  #61
Old 8th January 2012, 03:15 AM
deanej Offline
Re: Cinnamon guide for F16 (replacement for gnomes-hell)
This is great! Now all I need are weather panel applets so I don't need to worry about gdesklets slowing the system down any more.
Old 9th January 2012, 02:02 AM
MorphingDragon Offline
I've uploaded the cinnamon files to my repo and will update my guide later tonight. I need to do other things as well like remove Adobe Air.
Leigh, the process of signing the packages removes mentions of your name from the packages, do you want me to put something on my website?
Old 9th January 2012, 02:09 AM
leigh123linux
Guest
Posts: n/a
There's no need.
Old 9th January 2012, 11:37 AM
windows_7ie
Originally Posted by leigh123linux View Post
There's no need.
Do you know how to change the user's session to Cinnamon at the command line?
I can't seem to find a similar hack like I did for LXDE.
Old 9th January 2012, 11:52 AM
leigh123linux
Guest
Posts: n/a
Have you tried
cinnamon --replace
Old 9th January 2012, 11:55 AM
windows_7chrome
Have you tried
cinnamon --replace
I thought --replace was temporary and the session reverts to Gnome 3 on next login?
Old 9th January 2012, 12:04 PM
leigh123linux
Guest
Posts: n/a
Ok, I would edit /var/lib/AccountsService/users/leigh to change session permanently
Old 9th January 2012, 12:32 PM
kkshethin Offline
Best tip for cinnamon by cavedweller
I was just passing through and reading the posts. Right now the panel is stuck to the bottom. If it hasn't been posted somewhere you might want to install dconf Editor. Then launch it. Under org you should find cinnamon. If you click on it and remove the checks out of the overview-corner-hover and overview-corner-visible, that will get rid of that annoying overview button tripping you evrytime you get near the menu bar and file.
Old 9th January 2012, 02:29 PM
Radioman621 Offline
macosfirefox
I installed cinnamon on Fedora 16 32 bit. It works perfectly, so far as i can tell. The only problem I have is that the fonts for all the menus are unreadable. They work, but you cannot read them. Missing letters, or mystery characters, or both. When you open an app all the fonts are perfect, it is just the menus, and anything on the top and bottom bar. Has anyone else run into this?
Old 11th January 2012, 06:09 AM
leigh123linux
Guest
Posts: n/a
The future 1.1.4 release is shaping up nicely.
I will be packaging cinnamon-settings and updating the extension package next repo update.
Click image for larger version
Name:	Screenshot at 2012-01-11 06:03:02.jpg
Old 11th January 2012, 07:26 AM
VernDog Offline
That does look nice, and the menu is now on top. Great replacement for gnome-shell.
Old 11th January 2012, 08:49 AM
Does it have the option to to mooove the bar back on to the bottom?
I just dislike things at the top of my screen.
Old 11th January 2012, 09:42 AM
leigh123linux
Guest
Posts: n/a
There's options in cinnamon-settings to move it to top or bottom.
Old 11th January 2012, 02:17 PM
spacin Offline
Is cinnamon settings in 1.1.3?
Old 11th January 2012, 02:23 PM
leigh123linux
Guest
Posts: n/a
No it's going to be a separate package that I will include in the repo when 1.1.4 is released.
cinnamon, f16, gnomeshell, guide, replacement
GIMP, Gnome, Cinnamon, XFCE, LXDE and the future of GTK+ Thetargos Linux Chat 59 8th November 2013 08:20 AM
gnome-power-manager replacement in gnome 3? fetchinson Using Fedora 6 28th September 2012 09:42 PM
Cinnamon and GNOME-Shell Adunaic Linux Chat 4 7th August 2012 04:13 PM
Howto use keyboard shortcut to reboot/shutdown from gnome/cinnamon hieronymous Guides & Solutions (Not For Questions) 0 23rd April 2012 12:03 AM
Cinnamon is Mint's gnome-shell fork Gareth Jones Linux Chat 28 2nd January 2012 09:24 AM
Current GMT-time: 19:27 (Wednesday, 24-05-2017)
