Old 11th January 2017, 08:48 PM
elmarts Offline
windows_7firefox
Re: Windows 10 is gone after installing Fedora workstation 25
Hmmm - this is worrisome. I have a functioning win7 64 bit installed on my SSD, with about half the SSD unallocated to make room for the Linux installation (Fedora-MATE_Compiz-Live-x86_64-25-1.3). The machine is UEFI (mobo ASRock H170M PRO4, BIOS version 7.10). I am concerned about installing to the SSD (first 2 partitions are a windows system reserved of 100MB, and the C drive of 125 GB; 100 GB remaining unallocated). Anyone see problems or things I really need to be careful of? I really do need my Win7 OS to be functional. - Elmar
Old 12th January 2017, 05:50 PM
TruboXL Offline
windows_98_nt_2000firefox
You definitely need to use Windows 10 DVD/USB to repair...
Laptop: http://forums.fedoraforum.org/showpost.php?p=1760122&postcount=528
Windows 10, Fedora MATE / Cinnamon
Old 13th January 2017, 04:43 PM
allocated Offline
linuxfedorachrome
Originally Posted by topiwala View Post
If your windows cannot boot using EFI manager than it will not using Grub. I would advise you to make a windows 10 usb/dvd and repair installation.
Yeah I think i've got that now pretty much.... no other way to do it internally it seems. But the problem is it isn't even booting from Live media (USB) or CD/DVD that has a windows image burned in it. As I mentioned earlier it accepts it as a bootable device AND boots from it if it's a linux live media but for windows it doesn't even register it as a disc.
I think i'll ask Dell Service center for help, see if they can do something with it....
fedora, grub 2, installing, windows, workstation
checksum Fedora-Workstation-netinst on Windows wolfv Installation, Upgrades and Live Media 8 2nd February 2016 06:55 PM
Installing Fedora 17 in VM Workstation kcwong13 Installation, Upgrades and Live Media 0 4th August 2012 02:31 PM
help - installing fedora 8 to VM ware workstation 6.01 in windows xp poor Installation, Upgrades and Live Media 3 16th March 2008 01:50 PM
Installing Fedora core 5 as guest in VMware workstation 5.5 running on windows XP pro holmen Installation, Upgrades and Live Media 5 30th September 2006 11:56 AM
Installing Fedora Core 4 (x86) on Vmware Workstation 5.0 on Windows XP fedoraamd64 Using Fedora 6 23rd June 2005 12:36 PM
Current GMT-time: 15:28 (Monday, 20-02-2017)
