  #466
Old 18th February 2017, 12:04 PM
raveit65 Offline
Re: MATE-Desktop for fedora
Dear MATE and Compiz haters :-)
MATE upstream did make some progress to fix the background issue with f25.
So i decided to fire up current state of work to copr repo.
https://copr.fedorainfracloud.org/co...te-Compiz-Fix/
As this is a developer version and not finished yet i repeat notes for this repo here.
Description
This testing repo is for fixing
https://github.com/compiz-reloaded/compiz/issues/40
https://bugzilla.redhat.com/show_bug.cgi?id=1383272
https://bugzilla.redhat.com/show_bug.cgi?id=1420709
It is the current state of those pull requests:
https://github.com/mate-desktop/mate-desktop/pull/249
https://github.com/mate-desktop/caja/pull/731
https://github.com/mate-desktop/mate...aemon/pull/169
Repo is for f25 and rawhide (f26)
Installation Instructions
Some notes:
1) mate-desktop, caja and mate-settings-daemon have higher versions than normal fedora repo. Packages from this repo will use 2 digits as fedora package version. So only an update to this package versions is needed after installing the repo.
2) Don't mix those packages with version from normal fedora repo, as this is a complete rewrite of background handling in MATE.
3) A session restart is needed after install.
4) Don't use this repo if you're not able to restore your system to normal package versions from fedora repos without running X-Server in a konsole, if something goes wrong.
5) Be warned, this is a developer version and might have issues.
Happy testing ;-)
Life is to short for boring desktops
Old 20th February 2017, 08:21 PM
solo2101 Offline
Awesome... Thank you for the hard work. Will test and report back.
Old 23rd February 2017, 05:15 PM
solo2101 Offline
Thumbs up Re: MATE-Desktop for fedora
Fix is working correctly. I can have a slideshow now instead of have a static wallpaper. Awesome Job.
The only thing I noticed is when wallpapers are changing, the desktop lags a little during the transition.
BTW if anyone is looking for a slide show script It's a port of gnome-wallpaper-slideshow.
https://sourceforge.net/projects/mateslideshow/
Old 26th February 2017, 12:10 AM
antikythera Offline
Thanks for your continued work with MATE Wolfgang, I'm not in a position to test these fixes at the moment. Otherwise I'd do so willingly
Old 12th March 2017, 07:14 PM
topiwala Online
When can we expect Marco's port to wayland?
Old 26th March 2017, 03:34 PM
raveit65 Offline
New builds for fixes the compiz issue are at bodhi.
https://bodhi.fedoraproject.org/upda...017-75ddaab36c
Old 31st March 2017, 08:11 AM
antikythera Offline
new builds have been pushed to stable. thanks wolfgang it works nicely
desktop, fedora, icon, mate, ubuntu
MATE Desktop question? BogdanPetkovic Using Fedora 7 15th March 2013 11:37 AM
Help with mdmsetup on MATE Desktop Jamwa Using Fedora 0 1st November 2012 06:58 AM
Fedora 17 Net Installation + Mate Desktop DragonWarrior Installation, Upgrades and Live Media 4 4th October 2012 11:42 AM
MATE desktop available for F16! tsorvoja Using Fedora 0 27th January 2012 06:01 PM
Mate Desktop Environment is977 Using Fedora 8 14th December 2011 08:23 PM
Current GMT-time: 22:45 (Monday, 29-05-2017)
