.fc22                              updates                      78 k
 openssh-clients                                x86_64      6.9p1-10.fc22                              updates                     672 k
 openssh-server                                 x86_64      6.9p1-10.fc22                              updates                     469 k
 openssl                                        x86_64      1:1.0.1k-14.fc22                           updates                     496 k
 openssl-libs                                   i686        1:1.0.1k-14.fc22                           updates                     945 k
 openssl-libs                                   x86_64      1:1.0.1k-14.fc22                           updates                     943 k
 openvpn                                        x86_64      2.3.10-1.fc22                              updates                     459 k
 opus                                           i686        1.1.2-1.fc22                               updates                     183 k
 opus                                           x86_64      1.1.2-1.fc22                               updates                     181 k
 os-prober                                      x86_64      1.70-1.fc22                                updates                      48 k
 p7zip-plugins                                  x86_64      15.09-9.fc22                               updates                     988 k
 pcmanfm                                        x86_64      1.2.4-1.fc22                               updates                     318 k
 pcre                                           i686        8.38-3.fc22                                updates                     504 k
 pcre                                           x86_64      8.38-3.fc22                                updates                     495 k
 perl                                           x86_64      4:5.20.3-329.fc22                          updates                     8.0 M
 perl-Carp                                      noarch      1.38-1.fc22                                updates                      28 k
 perl-Encode                                    x86_64      2:2.80-1.fc22                              updates                     1.5 M
 perl-Module-CoreList                           noarch      1:5.20160121-1.fc22                        updates                      73 k
 perl-PathTools                                 x86_64      3.47-312.fc22                              updates                      85 k
 perl-Pod-Escapes                               noarch      1:1.06-329.fc22                            updates                      62 k
 perl-Socket                                    x86_64      2:2.021-1.fc22                             updates                      55 k
 perl-Test-Harness                              noarch      3.36-1.fc22                                updates                     277 k
 perl-Time-HiRes                                x86_64      1.9728-1.fc22                              updates                      50 k
 perl-encoding                                  x86_64      2:2.80-1.fc22                              updates                      62 k
 perl-libs                                      x86_64      4:5.20.3-329.fc22                          updates                     748 k
 perl-libwww-perl                               noarch      6.15-1.fc22                                updates                     208 k
 perl-macros                                    x86_64      4:5.20.3-329.fc22                          updates                      54 k
 pixman                                         i686        0.34.0-1.fc22                              updates                     261 k
 pixman                                         x86_64      0.34.0-1.fc22                              updates                     254 k
 pixman-devel                                   x86_64      0.34.0-1.fc22                              updates                      18 k
 python-backports-ssl_match_hostname            noarch      3.5.0.1-1.fc22                             updates                      17 k
 python-coverage                                x86_64      4.0.3-1.fc22                               updates                     223 k
 python-dnf                                     noarch      1.1.6-2.fc22                               updates                     449 k
 python-dnf-plugins-core                        noarch      0.1.16-1.fc22                              updates                     105 k
 python-hawkey                                  x86_64      0.6.2-2.fc22                               updates                      77 k
 python-requests                                noarch      2.9.1-1.fc22                               updates                     105 k
 python-sssdconfig                              noarch      1.13.3-5.fc22                              updates                     100 k
 python-urllib3                                 noarch      1.13.1-3.fc22                              updates                     119 k
 python2-dnf-plugin-system-upgrade              noarch      0.7.1-1.fc22                               updates                      31 k
 python3-PyYAML                                 x86_64      3.11-11.fc22                               updates                     169 k
 python3-dnf                                    noarch      1.1.6-2.fc22                               updates                     453 k
 python3-hawkey                                 x86_64      0.6.2-2.fc22                               updates                      72 k
 python3-requests                               noarch      2.9.1-1.fc22                               updates                     106 k
 python3-sssdconfig                             noarch      1.13.3-5.fc22                              updates                     100 k
 python3-systemd                                x86_64      231-4.fc22                                 updates                      68 k
 python3-urllib3                                noarch      1.13.1-3.fc22                              updates                     125 k
security, update
[SOLVED] Can't install flash-plugin 11.1.102-62-release i386 JohnJasonJordan Using Fedora 9 4th February 2015 06:49 AM
F11 x86_64, Firefox 3.5, flash-plugin i386, mozilla-plugin-config bongoman Using Fedora 21 30th July 2009 02:58 AM
Current GMT-time: 02:05 (Friday, 24-03-2017)
