View Poll Results: Did it work for you
Yes 459 48.57%
No 343 36.30%
Nearly worked 143 15.13%
Voters: 945. You may not vote on this poll
Old 25th May 2007, 12:50 AM
Zero-Override Offline
[Alex@localhost ~]$ fglrxinfo
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (1.5 Mesa 6.5.2)
[Alex@localhost ~]$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
    GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
    GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
    GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
    GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
    GLX_ARB_multisample
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x22 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x23 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x24 24 tc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x3d 32 tc  1  0  0 c  .  .  0  0  0  0  0  0  0  0  0  0  0  0 0 None
these are my fglrxinfo and glxinfo outputs, maybe that helps anything
LINUX NUMBER 389596
machine number 290131
Old 25th May 2007, 12:54 AM
leigh123linux
Guest
Posts: n/a
Originally Posted by Zero-Override
i must have fudged up somewhere
okay here is what i did and have:
i have a fully operational and fresh install of fc7test4
i have the i686 kernel
i have yum and downloaded the packages,
what i don have
i don't have the the namechange from mesa to ati in the xorg.conf
when i tell it to do "service fglrx restart" it says
 bash: service: command not found
when i reboot it tells me that itś enabling the fglrx and that it may take a while, that works out okay and passes, then whenit should load my xserver it fails and says i fudged something up and that it will repair it =/
what would you suggest i do next?
oh btw, i have my xorg.conf exactly like described
I have not tried FC7 test4 yet ( I am going to wait for the final release ) and don't know if the XGL script will work for FC7.
As for the livna driver did you use the right release key.?
Can you also post the output from these commands
cat /var/log/Xorg.0.log | grep EE
and
cat /var/log/Xorg.0.log | grep WW
Old 25th May 2007, 12:59 AM
i get an error roughly saying thta i don't have fc7 yet (it is officially 6.93) so it won't load up
to game (just WoW) is there anything i can do at this point?
thanks for the lightning responsetime btw
[Alex@localhost ~]$ cat /var/log/Xorg.0.log | grep EE
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(II) Loading extension MIT-SCREEN-SAVER
[Alex@localhost ~]$ cat /var/log/Xorg.0.log | grep WW
(WW) No monitor specified for screen "Screen0".
(WW) The core pointer device wasn't specified explicitly in the layout.
(WW) No FontPath specified.  Using compiled-in default.
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(WW) VESA(0): Option "UseFastTLS" is not used
(WW) VESA(0): Option "BlockSignalsOnLock" is not used
(WW) VESA(0): Option "ForceGenericCPU" is not used
(WW) VESA(0): Option "KernelModuleParm" is not used
(WW) <default pointer>: No Device specified, looking for one...
[Alex@localhost ~]$
LINUX NUMBER 389596
Old 25th May 2007, 01:08 AM
leigh123linux
Guest
Posts: n/a
Ok try this as I dont think FC6 packages will work
su -
yum remove kmod-fglrx xorg-x11-drv-fglrx xorg-x11-drv-fglrx-libs-32bit
wget http://rpm.livna.org/fedora/6.93/i38...4.fc7.i686.rpm
wget http://rpm.livna.org/fedora/6.93/i38....lvn7.i386.rpm
rpm -i kmod-fglrx-8.36.5-3.2.6.21_1.3194.fc7.i686.rpm xorg-x11-drv-fglrx-8.36.5-3.lvn7.i386.rpm
Can you post any errors from the rpm command
Old 25th May 2007, 01:22 AM
it says i need the 8.36.5 >= is needed of fglrx-kmod-common after looking that up it should have been in the http://rpm.livna.org/fedora/7/i386/x....lvn7.i386.rpm file but thatś not a high enogh version
off to my bed (2.19 am here, got an important day tomorrow =/ ) but iĺl read any comment tomorrow and thanks for the help so far man! i appreciate it a lot
LINUX NUMBER 389596
Old 25th May 2007, 01:40 AM
leigh123linux
Guest
Posts: n/a
I have just looked at both repositories ( 6.93 & 7 ) and the fglrx driver versions dont match the kernel modules .
I will have a word with the person responsible and see if he can correct it.
Old 25th May 2007, 07:59 AM
omg O_O
influance...
that would be so great if you could manage to do that!!!!!
LINUX NUMBER 389596
Old 25th May 2007, 04:08 PM
leigh123linux
Guest
Posts: n/a
omg O_O
influance...
I have been told that this will be corrected by tomorrow
Old 26th May 2007, 12:59 PM
strikeforce Offline
Thanks for this it works great. The fact that you manually downloaded the packages does that run the risk of being outdated? Is there a repository to upgrade all the parts of compiz/xgl/ beryl?
- Helping New Users
Fedora Solved
- How to pay forward
Fedora Help Wanted
- Need a quick guide
Fedora Guide
Old 26th May 2007, 02:05 PM
leigh123linux
Guest
Posts: n/a
I have had a quick look at the script and the packages seem to be provided by this repository
http://fedoraxgl.tuxfamily.org/repos...0-3.noarch.rpm
So they should get any updates when released
Old 26th May 2007, 02:23 PM
strikeforce Offline
Beauty I think I have to turn it on because when I do a
yum check-update
It doesn't get the repo's data it just goes to my regular repo's
- Helping New Users
Fedora Solved
Fedora Help Wanted
Fedora Guide
Old 26th May 2007, 02:40 PM
leigh123linux
Guest
Posts: n/a
yum check-update
The repo is installed in a disabled state
[fedora-xgl]
name=Fedora $releasever - $basearch - Base Xgl repository
baseurl=
http://fedoraxgl.tuxfamily.org/repository/$releasever/$basearch
http://users.telenet.be/quenta/$releasever/$basearch
gpgcheck=1
enabled=0
#gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-AL-CAPCOM
[fedora-xgl-source]
name=Fedora Xgl tmp testing repository
baseurl=
http://fedoraxgl.tuxfamily.org/repository/$releasever/SRPMS
http://users.telenet.be/quenta/repository/$releasever/SRPMS
gpgcheck=1
enabled=0
To enable this repo try
yum --enablerepo=fedora-xgl check-update
Old 27th May 2007, 11:13 AM
tokegee Offline
Hi
I cound not install fglrx driver for my ati card. Although I have i686 kernel, it showed me error. My PC has ATi 9800 SE. How can I do that?
Best regards
Old 27th May 2007, 11:25 AM
leigh123linux
Guest
Posts: n/a
Originally Posted by tokegee
Hi
Best regards
You have a i585 kernel and need to swap it for a i686 kernel as described in section 1
to check
rpm -qa --queryformat "%{NAME}-%{VERSION}-%{RELEASE}.%{ARCH}\n"|grep kernel|sort
to fix
su -c "yum install yum-utils"
yumdownloader kernel.i686
su -c "rpm -ivh --replacefiles --replacepkgs kernel-2*.i686.rpm"
reboot
then run these commands again
su -
yum install kmod-fglrx xorg-x11-drv-fglrx xorg-x11-drv-fglrx-libs-32bit
yum update kmod-fglrx xorg-x11-drv-fglrx xorg-x11-drv-fglrx-libs-32bit
fglrx-config-display enable
You will need to read my howto carefully as all the steps are required
Old 28th May 2007, 03:43 PM
tokegee Offline
Hi leigh123
Thank you .. leigh123, I got fglrx driver installed and Beryl too. Well .. please let me ask more questions.
After installing them, I lost my desktop effects. Although I tried with Beryl Manager, I got nothing effects.
And all resolutions were changed from my current resolution 1024x768 to the 1280x1024. Although I could change my destop resolution to 1024x768, but Starting screen and Login screen are in 1280x1024. So how can I fix it and How can I get Desktop Effects?
Best regards
PS: have a nice day
ati, fglrx, howto
ATI Catalyst fglrx driver manual install on Fedora 12 Jeff72 Guides & Solutions (Not For Questions) 15 13th August 2010 09:17 PM
ATI Catalyst™ Display Driver v9.12 rich52 Hardware & Laptops 1 31st December 2009 04:59 AM
HOWTO - make less noise from video card while using fglrx driver multescugeorge@ Guides & Solutions (Not For Questions) 2 3rd October 2009 08:02 AM
ATI Catalyst 9.x fglrx driver manual install on Fedora 11 Jeff72 Guides & Solutions (Not For Questions) 25 30th August 2009 08:29 PM
Current GMT-time: 18:35 (Sunday, 28-05-2017)
