  #91
Old 31st July 2015, 06:49 PM
debo2011 Offline
Exclamation Re: PostInstallerF
Originally Posted by glennzo View Post
Here's what I get when I try to install this program under Fedora 21 I686.
Same issue as broadstairs?
I should add that all seems well with postinstallerf under Fedora 22.
Hi glennzo, yes is serious problem! Sourceforge experienced a storage fault; and I can't upload the new package ; but I hope tomorrow it will available for all.
http://sourceforge.net/blog/sourcefo...pdate-for-728/
My last option would COPR. But there is very limited, and I can not pack most packages, provided by PostInstallerF
Old 23rd June 2016, 11:20 AM
bob Online
Administrator (yeah, back again)
Location: Colton, NY; Junction of Heaven & Earth (also Routes 56 & 68).
Re: PostInstallerF
David, used your script for F24 Gnome and it's generally working very well, however dnf updates now shows:
Skipping packages with broken dependencies:
gstreamer1-plugins-bad-freeworld x86_64 1.8.1-4.fc24 postinstallerf 178 k
Looks like a tweak is indicated.
Registered Linux User #362651
Old 24th June 2016, 03:54 AM
debo2011 Offline
Re: PostInstallerF
Hi! thanks, I am updating now to 1.8.2; and it will solved the problem, gstreamer1 updated to 1.8.2 and affected the package.
Old 26th June 2016, 12:11 AM
ossandon Offline
Re: PostInstallerF
is rpmfusion necessary to use postinstallerf? When will 1.8.2 be ready?
Old 26th June 2016, 04:30 AM
debo2011 Offline
Smile Re: PostInstallerF
Short answer: No. rpmfusion is necessary for some tasks in PostinstallerF (but not a dependency); if you see gstreamer1 isn't part of rpmfusion, gstreamer1-devel is necessary if you want compile all gstreamer1-plugins... Why I provide a 'gstreamer1-plugins-bad-freeworld' in postinstallerf? well for "gstreamer1-plugin-openh264" the future...
dnf provides gstreamer1
dnf provides gstreamer1-devel
Old 26th June 2016, 07:09 PM
lsatenstein Offline
Re: PostInstallerF
Coming soon
I'm on F24. I click on mp4's and I get sound only.
I am able to dual boot Chapeau Linux F23, and view my mp4's. Any ideas about getting video to work?
Old 26th June 2016, 07:17 PM
antikythera Offline
Re: PostInstallerF
is ffmpeg-libs installed leslie? if not try installing that rpm
Old 26th June 2016, 07:46 PM
smr54 Online
Re: PostInstallerF
What player do you use, and it does it play x265 (HEVC) videos? This isn't yet consistent across distributions, and mplayer, at least, is usually able to play everything, but, for example, most Ubuntu offshoots have a version of mplayer that won't play x265 video. Their mpv will. At one point, Fedora's mpv wouldn't, but it does in its latest iteration.
To see if it's x265 encoded, if you have ffmpeg installed, you can run ffprobe -hide_banner <filename>.
If it does show that it's x265 (hevc) encoded, you may need a different player.
Old 26th June 2016, 11:56 PM
debo2011 Offline
Re: PostInstallerF
rpmfusion-non-free isn't complete in this moment; but all can install unitedrpms , repository
Old 27th June 2016, 11:33 AM
bob Online
Re: PostInstallerF
Before installing unitedrpms, I'd carefully read the description. Personally, there are things there that disturb me.
Old 5th October 2016, 11:23 AM
BkkLQ Offline
linuxubuntufirefox
Re: PostInstallerF
I'd also be careful with PostInstallerF, it has some major security flaws:
1. the .repo files disables GPG checks: repo_gpgcheck=0
2. some scripts (e.g. the RPMFusion installer) use --nogpgcheck without checking the signature of packages downloaded.
3. Some files are downloaded from an unencrpyted (HTTP instead of HTTPS) connection and no signatures are checked.
So as a general rule, don't ever open metadata files or run applications or installers for an insecure connection. To make a connection secure you should at least download it through HTTPS (and check the certificate validity) or check the signature (PGP or S/MIME) against a known key downloaded through a secure connection.
There are some more quality issues in this script, for example:
* the postinstaller will fail if a /tmp/.pictures folder already exists and is owned by different user. You should use mktemp instead.
* the "gnome" script is using zenity to get the password for sudo, but it is unclear whether to input the root or user password. Instead you should use pkexec, which you do sometimes.
* the software is inconsistent about using yad vs. using zenity. One of them should be enough.
If you want me to have a more detailled look at this software, please leave me a personal message.
Old 13th January 2017, 05:33 AM
debo2011 Offline
Re: PostInstallerF
Welcome your help, clone and make a pull request
https://github.com/kuboosoft/postinstallerf
postinstallation fedora, postinstallerf, repositories, scripts, sudeenly
Current GMT-time: 11:13 (Wednesday, 29-03-2017)
